Easy 5 min anytime fog light relay mod DIY
Discussion in 'Lighting' started by xtyfighterx, Jan 16, 2018.
  1. Jan 3, 2019 at 4:54 PM
    #151
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Thank you again.
    OBXTundra likes this.
  2. Jan 3, 2019 at 5:03 PM
    #152
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Nice write-up. I don't have any empty switch locations..... may have to get creative with that.
  3. Jan 4, 2019 at 8:23 AM
    #153
    SweetWaterSurprise
    SweetWaterSurprise New Member
    NJ
    Platinum
    Same here. I have a Platinum and no blanks available.
    ldale[QUOTED] likes this.
  4. Jan 9, 2019 at 1:47 PM
    #154
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    I connected the fog ground (bent out) to headlight relay ground via epa4wd's method. Works as stated above. Wondering if I connect the fog ground to headlight ground like before, but instead not bend the fog ground out and allow it to plug back into the housing. Will I be able to control fog with parking lights and still get benefits of fogs/brights with headlights on?
    Tundra18ttags, TRON and Norfolk757 like this.
  5. Jan 10, 2019 at 3:27 PM
    #155
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Is there a way to make the stock on and off switch to work on a platinum?
    Norfolk757 likes this.
  6. Jan 10, 2019 at 3:44 PM
    #156
    Norfolk757
    Tom
    Norfolk, VA
    That would be ideal even with the just the parking lights.
  7. Feb 3, 2019 at 8:13 AM
    #157
    HomeDetective
    HomeDetective New Member
    Brent
    2014 DC Limited
    Too bad the fog lights don’t work with lights in Auto position. I never change mine out of the Auto position so I’ll have to try something else.
  8. Feb 3, 2019 at 11:48 AM
    #158
    bb_stance
    bb_stance New Member
    I have the 2018 headlights installed on my ‘15 platinum and did this anytime fog mod. Ive experienced that my DRLs were brighter when they were on auto mode (during the day with headlights off) vs when in parking lights only mode. Now that I’ve done the anytime mod, since the DRLs no longer are on when in auto mode, the DRLs are not as bright when I’m in parking lights only mode. I love the look of DRLs and fog both on at same time, but is it normal that my DRLs are not as bright when in parking lights only mode?
    payyourtoll likes this.
  9. Feb 3, 2019 at 12:44 PM
    #159
    bb_stance
    Solved! Sorry for clogging up the thread. In parking lights mode, DRLs are dimmed when parking brake is engaged. Once parking brake is released, DRLs go bright. Thank you @BlueBottle for the dim/brightness explanation! And thank you @xtyfighterx for the anytime fog mode write up - love it!
    xtyfighterx[OP] likes this.
  10. Feb 4, 2019 at 8:32 PM
    #160
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    For reference 2016 Tundra, once this mod is complete I understand the fog light switch no longer works but does that mean even when you switch it on, the positive wire does not get a signal/power at all?? @xtyfighterx
  11. Feb 26, 2019 at 1:47 PM
    #161
    jtdunc
    jtdunc New Member
    2014 Tundra Double Cab - Magnetic Gray
    Has anyone done this with a 3rd gen Tundra like my 2014?
    Any other tips @OBXTundra as I'm not certain what is connected to what.
  12. Jun 6, 2019 at 10:15 AM
    #162
    ccress83
    ccress83 Be A Good Human
    Colin
    Cleveland Ohio
    2011 Tundra CM TRD Off-Road Limited
    AFE Dry Drop in Filter, Morimoto XB LED Fogs , LED Taillights, Morimoto D2S retro w/profile HI-Lens LED Brights, 3/1 LRO Level, Dirty Deeds 8', TRD Rear Sway Bar,
    Exactly what I did but I didnt bend the tab, just made little jumpers.
  13. Jul 12, 2019 at 8:33 AM
    #163
    tundraoverland1
    tundraoverland1 New Member
    Las Vegas
    2015 White Tundra crewmax TRD 4x4
    IG: sfarrisjr88
    What guage wire did you use to make the little jumper/ground?
  14. Jul 12, 2019 at 2:28 PM
    #164
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    16g I think doesn’t have to be crazy
  15. Jul 18, 2019 at 5:12 AM
    #165
    tapeworm
    tapeworm New Member
    Aaron
    2019 Cement Grey Tundra SR5
    3.5" Rough Country Lift Fuel Cleaver wheels
    Does anyone have a pic of this so I can do it on my 2019?
  16. Jul 18, 2019 at 2:17 PM
    #166
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    @Ikonrat did his, not sure of the outcome
  17. Jul 18, 2019 at 2:24 PM
    #167
    Berdine
    Frank
    Binghamton, NY
  18. Jul 19, 2019 at 4:15 AM
    #168
    tapeworm
    tapeworm New Member
    Aaron
    Berdine[QUOTED] likes this.
