NSV Light Bar Install Tips
Discussion in 'Lighting' started by cook2kill, Feb 10, 2019.
  1. May 23, 2019 at 7:16 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    You need to install that on your headlamp assembly it’s the piggy back harness so you don’t have to splice I have a 19 might be little different but I will take some pics when I get home tonight hopefully will help
  2. May 23, 2019 at 7:17 PM
    Mr.GT.Fan
    Mr.GT.Fan New Member
    2014 Tundra 1794
    NSV LightBar, 2018+ LED headlights, 2018+ front TRD Pro grill, front Honeybadger Bumper with 40inch light bar and winch, 4 ½ ADD full coil suspension lift kit, 20x10 on 35s. Rear Dual swing arm Bumper with spare tire and gas tanks.
    What year and trim is your truck? Also, do you have factory headlights? Or installed factory LEDs or non DRL headlights? The headlight setup that you have decides how to wire the bar.
  3. May 23, 2019 at 7:41 PM
    Mr.GT.Fan
    2014 Tundra 1794
    Did you install LED turn signals? If you didnt. Just unplug factory plug and connect it to the T harness from the light bar and the other end to the headlight. Then the plug that connects to the factory plug from the car CUT the blue wire and you have to tap a cable from that blue cut cable to the purple on the motorized plug down on the headlight. For that you need to take out the battery, it is the only way to access it without taking grill and headlights out. Do not cut blue cable on the factory plug from the car, cut the blue cable on the plug coming from the t harness to the car factory plug.
  4. May 23, 2019 at 7:52 PM
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    I have a 2015 1794. I have the factory headlights with the factory DRL.
    I followed the HR videos for the Gen 1 since I wanted the strobe. I started going through the manual and I've noticed it says for Gen 2 bars not to pin 2 & 9. Well I've pinned those. I didn't do the jumper wire like the videos or the manual because of the harness.
    Even now with the harness not installed I get swipe and strobe. The light bar works with high beams but only when the headlight switch isn't set to Auto.
    I'm completely lost here and wondering should I have not pinned 2 & 9 better yet if so how to depin them.
  5. May 23, 2019 at 8:29 PM
    Mr.GT.Fan
    2014 Tundra 1794
    0689B16F-9E6E-4C16-AF5F-7AE04C7B1DAD.jpg 78705AEC-5513-43E4-B98E-24B333794979.jpg 87B55AC4-F590-4D23-8FC2-283B5BBA81A5.jpg Here is screen caps of the video installation, in this case it was installed in a 2014-2015 sunset bronze tundra 1794 with factory led DRLs.
  6. May 23, 2019 at 8:31 PM
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    So I need to do this and not use the drl harness that came with the kit?
  7. May 23, 2019 at 8:34 PM
    Mr.GT.Fan
    2014 Tundra 1794
    I did not use the harness provided, and on the video he didn't use it either. Just jump to the purple, and should work.
    Oh and you dont have to take battery out, I unplugged it, and moved it to one side away from the headlight connector just enough to fit my hands to work down there. I did it so I could try different setup until I got the one that worked for me.
  8. May 23, 2019 at 9:08 PM
    Welcome from NY.
    TopNotch likes this.
  9. May 24, 2019 at 3:38 AM
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    So it sounds like the harness is a waste???? Why would they include it... Do you think the harness would work if I depinned 2&9.
    I don't mind splicing but if I don't have to and can make the harness work that would be the direction for me.
    I take it yours is a Gen 2 as well?
  10. May 24, 2019 at 4:09 AM
    Mr.GT.Fan
    2014 Tundra 1794
    I just purchased it about a month ago so yeah I think is gen2 I don't have strobe which Im good about it. I installed it following original specs. Pinned it as per instructions. I have the light-bar running the corner lights as DRL. Then on demand swipe lights, and high beam full bar when not on auto. Im cool with it. I had trouble installing because I purchased OEM 2018+ LED DRL headlights with LED turning signals and the NSV. Took me a while to figure out because technically my trim didn't have factory LED DRL headlights, only daytime LED, so although I installed it, I had to use provided plug and play harness, but does not make it factory therefore instructions re not the same, then NSV installation went crazy because instructions are either factory DRL or not. No in between lol. Anyways, I had to cut the blue cable and jump it on the purple and not switch any pin so the turning signals would work.
