50statesoverland - 2018 SR5 Cement CM Overland Build
Discussion in '2.5 Gen Builds (2014-2021)' started by itsdchz, Feb 14, 2018.
  1. Apr 13, 2019 at 5:18 AM
    #91
    itsdchz
    itsdchz [OP] 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Adding a couple aftermarket head unit pics
    AVIC 8400 NEX
    ********* speakers
    ********* 5 channel amp
    Tech12volts dash speakers w/ center
    joonbug, Watt maker and Berdine like this.
  2. Apr 22, 2019 at 12:08 PM
    #92
    Lukester
    Lukester New Member
    SF Bay Area
    Loving your build. Is your max modular rack 46" or 58"? I am trying to decided which one I want to go with.
  3. Apr 22, 2019 at 12:48 PM
    #93
    itsdchz
    Clovis, CA
    Thank you!
    46”
    58” takes up the entire bed. I wanted a little room to adjust as needed.
  4. May 6, 2019 at 5:14 AM
    #94
    itsdchz
    Clovis, CA
    A few of the Method MR312 rims:
    TRDblvd, Navi, khens12 and 1 other person like this.
  5. May 6, 2019 at 5:49 AM
    #95
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    You're killin' me!:)
    itsdchz[OP] likes this.
  6. May 6, 2019 at 6:51 AM
    #96
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    What Tundra bed inserts are those? They look really good on the cement. The rest of the build is awesome too.
  7. May 6, 2019 at 7:21 AM
    #97
    itsdchz
    Clovis, CA
    Bed inserts?
    Do you mean the black lettering inserts on tailgate? They are OEM. Let me know if this is what you are asking. Sorry.
  8. May 6, 2019 at 9:57 AM
    #98
    redryder
    redryder New Member
    Ryder
    Louisiana
    Yes thanks. I couldn't remember what they were called. I didn't know they had those OEM
    itsdchz[QUOTED][OP] likes this.
  9. May 12, 2019 at 9:11 PM
    #99
    khens12
    khens12 New Member
    Kevin
    2018 Tundra SR5 Off-Road 4x4
    - Icon Billet UCA - King 2.5 Coilovers - King 2.0 “Shorty” Bumpstops
    How are you liking the MR312? Do you have any rubbing in the front? I’m running 295/70r18 and looking at this wheel (+18) and curious if I’m gonna run into excessive rubbing. Currently have a 1-1/4” spacer in the front and rub slightly in reverse on full lock but it’s not an issue for me. I think the added .25” might give me some issues.
  10. May 12, 2019 at 9:52 PM
    #100
    itsdchz
    Clovis, CA
    I have less rubbing with this wheel than the +18mm SCS I was running before! I have wheel spacers as well, 295/70/17. You’ll have the same or less with this wheel!
    khens12[QUOTED] likes this.
  11. May 12, 2019 at 9:57 PM
    #101
    khens12
    khens12 New Member
    Kevin
    Right on. I was looking at +25 in the NV which would only change offset by a 1/10” on paper but method only has a Few options in the +25 offset.
    Thanks for the input!
  12. Jun 13, 2019 at 5:14 PM
    #102
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    @itsdchz , how’s the rear expansion pack holding up. Has the rear maintained it’s lift? I looking strongly at Stage 3 and adding the UCAs or possibly just getting the Stage 5, but I’ve read some people saying the expansion pack goes flat in a relatively short amount of time.
    Rica25 likes this.
  13. Jun 13, 2019 at 7:17 PM
    #103
    itsdchz
    Clovis, CA
    I haven’t noticed any flatness, but I use sumo springs which helps the stress from towing. I have 8000 miles of towing on the truck, and 30,000 on the springs... seems to hold up well.
    Rica25 likes this.
  14. Jun 13, 2019 at 7:21 PM
    #104
    Rica25
    Ricardo
    Tulare
    Never have seen your truck around yet but would love to see it and we only one hour away from each other some day I might see you on the road
  15. Jun 13, 2019 at 7:23 PM
    #105
    itsdchz
    Clovis, CA
    We are doing a run in the 23rd to buck rock in sequoia.... you should come out
    Rica25[QUOTED] likes this.
  16. Jun 13, 2019 at 7:38 PM
    #106
    Rica25
    Ricardo
    Tulare
    Wifes bday June 23rd
  17. Jun 13, 2019 at 7:41 PM
    #107
    Rica25
    Ricardo
    Tulare
    Thanks for the invite though
  18. Oct 22, 2019 at 7:15 PM
    #108
    Vito_96
    Vito_96 New Member
    love this build...keep up the amazing work
    Rica25 likes this.
  19. Oct 22, 2019 at 7:26 PM
    #109
    itsdchz
    Clovis, CA
    Thank you! I need to post updated pics!
    Rica25 likes this.
  20. Nov 1, 2019 at 8:31 PM
    #110
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    With your current suspension setup and the size of the tires, dis it provide enough ground clearance for you? I keep going back and forth over 33 or 35 inch tires but might stick with a 33 cuz there’s narrow tires in that size, no skinny tires on a size 35.
    Rica25 and itsdchz[OP] like this.
  21. Nov 1, 2019 at 8:48 PM
    #111
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    Love it, looks awesome!
  22. Nov 1, 2019 at 8:50 PM
    #112
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    About the only skinny 35 I know of is 285/75R18.
    Rica25 and Samoan Thor[QUOTED] like this.
  23. Nov 1, 2019 at 9:05 PM
    #113
    itsdchz
    Clovis, CA
    These are 35x12.5x17
    the ground clearance and clearance from suspension has a great amount of tolerance.
    No rubbing on suspension or Cab Mounts since being chopped long ago.
    Thank you for the props!
    Rica25 and Samoan Thor like this.
  24. Nov 1, 2019 at 9:06 PM
    #114
    Samoan Thor
    TheBeast and Rica25 like this.
  25. Nov 2, 2019 at 5:10 AM
    #115
    itsdchz
    Clovis, CA
    Thank you!
    Rica25 likes this.
  26. Jul 4, 2020 at 5:05 PM
    #116
    Jonnynewton909
    Jonnynewton909 New Member
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC rear. 37 Toyo RT Trails on Method 312s
    BUMP this awesome build!
    Just wondering if you are still running the 1.25 Spidertrax with the current setup? If so I'm assuming you're running them front and rear?
    Were they needed to clear your setup or were they added more for stance?
  27. Jul 4, 2020 at 6:07 PM
    #117
    itsdchz
    Clovis, CA
    Running them front and rear up until a little while ago. Removed the fronts for better clearance with the 35” tires and offset of the 17” rims. It touches the inside fender, even with a lot of trimming. Less aggressive tires wouldn’t, but the MT’s do. Thank you for the kind words!
  28. Sep 9, 2020 at 5:44 PM
    #118
    RBB
    RBB Member
    Vancouver Island B.C. Canada
    Barcelona Red Mettalic 2020 Tundra TRD off road
    Blackout badges, tailgate insert, sill protectors
    I absolutely LOVE this build!! You nailed it man.
  29. Sep 10, 2020 at 3:17 PM
    #119
    RBB
    RBB Member
    Which model Voodoo rack did you put on your truck? There seems to be alot to choose and I like how yours fits. Thanks
  30. Sep 10, 2020 at 3:30 PM
    #120
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
