Remove factory spray on liner from bed bolts?
Discussion in 'General Tundra Discussion' started by atebit, May 26, 2019.
  1. May 26, 2019 at 3:58 AM
    atebit
    atebit [OP] New Member
    PA
    19 QS DC TRD Limited
    My new 19 has the OEM spray on liner. I’d like to install D-Rings under the bed bolts, but they’re all covered with spray liner? Is there a prescribed way to get it off the bed bolts so I can R/R?
  2. May 26, 2019 at 5:01 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  3. May 26, 2019 at 5:09 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Yep, cut around the bottom of the head of the bolt with a utility knife and the liner should peel right off.
    Kgfit85 and Toyotoholic like this.
  4. May 26, 2019 at 5:38 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
  5. May 26, 2019 at 5:56 AM
    atebit
    PA
    Thanks, glad it’s that easy!
  6. May 26, 2019 at 6:28 AM
    Keisuketak
    Keisuketak New Member
    Santa Cruz, ca
    2016 CM 4x4
    Make a few slices with a blade and peel off with pliers
  7. Dec 24, 2021 at 11:55 AM
    Keakua17
    Keakua17 New Member
    2021 Black Tundra SR5 4x4
    Leitner ACS rack & storage, blackout grille replacement, Decked storage, Prinsu roof rack, this is just the beginning…
    I tried a few different techniques and whatever bedliner the dealership sprayed on, it definitely didn’t just flake off with a chisel. But this is what I did that ended up being pretty quick and easy to remove the T40 bolts:
    1) use a heat gun on the bolts until you can tail that the coding has become soft and almost starts to bubble.
    2) I used a T30 and gently tapped it in with a hammer. You have to rotate it around a bit but if you have heated the code into the point where it’s soft, you’ll feel when it sinks into the bolt’s grooves.
    3) Remove the T30, soften it up again with the heat gun, and find the alignment from the T30 and do the same thing to tap in the correct T40 size. Without removing the T40, attach a socket wrench and carefully remove the bolt.
    4) I then had to soak the bolts overnight in isopropyl alcohol (or paint thinner) to get the coating off.
    As long as you don’t go apeshit with the hammer, you can avoid damaging the bolts.
    WVI and coldcanuk like this.
