CB Antenna Mount
Discussion in 'Colorado' started by Lifeofbrian, Jun 20, 2019.
  1. Jun 20, 2019 at 7:35 PM
    Lifeofbrian
    Lifeofbrian [OP] New Member
    2010 Tundra 5.7 Rock Warrior
    TBD
    Wondering what you all are using to mount your antenna? If you use a cb radio that is. :D
  2. Jun 21, 2019 at 4:05 AM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
  3. Jun 21, 2019 at 4:30 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Im using half of a regular trucker mirror mount. Worked well for me.20190621_062932.jpg
    CaptSpaulding likes this.
  4. Jun 21, 2019 at 5:07 AM
    Aurora CO
  5. Jun 22, 2019 at 8:46 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I used a mirror mount like @Larmand but put mine in the bed rails.
  6. Jun 22, 2019 at 10:00 AM
    Lifeofbrian
    TBD
    Nice!
  7. Jun 22, 2019 at 11:48 AM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    Do you have a problem with cargo snagging on the wiring? I would be concerned about tearing up the wiring when hauling stuff.
  8. Jul 31, 2019 at 10:41 AM
    CO_Native
    CO_Native New Member
    Englewood, CO
    2019 MGM CM TRD Sport
    Hey all, I just picked up a new truck & wanted to swap my CB over from my 4Runner to the Tundra. Looking at mounts I came across this thread.
    Where on the truck is this? It's a bit close for me to tell where you have it mounted. Looks like the spare? Underneath somehow?
    How did you actually attach it to the bed rails & where is your cable routed?
  9. Jul 31, 2019 at 10:43 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Mine is attached to front right corner of the bed.
    Squatting Pigeon likes this.
  10. Jul 31, 2019 at 10:49 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I made my bed rails out of Unistrut, so I used unistrut connectors to actually mount it.
    I ran the wire from the CB under my carpet and out a rubber plug directly underneath the back seat. Then down along the frame rail and through the plastic cut out at the front of the bed. No drilling whatsoever! :thumbsup:
    (I've since pulled the slack from that wire)
    Cement likes this.
  11. Jul 31, 2019 at 10:51 AM
    CO_Native
    Englewood, CO
    Outstanding! Thanks guys!
  12. Jul 31, 2019 at 11:39 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    I'm a fan of stake pocket mounts and hidden cabling.
    Not a CB antenna but what you screw on top doesn't matter.
    If you haven't already, take a look at Breedlove Mounts. None better built in the world. All kinds of rock solid CB mounts and here's a direct link to his stake pocket options: https://www.breedlovemounts.com/ezn-stake-pocket-bracket.html
    CO_Native likes this.