  11. May 24, 2019 at 10:18 AM
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    10-4. Thanks for the info. All the functionality works with the exception of the DRL on the light bar so I guess the DRL harness supplied doesn't work with the 1794 trim level??? I can make the jumper from the blue to the purple.
    Any idea why they (NSV) is saying on the GEN 2 not to pin 2 & 9?
  12. May 25, 2019 at 6:44 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Pin #2 is a redundant 12+ bat supply for the DRL and swipe on alarm. When disconnected, it prevents them from back feeding and holding the turn light on, and prevents accidentally triggering the swipe function when signalling with a short pulse (not fully engaging the turn signal).
    Pin #9 is actually the "blue" tap wire from the headlight that dims the DRL when the low beams are turned on. There are many automatic lighting features in our trucks (not "auto" headlight setting) that confuse things for the nsv. Disconnecting this defeats the dim feature, but allows for nsv switch control over the DRL at full brightness
    Beesta likes this.
  13. May 25, 2019 at 7:30 AM
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    Great info. Thank you!
    Let me ask you this... I spoke with Jensen yesterday about the harness that came with my kit. It seems I was shipped a Gen 3. That harness plugs into headlight motor and gets rid of the need for the jumper. I've got it hooked up now the way he told me too as well had to disconnect the blue wire from the NSV harness that is running into the headlight.
    I populated pin 3 instead of pin 8 because I wanted the strobe feature. Do you think I need to unpin #2 to get the DRL function? Right now everything works correctly: Stone, Swipe, Swipe on for unlock/lock. Just no side markers on the light bar.
    Any insight is much appreciated.
    Beesta and Toyotoholic[QUOTED] like this.
  14. May 25, 2019 at 12:27 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I am using a Switch Pro to apply 12+ to the blue anytime I want it "dim" and leaving the nav happy and functional. I am also using the SP to give me overall control of the nsv, even with the lights/truck being off.
    The only way to get the dim and the bright is to have one or the other while maintaining safe function of the nsv.
  15. Jun 19, 2019 at 4:21 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Theft light went away after I started it a couple times.
    Guess it just needed to remember what key was what.
    Install went flawless though
  16. Jul 20, 2019 at 4:21 PM
    Clay4
    Clay4 New Member
    Clay
    2018 Tundra Platinum
    Pop-and-Lock Tailgate Painted Door Handles and Mirror Caps Stubby Antenna Husky Floor Mats
    Got my NSV light bar on the July 4Th sale!!!! The 15% discount was apparently the straw that broke the camels back on me dropping the money on it. I installed mine in segments due to my work schedule this last week. I mounted the light the first night. Ran and pinned the harness through the hood the next night. Yesterday/last night I finished the rest of it. I was very happy with the look, fit & function of the light. I have a 2018 Platinum with LED headlights and DRL's. It got a bit confusing on the T-harness part of the install. I didn't cut or re-pin any connectors on the first install. I went out to try it out and was happy. Once I got over the initial wow factor of the new bright light...I started looking closer and noticed my drivers side front blinker was on all the time and didn't blink when the turn signal was on. Then when all the NSV light was completely turned off, and I turned on the left blinker....the blinker would blink but would blink and then be off set by BOTH OEM DRL's counter blinking!!!
    Thanks to @cook2kill and @starbucks' write ups...I figured out all I needed to do was cut (or like @starbucks did...de-pin) the blue female wire from the T-harness that attaches to the headlight...system works like a champ and couldn't be happier!
  17. Jul 20, 2019 at 5:55 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    X2 exactly what I did love the nsv cool as ice
  18. Jul 22, 2019 at 11:24 PM
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    Nott sure what I did but I just lost my swipe feature on the lock and unlock. Anybody have a clue on what I may have done?
