Bestop Trek Step or Amp Research Bedstep
Discussion in 'General Tundra Discussion' started by MatthewPTguy, Jun 13, 2018.
  1. Jun 13, 2018 at 6:57 PM
    MatthewPTguy
    MatthewPTguy [OP] Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Anyone have any experience with either of these products? They look similar in function... they both have 300 lb weight rating... both with 3 year / 36k mile warranty... the Trekstep is about $100 less... thoughts? Opinions?
  2. Jun 13, 2018 at 7:41 PM
    417Tundra
    417Tundra New Member
    Levi
    2013 platinum
    My truck came with the Amp step on it, I couldn't tell anything about the Bestop.
    Mine works great, comes down easy enough goes back up using just the tip of my shoe. Doesn't rattle or come down in bumpy situations. I weigh about 230 and it supports me just fine.
    MatthewPTguy[OP] likes this.
  3. Jun 13, 2018 at 11:47 PM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
    I bought a used Bestop for my brief '13 CM I had, did it's job, totally forgot to take off when I bought my used '14, looking to buy again
  4. Jun 14, 2018 at 3:10 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    One of the first things I did with my truck was get an Amp Bedstep and couldn't be happier. Install was easy and it does the job.
  5. Jun 14, 2018 at 6:53 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  6. Jun 14, 2018 at 1:46 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    0208140955.jpg 0208141321.jpg In my research between the two, I found Bestop's Trek Step is larger, works identically and is less money.
  7. Jun 14, 2018 at 8:44 PM
    MatthewPTguy
    Eugene, Oregon
    Thanks! Would you show a pic of it in the closed position? The YouTube video I saw on a Ford, it didn’t close flush with the bumper... thanks in advance!
  8. Jun 15, 2018 at 1:06 AM
    CMB
    CMB New Member
    Cecil County MD.
    There needs to be enough room to get a foot-hold on it to lower it. I have mine mounted off to the side enough to get my foot on it. Fitting flush would require using your hand every time and that's not what I was after.
  9. Jun 15, 2018 at 6:09 AM
    MatthewPTguy
    Eugene, Oregon
    Thanks!!
  10. Jun 15, 2018 at 6:24 AM
    15whtrd
    15whtrd Mr. Blonde
    So it’s not a fixed position that it has to be placed in? It’s adjustable? Any drilling required?
    TXRailRoadBandit73 likes this.
  11. Jun 15, 2018 at 8:53 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    does anyone have a write up on how to install one of these or pictures of install?
  12. Jun 15, 2018 at 10:59 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    Guys, the 14-18 has two different types of AMP Research steps, 75309-01A and 75316-01A, depending if you have resin or steel inner structure. I had the 75316-01A, and it suuuucked. Sorry AMP Research, but I hated it. The step comes out the side of the bumper, not the back of the bumper. I bought one and installed it then immediately uninstalled it. The step installs relatively easily, kind of clunky until you tighten everything up and torque it down, but the thing coming out the side was bogus. And the retract bangs into the bumper hard, no way to adjust that.
    When I got that one, I didn't see the other version available. So be warned!
    75309-01A installation: https://www.amp-research.com/?dl_id=321
    75316-01A installation: https://www.amp-research.com/?dl_id=363
    JoshuaA and buckeyeinlv like this.
  13. Jun 15, 2018 at 12:26 PM
    CMB
    CMB New Member
    Cecil County MD.
    The Bestop model is adjustable side to side and no drilling on my 2010.
    15whtrd[QUOTED] likes this.
  14. Jun 15, 2018 at 12:35 PM
    15whtrd
    15whtrd Mr. Blonde
    Thanks!
  15. Jun 15, 2018 at 11:15 PM
    MatthewPTguy
    Eugene, Oregon
    Crap... I ordered the bedstep 75316 from Amazon thinking it was the right part number... now I’m not sure... I looked under my truck and all I saw was steel... not sure how to tell about this resin / steel thing... but I just tried to cancel my order at Amazon... we’ll see if it worked... want to talk to someone at Amp Research on Monday and see if I can figure this out.
  16. Jun 16, 2018 at 1:57 AM
    CMB
    CMB New Member
    Cecil County MD.
    If you get on Bestop's website, they show a model # of 7530515 but they're saying it's Backordered.
  17. Jun 16, 2018 at 8:36 AM
    MatthewPTguy
    Eugene, Oregon
    I was too slow on the draw to cancel my order... so we’ll see what shows up on my doorstep tomorrow... hope it fits... :popcorn:
  18. Jun 16, 2018 at 8:41 AM
    Yeah no drilling bought a used one for my brief '13 I had direct bolt on, for got to take off when i traded for my '14, lookin to get another one
  19. Jun 25, 2018 at 3:09 PM
    MatthewPTguy
    Eugene, Oregon
    Ok... update on the Amp bedstep... just like @Tundradrenalin said, there are two parts numbers that fit 3rd gen Tundras. When I ordered from Amazon, I tried to order the 75309-01A and it said “Warning: this will not fit your Tundra”. And it suggested the 75316-01A... got that one in the mail... I installed it... and every time I folded the step up it slapped the bumper. I called Amp Research, and once he had my year, make and model, asked me if there was only metal under my truck or resin / plastic looking stuff? Mine was metal... he said “Send it back and get the 75309-01A” .... the one Amazon said wouldn’t fit. So I un-installed the wrong one, sent it back to Amazon. Ordered the 09-01A and just finished installing it. It fits and works perfectly. Nice fit and finish on the parts. There was no “forcing “ anything together. It retracts easily without slapping the bumper. I’ll post some pics of the process. Oh, and BTW, the 16-01A comes off the SIDE of the rear bumper, whereas the 09-01A comes off the rear of the bumper.
