Need Power Folding Tow Mirrors
Discussion in 'Towing & Hauling' started by PlatPro, Jan 18, 2017.
  1. Jan 30, 2018 at 6:56 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    That's exactly right. Power fold, heated, power adjustment, and turn signals will work. BSM and puddle lights aren't there, the memory feature will not work, and the mirror does not auto dim. You could tap into something to make the marker light work, it's just not plug and play.
  2. Jan 30, 2018 at 7:51 AM
    Sigbrown1297
    Sigbrown1297 New Member
    2018 Tundra Platinum
    Thanks for the info. I actually got my Tundra from Cool Springs Toyota.
    Gotta do some research to see what I can tap into to make the marker lights work.
    I
    Roman[QUOTED] likes this.
  3. Jan 30, 2018 at 8:02 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Whew, I had no idea how expensive mirrors could be. Seems like you could just mount some rear facing cameras and put screens on there for that much.
    Roman likes this.
  4. Apr 15, 2018 at 7:10 AM
    FossilHunter
    FossilHunter New Member
    2017 Tundra TRD 4x4 Double Cab
    I have an SR5 with no power folding. I would like to get towing mirrors that can do all the functionality as I have currently. I have found OEM but none with the BSM function?
  5. Apr 16, 2018 at 11:37 AM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
  6. Apr 16, 2018 at 12:31 PM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    @Roman I have a 2018 SR5 TRD off Road CM. Would the OEM folding tow mirrors work with my truck? Do they fold when you kill the truck or do you have to manually fold?
  7. Apr 16, 2018 at 12:32 PM
    Roman
    Roman
    Franklin, TN
    They will plug up and work if you have the power folding function now. If you do not, you will need to wire that function up. They close from a button on the mirror switch.
  8. Apr 16, 2018 at 12:34 PM
    jaredmillerdvm
    Anderson, SC
    Ok thanks. I don’t have that option guess a no go for me! Thanks again!
  9. Apr 16, 2018 at 2:19 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Any of you guys with spare Power folding standard (non towing) mirrors hit me up if you are looking to sell. Looking to upgrade my SR5 and I'm capable of the wiring.
    Thanks!
  10. Apr 16, 2018 at 7:39 PM
    FossilHunter
  11. Apr 16, 2018 at 7:44 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    ScottD and Roman like this.
  12. Apr 16, 2018 at 7:52 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    :muscleflexing::muscleflexing::muscleflexing:
    GNTundra likes this.
  13. Apr 16, 2018 at 7:54 PM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Have you ever sat in the driver seat of a tundra with tow mirrors? Make sure you try them out before you buy if at all possible. I wasn't particularly thrilled with them. Theres actually less mirror. To me, the visibility is way better with the regular mirrors (except the blind spot mirror is nice for backing into parking spaces).
    Just a thought.
    mrballcb likes this.
  14. Apr 21, 2018 at 11:46 AM
    Tundra15
    Tundra15 New Member
    Roman I ordered these and when I went to have them installed they said the didn't have folder motors in them? When I push on them they did seem to move fairly easy? Can you help me here?
  15. Apr 23, 2018 at 10:19 AM
    Roman
    Roman
    Franklin, TN
    What's your order number? I'll look them up and confirm. You should have ordered 87940-0C281 and 87910-0C281 for the power folding tow mirrors.
  16. Apr 23, 2018 at 1:19 PM
    Tundra15
    Tundra15 New Member
    Custom no. 149968 invoice 541722
  17. Apr 23, 2018 at 1:21 PM
    Roman
    Roman
    Franklin, TN
    Yep, you ordered the correct ones. Double check the numbers on the boxes sent to you to make sure they match, but those are correct for power folding tow mirrors.
  18. May 21, 2018 at 8:58 AM
    mkmarz
    mkmarz New Member
    Any good aftermarket solution for some power folding tow mirrors?
