How to turn a 5 min job into a 3 hour job ...
Discussion in 'Lighting' started by rockjockey, Oct 29, 2016.
  1. Oct 30, 2016 at 5:37 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    How many tundras.com members does it take to change a light bulb?
  2. Oct 30, 2016 at 7:08 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hilarious post, I feel for ya bro. I damaged both of my map lights installing them sum bitches.
    NewImprovedRon likes this.
  3. Dec 14, 2016 at 12:34 PM
    rockjockey
    rockjockey [OP] Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Well, I said I would follow up with a how-to for how to take the console box off the roof and fix the bulb connector problem and, finally, here it is...
    Here's the console box before removal...
    There are four T20 screws which hold the console box to the roof.
    Two of theme are behind the square center section panel which has the clip holder on it.
    The other two are inside the sunglasses holder.
    The center section must be pried out to access those two screws.
    A little painter's tape will protect the plastic frame while prying out the center section...
    Here's the center section with the first corner pried loose.
    Once you have one corner loose, the whole section comes out pretty easily...
    Here's a pic of the back side of the center section removed.
    Note that the clip holder can be removed - might be a good place for custom switches...
    Once the center section is removed, you can get to the first two screws...
    Next, open the sunglasses holder to access the other two T20 screws...
    Be careful removing the last screw - once it's out the unit will come right off
    and will be hanging by the wrapped wire bundle hooked to the main connector...
    Here's a closeup of the back side of the roof console box unit with the connector highlighted...
    Here's a closeup of the connector itself...
    Here's a closeup of the connector after release.
    Use a small screwdriver or a thumbnail to lift the tab and pull apart the connector...
    Here's what the back side of the bulb socket is SUPPOSED to look like.
    Note that the plastic "weld" is holding the copper strip flat to the plastic body...
    Here's the problem side. as you can see, when I tried to insert the LED bulb, the slightly fatter base
    pushed the copper socket and the attached copper strip up off the plastic post (probably a poor "weld").
    Once this happens, the bulb just pushes the connector up instead of inserting into it.
    No way to fix this from the front side...
    After pushing the copper strip back down onto the post, I kept pressure on it from the backside while inserting
    the bulb in from the front side. Depending on how well the plastic post and "weld" holds once you push it back on,
    you might need to add a dab of silicon to hold it in place. Luckily mine stayed in the correct position...
    Reinstall by reconnecting the main wire bundle connector, reattaching the main unit with the four screws,
    and snapping the center section back in place. Note that the screws go into "nut clips" attached to the cross members
    behind the console box. These nut clips can move around during removal and you may have to fiddle with them a little to get
    them lined up with the screw holes in the console box. A gimlet or other pointed tool helps.
    Success!...
    After hearing from so many others who had similar problems, I think if I had to do it over, I would just remove
    the unit to change the bulbs in the first place. The whole process takes about 20 minutes.
  4. Dec 14, 2016 at 12:42 PM
    TheBeast
    TheBeast The Beach
    excellent write up. thanks !
  5. Dec 14, 2016 at 2:51 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    i can relate...
  6. Dec 14, 2016 at 10:09 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    And I thought I was the only one that had to do this ... Now seeing this is a common issue. Great write up that will hopefully help those that are bound to have this issue happen to them.
  7. Dec 15, 2016 at 5:20 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Really want to swap my interior lights out for green LEDs, but after all these horror stories. I'm not so sure. But thanks for the write up! Might be needing that soon. haha
  8. Feb 8, 2017 at 10:07 PM
    geno0506
    geno0506 New Member
    Michael
    Darth Tundra and Stulloh like this.
  9. Feb 9, 2017 at 4:09 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    This just made my morning lol hilarious
    geno0506 and NewImprovedRon like this.
  10. Mar 14, 2017 at 8:57 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    That was a great read haha some good info in here!
    geno0506 likes this.
  11. Jan 16, 2018 at 5:39 PM
    Datamulch
    Datamulch New Member
    Steven
    I just found this post. Searching because I just did the same goddamn thing. To hell with it. It can wait for the weekend. I pretty much destroyed the reflector as well. Son of a bitch!
  12. Jan 16, 2018 at 7:27 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    You forgot going to LKQ (sp). To buy a new overhead console because you blew the brass stips in the old one.
    (Did this last spring)
  13. Jan 16, 2018 at 8:34 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Man everyone here should re read this post before every project!!!! It's so freakin true and I truly feel the pain.LMAO snot bubbles the whole nine.
    Wvmoonshiner likes this.
  14. Jan 17, 2018 at 7:46 AM
    Happybg81
    Happybg81 New Member
    William
    13’ Balcked Out Rock Warrior DC
    Switched backup camera, interior led’s, backflip g2, smoke led taillights, rhino liner, leveling kit, black powder coated rw wheel rings, weathertech mats, under seat storage, evo one remote start, flowmaster 50 series, S&B CAI, Focal 6x9 front doors, Rockford Fosgate 6.5” rear doors, JL Audio dash tweeters, Kicker hideaway under rear seat
    Let’s say someone completely jacked up the socket and broke one of the strips. Could you solder in an led strip back behind the break?
