Has anyone got 295 55 20 on stock wheels
Discussion in 'Wheels & Tires' started by cquilichini, Feb 12, 2019.
  1. Feb 20, 2019 at 9:21 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    A shim is only 1/4 for 1/2”. Not 1.5-2” like a leveling spacer. Big difference.
  2. Feb 20, 2019 at 10:07 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    We have the same truck. Here is before 285/65/r20 to compare with the photos above. You may have a flare clearance issue even with a 3" lift as I had to pull the factory flaps.
    French Avocado likes this.
  3. Feb 20, 2019 at 10:13 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    The alignment is now within factory spec but pushing the adjustment limits. 4WP got it right in and fixed it up. Drives pretty much stock. Can definitely feel the Bilsteins on the rear. I am looking at other options.
  4. Feb 20, 2019 at 10:30 AM
    Danman34
    Danman34 New Member
    Danny
    What’s the sheet look like. You can’t align a lifted tundra using factory specs. What’s wrong with the bilsteins on the rear? My 5100s were a nice improvement over the TRD red bilsteins that came on the truck
  5. Feb 20, 2019 at 12:52 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    The tires are aligned to within factory specs for castor and camber. The sheet has green bars instead of red ones. :D
    Nothing is wrong with the 5100s. I can feel the difference with them on the back. :dancingbacon:
  6. Feb 20, 2019 at 12:58 PM
    Danman34
    Danman34 New Member
    Danny
    Toyota’s allowances are very broad. I too had my truck aligned and everything was in the green. However I knew it wasn’t right with camber at .6 and .7 and castor at 2. I brought it to a real chassis and suspension shop and they confirmed that my alignment was jacked up. The truck now drives and tracks better than it did stock. Being in the green doesn’t mean anything if they are using Toyota factory specs.
    deptrai likes this.
  7. Feb 20, 2019 at 1:00 PM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    I’ve got some 20x10 wheels and 295/55/20 is what discount tire told me that’s the largest I could go without rubbing. So idk, i would like to know what what fits.
    KELZ84 likes this.
  8. Feb 20, 2019 at 4:32 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    @ShreveportTSS so you have the 285/65/20 in those pics? That’s the tire size I’m planning to go with...so you removed the flaps and what else? I have Bilsteins 2.5” setting front nothing in rear with 285/55/20 now.
  9. Feb 20, 2019 at 5:05 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    :popcorn:
  10. Feb 20, 2019 at 5:49 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Yes (below), 3-1 lift (spacers), I initially removed both, front wheel well "spats" and splash guards. I put the splash guards back on this afternoon and drove it with no contact but it's close. Shown with tire turned left at closest point.
    Pics with nerf bars are stock 285/55/r20.
    Okietundra and KELZ84[QUOTED] like this.
  11. Feb 20, 2019 at 6:03 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @ShreveportTSS nice...I’m pretty sure they should fit mine. I dont see why not. It’s a close fit with the flaps but still some finger space haha. Thanks! Also could you share more photos of full truck with those tires and side views?
  12. Feb 20, 2019 at 6:21 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    You prefer the bilsteins Over the TRD shocks?
  13. Feb 21, 2019 at 4:33 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I have the TSS (Toyota Sport Series) It came with the regular SR5 shocks not the TRD Bilsteins. I may end up with the TRD Bilsteins on front.
  14. Feb 24, 2019 at 10:22 AM
    cquilichini
    cquilichini [OP] New Member
    Well I finally bit the bullet. My SR with blacked out Limited 20” rims and 295 55/20 Ridge Grapplers. No rub at full lock.
    Mr_Kane, jeller75, TRDblvd and 7 others like this.
  15. Feb 24, 2019 at 10:27 AM
    Okietundra
    Okietundra New Member
    OKC OK
    2015 Silver Sky CM TRD OFF ROAD
    Oh...she's dirty! Nice
  16. Feb 24, 2019 at 10:32 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Man that looks good. That’s the kinda pain you want to feel bro. Hahaha
    cquilichini[OP] likes this.
  17. Feb 25, 2019 at 6:38 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice! Any lift? Or wheel spacers?
  18. Feb 26, 2019 at 4:41 AM
    cquilichini
    Stock SR Suspension, no lift or spacers. 20" Limited Stock Rims and 295/55R20 Nitto Ridge Grapplers
    serbiansizzle and Big J[QUOTED] like this.
  19. Mar 4, 2019 at 6:46 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Bout to get some Cooper stt pros in 295/55/20 but I’m looking for a rwl. I guess they don’t like making white letters anymore.
  20. Jun 1, 2019 at 2:42 PM
    #50
    FPSCorvette
    FPSCorvette Texas Proud
    Justin
    Amarillo, Texas
    2014 Tundra TSS
    You get those coopers?
  21. Jun 2, 2019 at 4:24 AM
    #51
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    I didn’t man. I settled on some radar renegades all terrains.
  22. Jul 2, 2019 at 10:33 AM
    #52
    dbuckman
    dbuckman New Member
    2019 Black Tundra TRD Sport
    2" level
    Did you have any leveling done, if so what did you do?
  23. Jul 2, 2019 at 11:01 AM
    #53
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    No level, all stock. Wheels are +50mm, while the stock TRD Off-road are +60mm.
  24. Jul 2, 2019 at 11:41 AM
    #54
    dbuckman
    dbuckman New Member
    2" level
    So do you think those size tires would fit on my TRD Sport that has been leveled at 2" with the same offset?
  25. Jul 2, 2019 at 11:48 AM
    #55
    Razorwyre
    Do you have the stock wheels? The issue isn’t height, it’s that the offset of the wheel on a stock truck puts the tire 10mm closer to the control arm. It would be close. I would look for threads related to 295 wide tires on 60mm wheels (stock). Also keep in mind, there are minor variations between manufacturers even in the same size.
  26. Jul 2, 2019 at 11:51 AM
    #56
    Big J
    Big J New Member
    2020 4x4 crewmax
    OP showed pics on OEM 20x8 +60mm with this tore size. :thumbsup:
  27. Jul 2, 2019 at 11:52 AM
    #57
    dbuckman
    dbuckman New Member
    2" level
    I plan to purchase 20x9 wheels
    Big J likes this.
  28. May 20, 2020 at 10:03 AM
    #58
    MgmSR5
    MgmSR5 New Member
    2016 CM Limited 5.7 Mica Sunset Bronze
    Not to resurrect an old thread, but I found this super helpful when doing my own research. I just put 305/55/20 on the same stock wheels with +60 offset. I have an SR5 non TRD and is completely stock otherwise. I’d be curious to see what your clearance is like between the tires and UCAs. Mine is VERY close, but doesn’t rub. Will probably go down to a 295 next time around.
  29. Nov 6, 2020 at 3:48 PM
    #59
    jalam321
    jalam321 New Member
    Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Sorry, not trying to revive old thread either but I want to add a pic to help others that may be curious. Here is a pic of my Sequoia with the tundra TSS wheels 20x9 +50 offset and Toyo RT 295/55/20. It's close also but does not rub on UCA, probably about 1 finger gap
    @MgmSR5 - Just curious why downsize to 295/55/20? Is the 305/55/20 to close for comfort? I actually wanted to go 305/55/20 but was afraid it would rub on UCA. But after seeing your pics, I might go up 305/55 next time.
  30. Nov 7, 2020 at 1:27 PM
    #60
    MgmSR5
    MgmSR5 New Member
    I actually don’t have this truck anymore, but I was planning on downsizing just because of how close it was! It doesn’t rub though!
