Frame Mounted Air Tanks
Discussion in '2.5 Gen Builds (2014-2021)' started by CM-LENNY, Nov 2, 2016.
  1. Nov 2, 2016 at 3:21 PM
    CM-LENNY
    CM-LENNY [OP] No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey everyone I missed posting a few pics in my "still under const build", so thought I would show them here. I have my twin cyl ARB compressor under the hood and ran 3/8" air brake tubing through the frame rail to feed the air tanks. Both tanks are tied together and feed a qwik-connect on either side of the truck. ( just under the doors ). I can then fill my airbags without firing the compressor up. I also deflate my tires to 13 psi when I go cruising in the desert dunes. I use a set of 4 Staun deflators I have preset @ 13 psi. ( they work awesome ). When it's time to head home, I fill up the tires to 55 psi and the airbags to 65 psi and tow our travel trailer home. I have another single Staun deflator set @ 35 psi for my everyday driving pressure when I get home. The tanks are 2 different sizes for a total of about 4-5 gallons. This is also easier on the compressor when filling lots of tires. ( one draw back.........guess who fills most the tires around the campsite now ). I made the brackets out of aluminum and everything is tucked up above the bottom of the frame rail and strictly bolt on. Sorry for rambling on.........( my wife says I have a problem with that.
    DSCN3201.jpg DSCN3202.jpg DSCN3203.jpg DSCN3204.jpg DSCN3205.jpg DSCN3206.jpg DSCN3207.jpg DSCN3208.jpg DSCN3209.jpg DSCN3210.jpg DSCN3211.jpg DSCN3213.jpg
    Civiceg94, 1UPPER, cmrock and 12 others like this.
  2. Nov 2, 2016 at 4:24 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Another item for my list ...
  3. Nov 2, 2016 at 4:33 PM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Nice work...
  4. Nov 2, 2016 at 6:17 PM
    CM-LENNY
    San Diego, CA
    Thanks for the comments guys. Another note if you are thinking about adding a compressor and holding tanks to your rig: my compressor gets used more than you think. At times I don't feel like breaking out my garage compressor, so I simply plug into my qwik-conn on my frame rail. Also works great for bike tires etc when out going on a beach cruise. Just some thoughts.
    trayday, Wrongside, 831Tun and 3 others like this.
  5. Nov 2, 2016 at 9:51 PM
    gosolo
    Ray
    NW Oregon
    Really nice
  6. Nov 2, 2016 at 10:04 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's pretty sweet!
  7. Nov 5, 2016 at 9:48 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Had a chance to see this in person and the pics don't do it justice. Awesome mods man. Thanks for meeting up today!
  8. Mar 19, 2017 at 6:57 AM
    Rbtrd
    Rbtrd New Member
    So Cal/Oregon
    2017 Tundra trd pro CM wht
    CM-Lenny. I know this thread has been around for awhile but i just discovered it. Looks like a great set up and Im thinking of doing this(similar) to my 17'Pro.
    How has it held up over time? What bags did you use? Does it limit you while off-roading? What was the cost?
    I would appreciate the knowledge. Thanks RB
  9. Mar 19, 2017 at 7:12 AM
    CM-LENNY
    San Diego, CA
    Hey RB.........If you link onto the "build thread" in my signature you will find some of my mods. It shows the twin ARB compressor, Firestone bags etc. If you plan on using bags and going off road, definitely get air bag cradles. You will tear your bags apart other wise. My mods are homemade so kinda hard to give you a price. Also the Firestone bag mounts are not stock, they are homemade too. All my stuff has held up fine so far. I try to design and build it to last the life of the truck. Hope this helps. Yell with any questions.......
  10. Mar 19, 2017 at 7:21 AM
    Rbtrd
    Rbtrd New Member
    So Cal/Oregon
    Thank you Lenny for the qwik response. Unfortunately i dont have the skills/ballz to do the work myself, which saves $$$. I wont do a lot of off roading. Just logging/fire roads n some snow. Just wanna cure the sag while towing. Thanks again RB
  11. Mar 19, 2017 at 7:27 AM
    CM-LENNY
    San Diego, CA
    The Firestone kit is strictly bolt in with simple hand tools. They even have a set-up with a small compressor, gauge and switches. I only have the ARB and tanks cuz I air down my 37's to off-road in the sand. (and fill the bags too). Good luck with all RB.
    Jsena likes this.
  12. Mar 19, 2017 at 7:31 AM
    Rbtrd
    Rbtrd New Member
    So Cal/Oregon
    You da man!! Thx
  13. Mar 19, 2017 at 10:07 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Lenny, are those tanks completely above the lowest part of the frame? I've been toying with the idea of OBA, even though it's not like it's a necessity at this point.
  14. Mar 19, 2017 at 10:30 AM
    CM-LENNY
    San Diego, CA
    Yes I made certain that they were tucked up nice and tight out of harms way.
  15. Oct 25, 2017 at 1:02 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  16. Oct 26, 2017 at 9:31 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Awesome setup! Do you mind post a list of parts you used and how it was setup? I’d love to have the same setup