  19. Jul 23, 2019 at 2:45 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    What was the last thing you did to the truck?
    I mean anything, wash it, change the battery, check the oil...
  20. Jul 23, 2019 at 2:49 AM
    #50
    Devildawg712
    Union City, Ca
    I pulled out the turn signal bulbs tot swap them out. I'm sure I must have pulled a splice or something, but I can't figure out how I had it exactly. =/
  21. Jul 23, 2019 at 10:36 AM
    #51
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    2016 White Tundra TRD Pro
    Fab Four front/rear bumpers, Warn VR12S
    I have the Gen 3 setup, so pin 8 to 3 would give you strobe ?
    Which switch controls the strobe then ?
    Thanks...
  22. Jul 23, 2019 at 11:01 AM
    #52
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    Why all the work getting to the trailer output for power source, I thought that was really weird...
  23. Jul 27, 2019 at 9:24 AM
    #53
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    The DRL switch
  24. Jul 27, 2019 at 10:38 AM
    #54
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    You're likely going to lose this feature eventually anyhow. I had to de-pin that connection because the swipe would sometimes trigger when using the turn signals while driving. It's a bug in the NSV bar that they haven't fixed to my knowledge. Here's the postmortem from my install:
    https://www.tundras.com/threads/nsv-hood-bulge-light-bar-install-postmortem.29033/
    As well as a couple of other issues I ran into along the way:
    https://www.tundras.com/threads/fog-lights-not-working-after-2018-headlight-upgrade.30900/
    https://www.tundras.com/threads/v6-triton-blinkers-issue-w-nsv-oem-led-headlight-upgrade.44120/
  25. Aug 10, 2019 at 8:17 PM
    #55
    MVtundra
    MVtundra New Member
    paul
    2019 TRD Pro
    hi guys new to the forum. does anyone know if i attach the blue wire from the piggyback harness directly to the battery instead of the purple wire from my headlight motor will this work or will it cause other problems? Does the blue wire need to be connected to ignition on power or is constant power ok? T have a 2019 trd pro wiyh led headlights and drl's. thanks for all the info
  26. Aug 11, 2019 at 1:44 PM
    #56
    4077th
    4077th New Member
    2018 Tundra SR5
    Yes, I have this same exact question. Hearlight revolution won't respond at all...
    Thanks!!
  27. Aug 28, 2019 at 7:04 PM
    #57
    wire89
    wire89 New Member
    I saw one reply in this thread related to connecting the NSV to a Switch-Pros module. Can someone say more about the specific wiring modifications. Apparently, there is no wiring diagrams available, but since the Switch-Pros has trigger settings available then my initial thought was to just connect to 12v power and then tie in the desired NSV switch legs to a Switch-Pros switch.
  28. Sep 25, 2019 at 5:45 PM
    #58
    Lambeau
    Lambeau New Member
    2019 Black Tundra Platinum 4x4
    XP Package, 20” Rockstar, 295/60/R20 Nitto G2, Line-X Bedliner, Undercover Elite LX Tonneau Cover, Remote Start, NSV Hood Bulge Light Bar, Predator Running Boards, TacoTunes SQ1 Sound System, Toytec Boss front coilovers, Toytec Boss rear shocks, Coachbuilder +2 rear shackles
    Are the DRL’s supposed to dim with headlight low/off setting?
    When in auto and manual, my DRL switch will not turn off the DRL’s. Is this correct?
    Something is wrong because my lights (with DRL on) seem to be too bright to oncoming traffic at night. Trying to not get a ticket especially since I can’t turn the DRL’s off at night.
  29. Sep 28, 2019 at 8:33 AM
    #59
    X808
    X808 New Member
    I just PM'd you. Let me know if you can help out. Thanks!
  30. Sep 29, 2019 at 6:56 PM
    #60
    wire89
    wire89 New Member
