TRD coil-over swap out
Discussion in 'Suspension' started by Black Wolf, Apr 8, 2015.
  1. Apr 8, 2015 at 7:58 AM
    Black Wolf [OP] Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I am going to be swapping out my stock front and rear KYB shock/coil-overset up with TRD pull offs on my 07 SR5. I noticed that the TRD coil-overs have a blue painted dot marking on one coil and the other assembly has a yellow paint dot on the coil. Does anyone know if this have any significance? Left or Right markings maybe?
  2. Apr 8, 2015 at 9:56 AM
    Aurora CO
    I think I just answered my own question. My stock coil-over on the right is marked with yellow and left is marked blue. Still not sure if it makes any difference.
  3. Apr 8, 2015 at 2:15 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That solves that!
    Black Wolf[OP] likes this.
  4. Apr 8, 2015 at 3:21 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    There was a guy on another forum who actually measured the thickness of the coils and found out that they are of different thickness. If I remember correctly it was the driver's side that was thicker.
    Black Wolf[OP] and MotoTundra like this.
  5. Apr 8, 2015 at 5:55 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Interesting.
    tat2ude39 and Black Wolf[OP] like this.
  6. Apr 9, 2015 at 7:44 AM
    Aurora CO
    Good info. I am going to do the front swap out Sat. Going to measure coil thickness just out of curiosity. Replaced rear shocks yesterday. KYB's were toast. Kinda sucked trying to compress the Bilsteins with one hand and the other hand trying to align bolt, bolt hole, shock at the same time. Tried plastic ties to maintain compression but kept snapping. Oh well.
  7. Apr 9, 2015 at 9:25 AM
    U can rent a compressor at Auto Zone I believe.
    tat2ude39 likes this.
  8. Apr 9, 2015 at 9:33 AM
    Aurora CO
    My neighbor is a mechanic by trade. He is going to help with the install. So in theory it should go well. Who is your alignment guy?
  9. Apr 9, 2015 at 2:08 PM
    Jace at Stevinson Toyota West. Call to schedule it with him and I'll let him know you're a fellow forum member.
  10. Apr 9, 2015 at 5:27 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    At least on the first Gen there are left and right struts....If the ones you have are already off a vehicle, simply match the color to the right side or you will have a droopy side in the extreme. On some of the struts (4-runner and such) the spring seat is actually placed higher on one side than it is on the other.
  11. Apr 10, 2015 at 8:15 AM
    Aurora CO
    Thats good info. The spring seats are positioned slightly different. Enough to make a difference if installed on the wrong side. Thanks.
  12. Apr 14, 2015 at 10:49 AM
    Aurora CO
    Got the swap done Saturday. Took two of us about 3 hours to complete. Rides nice, except the change over caused the yaw/pitch sensor to go nuts. (VSC, 4Hi, flashing and ABS light on solid.) Tried the paper clip method to no avail. Could do the shim thing but maybe just go to the stealership and get it over with.
  13. Apr 14, 2015 at 11:04 AM
    The dealership route will cost around $100...I did the paper clip and dealer mod. Be sure to bring in the papers showing them what they have to do otherwise they'll have no clue what you're talking about...
    Bring it into Jace at Stevinson.
  14. Apr 14, 2015 at 11:10 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I had no issues at all with my lift. Weird. Yea, if you can figure it out the dealership should be able to reset.
  15. Apr 14, 2015 at 12:03 PM
    Aurora CO
    I got a copy of the TSB for zero point cal. Should take a couple minutes for the dealer to reset. It is weird. Already had a pro comp spacer on the stock coil-overs. New coil-overs were the same length with the spacer pre-install, but the truck gained about one inch more in height in the front after install. The extra inch probably tripped up the sensor. Just my luck.
  16. Apr 17, 2015 at 6:21 PM
    Aurora CO
    Turns out my problem was a bad speed sensor cable. Sensor ohmed out good. Harness continuity was open. Replaced harness and all flashing light craziness went away. Go figure.
    Black@Blue19 likes this.
  17. Apr 17, 2015 at 10:39 PM
    csuviper
    Broomfield, CO
    Well that's good the found and fixed the problem. Wonder if it was pulled on too hard or something during the lift install.
  18. Apr 18, 2015 at 2:52 PM
    Aurora CO
    I recall that the driver side sensor harness was pretty taut even with hold down brackets removed. Should have completely disconnected harness. Victim of the dreaded "I forgot the last step" virus.
  19. Jun 15, 2019 at 12:20 AM
    jtaco11
    jtaco11 New Member
    Blue is driver side. BD for ez memory
  20. Apr 18, 2020 at 11:31 AM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Leaving this here for reference as well. The springs on the left were from the drivers side and right are from the passenger. These are OEM coils.
    Ted4311 likes this.
  21. Apr 18, 2020 at 7:03 PM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    Toyota factory driver's side springs are roughly a half inch taller (longer) than the passenger side springs.