  15. Jan 17, 2018 at 8:41 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Must have been a Monday.
  16. Jan 17, 2018 at 4:20 PM
    Datamulch
    Steven
    Okay...so after a couple stiff belts of Knob Creek....I took the console out and got everything straight and reassembled. The pictures I’m this thread helped considerably! Thanks @rockjockey !
  17. Jan 22, 2018 at 8:45 AM
    Happybg81
    William
    FYI, it was very simple to solder an led strip into the map lights. They don’t work by pushing them, but come on with unlock and fade in and out with the dome, and come on when switch is turned to on. I probably could have played around longer and figured out which strips made them work by pushing the light, but I really didn’t care if they worked that way or not.
  18. Jan 22, 2018 at 10:30 AM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Here's what I did:
    1. Stick a small piece of duct tape to the bulb.
    2. Grip the duct tape and pull the bulb out.
    3. Insert new LED bulb.
    It took 30 seconds each side.
    jmdaniel and NewImprovedRon like this.
  19. Jan 22, 2018 at 10:44 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Hilarious! It's good to see that the struggle bus doesn't just stop at my house :)
  20. Jun 5, 2018 at 3:36 AM
    #50
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    Thank you sir! Exactly what I've been searching for. Found a lot of threads on removal of the console, but nothing close to this step-by-step. Will be doing this to put in my aftermarket mic for my new head unit.
    Thanks again for spending the time on it.
  21. Jun 5, 2018 at 5:39 AM
    #51
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Been there, done that. Have an opened box of assorted mini-fuses which is missing a 7.5! ;-)>
    B
  22. Jun 5, 2018 at 5:49 AM
    #52
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    That is some funny stuff!
    I blew a fuse on when changing the rear roof domes in our 07, had a spare Thank God! My son was like "Dad, what did you DO"! Because all the lights were out.
    The Glove box bulb was my nemesis. The socket/prongs got pushed upward behind the dash. Had to remove a few things to make it work again, maybe an extra 20-30 minutes.
  23. Oct 21, 2018 at 7:26 AM
    #53
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Bump!
    OP’s post #38 with the pics of taking down the overhead map light unit and step by step fix - I cannot say enough how easy this was!!! Any new Tundra owner needs to read and watch this thread, this happens a lot and you may need to do this one day!
    xma and NewImprovedRon like this.
  24. Jan 11, 2019 at 2:28 PM
    #54
    Mojo1794
    Mojo1794 New Member
    2016 1794 4X4
    I appear to be the latest lucky winner of weak ass prongs! I bought a new to me 2016 crew with the moon roof buttons and what not in the console. I'll try and do my best "rockjock" fix when I get home tonight. Anyone have trouble with pulling the unit down with his method having the additional electrical components? screws in the same place? harness connections and pry spots?
    Thanks for a great "how too". I was so gentle pulling them out, totally frustrated that they wouldn't socket. And then I arrived here... thank god! Just about to tear out the thin metal shields....
  25. Jan 11, 2019 at 2:43 PM
    #55
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    I just got all my LED's to replace all interior bulbs. Somehow I get the feeling I will repeat at minimum 80% of this. :(:help:
  26. Jan 11, 2019 at 2:56 PM
    #56
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Epic post OP
  27. Jan 11, 2019 at 2:59 PM
    #57
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
  28. Jan 12, 2019 at 9:22 AM
    #58
    Mojo1794
    Mojo1794 New Member
    2016 1794 4X4
    For those that arrive here with the rear window and moon roof option, it's one more easy connection to take apart inside compartment just above the switches, near the two screws you're going to pull anyway.
    I'll clearly not change these two bulbs out without taking the unit down again. So, after careful bending of the brass bits and getting it to hold, I only had 60% confidence it would stay in place long term. I placed a small small bit of cheap super glue(harbor frieght) on the top brass post of each light base. Used a tooth pick and it worked great.
    Thanks again all!
  29. Jan 12, 2019 at 11:22 AM
    #59
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I am glad you posted that I was thinking about doing that mod. Would not think it a big deal.
    gosolo[QUOTED] likes this.
  30. Jan 22, 2019 at 7:23 PM
    #60
    BradWils
    BradWils New Member
    7” Procomp lift Procomp MX2.75 Coilovers SPC UCA’s Plus 3” Rear Shackle 35x12.50 R20 Duratracs Pro Com 20x9 0 offset rims Bora 1.5” wheel spacers OEM LED Headlight and Fog conversion LED interior lights TRD Pro Grill Borla Touring true dual exhaust AFE Magnum Force Stage 2 SI Pro Intake Bushwacker Fender Flairs Colour match door pulls, mirror caps and hood buldge Weather Techs Remote Start Factory Match Tint Toyota Bakflip Tonneau cover Line-X
    Best Post! I broke the metal reflector and the clear lens on the drivers side before I found this thread. Any idea on part numbers or suggestions?
