My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Jun 20, 2019 at 8:20 PM
    #301
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Order 6 ohm/50W resistors and the appropriate LEDs. Try the front LEDs without resistors. If you don't get hyperflash with LEDs in the front, then try LEDs in the rear turn signals. For the rear LEDs, you'll probably need to add a 6 ohm resistor behind each tail light housing. Screw them to the metal behind the housings. This video shows you how to install the resistors: https://www.youtube.com/watch?v=z4HlVYkceNo&t=515s
  2. Jun 20, 2019 at 8:27 PM
    #302
    1_thirsty_tundra
    1_thirsty_tundra The Thirsty Tundra
    Jay
    Alberta Canada
    2019 SR5 Off-Road Crew Max
    Spintech custom exhaust Bilstein 6112 / 5100 Coachbuilder shackles / shims Vled LED interior Winjet tails Pacer high 5 cab lights Fuel Contra 20x10-18 wheels Wireless Apple Carplay/ Android auto Custom Pioneer stereo system Custom Crewmax underseat storage
    Just upgraded mine today(with resistors) also added some GM style tow mirrors. You can see me turning now for sure
    WFD473, iHacker and CCLJ03 like this.
  3. Jun 20, 2019 at 8:29 PM
    #303
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    very nice set up
  4. Jun 20, 2019 at 8:31 PM
    #304
    1_thirsty_tundra
    Jay
    Alberta Canada
    Thanks!
  5. Jun 20, 2019 at 8:33 PM
    #305
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    no doubt... very clean
  6. Jun 21, 2019 at 12:10 AM
    #306
    CLowery
    CLowery New Member
    Bates City, MO
    2018 Cement Tundra TRD
    None (yet)
    I did Front blinkers and backup lights on my 18 and I did not need resistors.
  7. Jun 21, 2019 at 6:31 AM
    #307
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    I have a 2018 Limited and I did the backup lights and the front blinkers, no resistors needed. I also did the cargo lights and most of the interior lights.
    Just make sure you get the correct base (CK or Standard) for the backup lights. The first ones I got were these:
    https://www.amazon.com/gp/product/B00NPIYDWU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    They worked fine for a while (and I think they'd be fine for 14-17 trucks), but they ended up blowing a fuse and the fuse was for the same circuit as the neutral safety switch. The truck didn't shift right and I had all sorts of warnings that the PCS and other safety sense features weren't working. Toyota tried to blame it on the OBDII connection for my iDataLink Maestro unit for the radio and wouldn't touch it. Luckily I was able to research it and discover it was just a fuse.
    I replaced the reverse bulbs with these last July, and they've been working great:
    https://www.amazon.com/gp/product/B06XQWPKKX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  8. Jun 21, 2019 at 9:29 AM
    #308
    CLowery
    CLowery New Member
    Bates City, MO
    None (yet)
    Thanx for the info. I think I'll switch mine out to the ones you suggested. $16 is worth not having future issues.
    JoeJob[QUOTED] likes this.
  9. Jun 22, 2019 at 10:21 PM
    #309
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Just revisited this thread, been 1 year or thereabouts. Went VLED's tritons for front turns and lower cost for rear turns, brake and back up. Resistors on all 4 corners, wired in back with t-taps on hot side. There has been no doubt with others knowing my intent, turning, stopping or backing up. 2018 CM with LED in front. Money well spent. Hyper flash without resistors and none after.
  10. Jul 21, 2019 at 3:47 PM
    #310
    Yzed608
    Yzed608 New Member
    Wisconsin
    So these resistors don't work with the v6 bulbs on our trucks? It looks like they are only up to 2.25A not a full 3 (although that's stated on the separate part page). I was looking at their full PnP with the adapter:
    https://www.vleds.com/shop-application/turn-signals-front/7440/amber/v6-triton-kit-a-7443.html
  11. Jul 30, 2019 at 7:29 AM
    #311
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    Go to VLEDS.com...I learned the hard way (don’t recommend Headlight Revolution!). Their shipping and customer service is waaaay slow. Nice videos though.
  12. Dec 31, 2019 at 5:05 PM
    #312
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Trying to add the JDM 1260 Ambers to the front and have a few questions.
    Similar to @Pudge, I'm in a '14 TSS OR, with '19 Pro LED HL. I think he's correct that the 14 - 17 yr models w/ 18+ LEDs need resistors, while the 18+ yr models do not.
    Before adding resistors, I had a couple questions for @BlueBottle and @NewImprovedRon
    I read on a Lexus forum where people have had the dealer to turn up the number of blinks from 2-3 to 7-8, apparently by using Techstream to adjust the BCM/ECU. Which...doubling the flash count would seem to me like not just a hyper-flash, but would increase the load and decrease the bulb life?