  19. Mar 22, 2019 at 8:10 AM
    Jrharvey02
    Jrharvey02 New Member
    Are you 100% positive the DRL (amber side markers) won’t work on the platinum 2nd gen.? How do you know this?
    Edit: they don’t, had to run a wire to the harness to power drl running lights on the side of the mirrors, couple hour job...
  20. May 20, 2019 at 3:57 PM
    #50
    ScottD
    ScottD New Member
    08 Seq Ltd
    Hi Roman, will these (87940-0C281 and 87910-0C281) work for an 08 Sequoia Ltd that has power fold, heated, power adjustment, and turn signals? Thank you in advance.
    Where on the harness did you end up running it to?
  21. May 21, 2019 at 7:40 AM
    #51
    Roman
    Roman
    Franklin, TN
    Maybe? I honestly do not know. I've never had anyone attempt this swap. There are some mirrors that are shared between the Sequoia and the Tundra.
  22. May 21, 2019 at 11:46 AM
    #52
    ScottD
    ScottD New Member
    08 Seq Ltd
    Thanks for the fast response. I reason that it should since PN 879400C203, which is my current drivers mirror is shared with the Tundra.
    Are there comparable towing mirrors to the ones listed above that also have auto dimming?
  23. May 21, 2019 at 12:49 PM
    #53
    Roman
    Roman
    Franklin, TN
    Not that I have seen. I don't believe even the aftermarket tow mirrors have auto dimming as a feature.
  24. May 27, 2019 at 2:38 PM
    #54
    Jrharvey02
    Here’s the build thread, it ended up being the only wire missing from the entire harness. https://www.tundras.com/threads/diy...o-oem-toyota-power-folding-tow-mirrors.42865/
  25. May 31, 2019 at 10:14 AM
    #55
    ScottD
    ScottD New Member
    08 Seq Ltd
    Roman, do you know if these are also offered in chrome, and would you be able to find the part numbers?
  26. May 31, 2019 at 10:32 AM
    #56
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    I've got a set if anyone is interested. Send me a PM.
  27. May 31, 2019 at 1:56 PM
    #57
    Roman
    Roman
    Franklin, TN
    The tow mirrors are not offered in chrome.
    Beesta likes this.
  28. Jun 10, 2019 at 6:55 PM
    #58
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Its me again Roman, what is the possibility on my 2019 Pro that when i purchased the OEM power folding tow mirrors and replace the switch with the one with the fold button that it will all works without any special wiring..? Wishful thinking .... and also how how about blinkers ... does that also have to be wired up separately...? Sorry it seems im asking you too much .... Thanks
  29. Jun 11, 2019 at 11:19 AM
    #59
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
  30. Jun 19, 2019 at 2:32 PM
    #60
    ScottD
    ScottD New Member
    08 Seq Ltd
    Roman, Thank you for providing the picture. From a thread on tundratalk.net, a member posted this:
    "After doing a bunch of research on the wiring diagram, I was able to put together the wiring for the mirrors and figure out how many pins/wires I’d need to install all of the necessary functions. Here is the layout of the wires for the 2014 DC SR5 (does NOT match 2008 Sequoia LTD):
    Pin 1: Heat +
    Pin 2: Heat –
    Pin 3: Signal – (Running Light -)
    Pin 4: Signal +
    Pin 5: Puddle Lamp – (Already wired as common ground, needs rewire to make puddle lamps work)
    Pin 6: Puddle Lamp +
    Pin 7: Mirror Retract (+)
    Pin 8: Mirror Fold (–)
    Pin 9: Running Light +
    Pin 10: Mirror Vert (power)
    Pin 11: Mirror +
    Pin 12: Mirror Horiz (power)
    Pin 13: Auto-Dim –
    Pin 14: Auto-Dim +
    Pin 15-18: Memory Pins .. since I don’t have this, I didn’t research the actual pins, just know that these 4 are reserved for that."
    My next question is this: Are there power folding tow mirrors that also have the auto-dimming feature?