  19. Jul 28, 2019 at 1:09 PM
    #169
    XDevilboiX
    XDevilboiX New Member
    2019 Tundra Limited TRD Off Road Silver
    Hi guys, just got my 2019 Limited CM Off road 2 days ago and been reading on how to get fogs on with drl and low beam with auto set. I traded my 2010 Tacoma in and had fogs on anytime and want the same thing with the Tundra.
    Thanks to OP for the original post. I played around with it and got it working with auto set and fogs on. Even when parking and low beam comes on, the fog stays on except for high beam. I’m happy with this as I rarely use high beam.
    What I did was connect the ground from the fog relay to the ground of the drl relay directly with a 16g wire. And that’s all it took.
    BBTundra, PhearCVBz, 100LL and 3 others like this.
  20. Sep 10, 2019 at 11:22 PM
    #170
    SicSS
    SicSS New Member
    Houston, Texas
    2012 Grey Tundra Crewcab
    Pro Comp 6 inch lift/Fuel Forged 20X12 wheels W/35's/ARE hard tonneau cover/AMP Research Auto running boards/TRD Exhaust/LED Fogs/LED Headlights
    I wonder if that would work on a 2015 Limited?
    I bought the girlfriend a Sequoia, and she wants her fog lights to stay on like mine (all the time), but she has the auto lights, and I do not.
    Just to verify, you jumped from the terminal closest to the front of the truck on both relays?
    Seeing if you have a pic of which ones you used?
    TIA.
  21. Sep 11, 2019 at 5:42 AM
    #171
    XDevilboiX
    Yes it’s the terminal closest to the front. Look at your cover for where the relay for fogs and DRL is. I’m not sure if your model year is the same.
  22. Sep 12, 2019 at 12:00 PM
    #172
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    didn't know about this mod.
    Thank you OP will try it this weekend.
  23. Nov 12, 2019 at 1:12 PM
    #173
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    thinking of doing this to my 16 DC SR5...any problems come by ever since doing this mod?
  24. Nov 30, 2019 at 7:04 PM
    #174
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    NewImprovedRon and Skew12 like this.
  25. Dec 2, 2019 at 7:30 AM
    #175
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Yes you can
    NewImprovedRon likes this.
  26. Dec 7, 2019 at 8:09 PM
    #176
    MAN N BLK
    MAN N BLK New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    Funny story. So I haven’t been able to do much of any mods to my Tundra yet and tonight I thought this would be a quick easy one. Found connector already on wire from a set of lights from who knows when. Cut wire to length and got everything all hooked up and put fuse/relay cover back on. Time to test...Drum roll...... started truck and flipped on parking lights. One of my damn fog lights was out. Seriously. Gave it a gentle tap and it came on. Smh
  27. Dec 10, 2019 at 5:52 AM
    #177
    ccress83
    Colin
    Cleveland Ohio
    Shite, this is even better then my method if it works for my 2011. So foglights will be on all the time no matter if on auto or off but turn off for brights? I have DRL brights on my retrofit I did, so ive been trying to figure out when headlights are on DRL brights turn off and when headlights are auto/off/parking they turn on. Pretty much how the drl on the turn signals get brighter and dim when headlights turn on and off. Trying to alternate my headlights and DRL brights. If any of that makes sense.
  28. Dec 10, 2019 at 12:25 PM
    #178
    Cobshop
    Cobshop New Member
    Idk If the previous owner did this but my 2019 has the fogs on all the time.
  29. Dec 16, 2019 at 7:19 AM
    #179
    tglyder
    tglyder New Member
    Salt Lake City
    Silver 2010
    Nice DIY mod but , I like all my accessory lights switchable. If it's foggy, I'll flip a switch. If I need more light to back up, I'll flip a switch. If I want all the red and blue lights on, I'll punch it through a school zone...
  30. Dec 16, 2019 at 8:47 AM
    #180
    LosGixxer1000
    LosGixxer1000 New Member
    Carlos
    2013 Toyota Tundra Crewmax Platinum
    Custom LED lights underneath running boards fabricated and installed. LED Headlights HI, Low, Fog Four Train horns with complete compressor and solenoid kit with custom made switches for compressor on / off and horn disarm. Electric ahooga horn. Spare air fill up chuck off of train horn air tank. Installed and fabricated by me.
    Awesome directions! Spot on!!!! Thank you. If you do not want to bend the prong on the relay you could do what I did instead. This way you can eliminate the mod without damaging the relay using just four jumper wires, four female connectors, three male connectors, and one loop connector for the ground. Cut a tiny notch on the edge of the relay/fuse box for the wire to come out of from under the cover and you have a clean install. The relay fits beautifully in that little spot.15765137721534975742119034170544.jpg 15765142861499094933446745526401.jpg