    With this in mind, theoretically, could I use Techstream to turn down the number of blinks, such that the LEDs would work without resistors??
    If not, @Pudge; Do you have a link for the resistors you used?
  13. Dec 31, 2019 at 5:28 PM
    #313
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm not sure. I checked my Amazon account and didn't see them. I'll looks again. I wanna say they were around $10
    Found them! https://www.amazon.com/gp/aw/d/B00DCULNXS?psc=1&ref=ppx_pop_mob_b_asin_title
    GAknight[QUOTED] likes this.
  14. Dec 31, 2019 at 6:42 PM
    #314
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Pudge[QUOTED] likes this.
  15. Dec 31, 2019 at 8:08 PM
    #315
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I honestly don’t know if changing the blink times will fix the issue. The proper way to fix it is by adding resistors. I know it’s expensive but if you want to do it the right way you should go w vled since they have pnp resistors w their v6 lights. Just my opinion.
  16. Jan 1, 2020 at 11:08 AM
    #316
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks Ron!
    Ordering resistors next!
    NewImprovedRon likes this.
  17. Jan 1, 2020 at 12:05 PM
    #317
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    My led blinkers from Vleds required no resistors on the oem led headlights.
  18. Jan 4, 2020 at 9:51 AM
    #318
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 and 2019 Tundra Double Cab Limited MGM
    3/1.5 leveling kit, ADS 2.5 front shocks, ADS 2.5 piggyback rears, MCM UCA’s with Delta joints, MCM Bracket with ADS Air Bumps in the rear, Toytec shackles set at 1.5, BFG KO2’s 35x12.5x18, SCS SR8 Bronze with machined lip wheels.........
    Did the JDM ASTAR 1260’s to my 19 Limited, I would have never guessed that the factory ones were so dim, the led bulbs were about 10 times brighter.
    I’d definitely recommend this upgrade.
    stuckinohio likes this.
  19. Jan 4, 2020 at 10:23 AM
    #319
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I hate this place. I didn't even know this was a thing until I read this. Went outside and checked...... Yep, I have weak blinkers. Amazon gets more of my money.
    phogallen and panicman like this.
  20. Jan 4, 2020 at 10:35 AM
    #320
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    14 months and still going strong. No issues, bulbs are still bright enough to scare a cat out of a tree.
  21. Jan 7, 2020 at 11:22 AM
    #321
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    aloha all, new member here. recently installed the VLED v6 triton switchbacks on my 2015 and was wondering if anyone had advice on how to install the tap for the dim wire harness? I got everything else installed and it's working perfect... but the white LED is brighter than my headlights at night haha
  22. Jan 7, 2020 at 11:34 AM
    #322
    Flying Fuzz
    Flying Fuzz New Member
    2019 GX460 Premium with Sport package.
    Installed the JDM Astar this weekend. 2019 with LED headlights, plug and play. Here’s a picture of the physical size of these things as I was surprised by how big they are.
  23. Jan 7, 2020 at 5:59 PM
    #323
    panicman
    Eric
    Yo Fuzz, forget the bulb what is THAT:
  24. Jan 7, 2020 at 6:06 PM
    #324
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Looks like a mini bug zapper...
  25. Jan 7, 2020 at 6:48 PM
    #325
    Flying Fuzz
    Titanium tritium vial holder for my keychain. Holds six small vials of tritium gas which is what’s used on Trijicon night sights for your pistol/rifle. The one for the Tundra has a similar blue like the dash lights. I have one for my Audi as well but I put in three blue and three red.
    So when it’s bright out it looks like a weird piece of metal but when there zero or minimal light my keys can be found easily.
    superdenk, AZBoatHauler, bvia and 2 others like this.
  26. Jan 7, 2020 at 6:49 PM
    #326
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I really like that..
  27. Jan 7, 2020 at 6:52 PM
    #327
    Flying Fuzz
    Thanks. The photo makes them seems brighter than they are, has a nice subtle glow at night. Wife was annoyed when I told her the prices, I think once said and done the titanium holder with the tritium was $130 each
  28. Jan 7, 2020 at 6:55 PM
    #328
    empty_lord
    05 rollover special
    How long are the tubes good for? I’d assume the same half life as trijicons or w/e sights. Which is usually 10 years.
  29. Jan 7, 2020 at 6:57 PM
    #329
    Flying Fuzz
    Yup the same about 10-12 years
    empty_lord[QUOTED] likes this.
  30. Jan 7, 2020 at 7:17 PM
    #330
    panicman
    Eric
    Nice that you can tell them apart as well.
    Thank you!