  20. Jun 25, 2018 at 3:11 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  21. Jun 25, 2018 at 3:31 PM
    MatthewPTguy
    Eugene, Oregon
    The directions that came with the step are pretty good, but here is the process anyway... 300A2090-D007-4EDE-89A4-E9FE9F4D650B.jpg
    If you look under your truck where the step will mount and you see this... all metal, no resin / plastic you will need the 75309-01A.
    Take off bumper trim
    Pop up the rest of the bumper trim by following the directions...
    Still more stuff to remove
    The above pic is a wrench on one of the bolts you have to remove in order to get the bumper bracket off and the you replace it with the Amp supplied one.
    The above pic shows bumper bracket removed and ready for the Amp one.
    Above pic is Amp bracket.
    The above pic is with ste step in place just before I torqued everything up. See the long, thin bracket top right of the pic? The directions don’t tell you to remove that, but I did (only two bolts) and it made torquing the frame bolts that hold the step on A LOT easier to tighten. Then just re-install.
  22. Dec 3, 2018 at 10:56 AM
    AZTundra
    Paul
    Phoenix, AZ
    @Tundradrenalin - Did you end up switching from the AMP Bed Step 75316-01A to the 75309-01A? I have a 2017 Crew Max and just installed the 75316-01A and just like you said it sucks. It seems to hit the side of the truck when tucked in and no room for adjustment. I'm wanting to take it off and get the other one if that worked for you. Will the other model fit the 2017? Thanks!
  23. Dec 5, 2018 at 12:48 PM
    Tundradrenalin
    Virginia Beach, VA
    I never got the other version. MatthewPTguy put one on his 2017 in the photos above.
  24. Jan 9, 2019 at 9:31 PM
    TundraPro2019
    TundraPro2019 New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Well, I can confirm through experience that the AMP bedstep model 75309-01A works fine on the 2019 TRD Pro! The instructions and pictures from MatthewPTGuy are spot on, especially this comment from him:
    > The above pic is with the step in place just before I torqued everything up. See the long, thin bracket top right of the pic?
    Definitely do that.
    Three more tips to make the install a bit easier.
    1) The instructions say to remove the corner bumper cap. Yes, you need to do that. What it doesn't say is that there are two fasteners you need to squeeze the tabs inwards from the underside. Don't just pry the cap up with a screwdriver.
    2) The instructions also say to remove the whole rear bumper cap. That is a royal pain. Lots more of those pesky fasteners to squeeze from under the car. I took a short cut, and did just enough of them so I could lift up the bumper cap and stick a 12mm ratchet wrench under it. See below picture.
    3) Getting the stock bumper bracket actually out, after you have removed the three bolts, isn't easy. It is a really tight fit. I only managed by removing a fourth bolt, so that I could move the metal bumper frame just enough to get the bracket out. The extra bolt I removed is the one circled in red. This picture was taken after I put the replacement bracket in, show with the red arrow.
    Hope that helps!
  25. Jun 14, 2019 at 8:08 PM
    2chains
    2chains New Member
    Southern Ablerta
    Thanks for the great pics guys! Can the step be adjusted so it aligns better with the bumper?
  26. Jun 15, 2019 at 2:14 AM
    CMB
    CMB New Member
    Cecil County MD.
    I've adjusted mine several times due to my Chronic OCD:D I wanted it to be far enough 'off-side', to be easily reached with my foot, instead of having to use a hand to bring it down. Where it is now, is just about the sweet-spot for accessibility, function and appearance.
  27. Jun 15, 2019 at 5:47 AM
    2chains
    2chains New Member
    Southern Ablerta
    Good info. Thanks for the additional pics!
  28. Dec 22, 2019 at 10:27 AM
    RangerBP
    RangerBP SC Expat
    2017 4x4 DC, Silver Sky
    Does anyone have experience mounting the Bestop Trekstep with an aftermarket rear bumper?
    I looked at the instructions and it seems like the mounts are to the tow hitch and all of the other stuff done to the stock bumper is making room for the step unit.
    Can anyone confirm?
  29. Dec 22, 2019 at 10:33 AM
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    You are correct. I just installed the Rough County rear bumper and the amp step fits perfect underneath. If you were to install the Rough County bumper first then the install of the step is trivial. Just use two existing bolts into the frame. Way easier than dealing with the stock bumper.
    RangerBP likes this.
  30. Dec 22, 2019 at 10:35 AM
    RangerBP
    RangerBP SC Expat
    Thank you, sir.
    TundraPro2019[QUOTED] likes this.
