Smoked third brake light
Discussion in 'Lighting' started by Racerx01, May 25, 2019.
  1. May 25, 2019 at 2:01 PM
    Racerx01
    Racerx01 [OP] New Member
    2019 Trd sport
    3/1 lift
    I wanna put a smoked third brake light on my 2019 sport but was just wondering if it is a pain to replace or if they’ve changed how it’s mounted
  2. May 25, 2019 at 2:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    They are a huge pain to replace. Definitely best off tinting the lense that's on there. With film or spray. Some guys use plastidip even
    Sas likes this.
  3. May 25, 2019 at 2:31 PM
    Racerx01
    2019 Trd sport
    3/1 lift
    So what’s the major hang up , is it that there’s nuts on the back side under the headliner ?
    Pudge likes this.
  4. May 25, 2019 at 2:42 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    The 3rd brake light itself is only 2-4 screws... I used VHT Niteshade and tinted mine as a DIY... turned out great I think
    hi_rawb, toyofan87 and OR18TRD like this.
  5. May 25, 2019 at 3:05 PM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    It’s still a pain. If you have a CM it isn’t horrible. I know it’s a lot of money for a lens, but I bought the light smoked lens from Klearz. I’ve had it for s couple years and am happy with it. It still looks like it did when I first installed it. All the aftermarket ones I’ve had have yellowed over time.
    5150bronco and Punisher17 like this.
  6. May 25, 2019 at 3:14 PM
    Pudge
    CT
    Yeah the nuts behind the headliner. People seem to never get it fully sealed once its off once
    5150bronco likes this.
  7. May 25, 2019 at 3:26 PM
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    2023 TRD PRO
    Damn! It's $80 for the lens!
  8. May 25, 2019 at 4:13 PM
    MMichaelJJ
    14 Platinum CM
    Yes.... but worth the money to not have to deal with the hassle of dropping the headliner and risk of it leaking water.
  9. May 25, 2019 at 5:01 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Tinted mine... well the cargo lights anyhow.
  10. Jan 20, 2021 at 5:17 PM
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Are these the light smoked or smoked?
  11. Mar 13, 2022 at 4:35 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Hello!
    I bought the Enzo third brake light smoke and realizing how this is a huge pain and it does look like you have to get the nuts behind the headliner.
    it just looks like the easiest thing would be just to replace the lens. The body of the stock third brake light is black and the body of the aftermarket third brake light is chrome which is pretty stupid.
    it would just make sense to replace the lens only.
    are there any other updates anyone has found to get a new lens besides the one mentioned?
    thanks!
  12. Apr 4, 2022 at 5:59 PM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    I have been looking into this. Looks like the only options to purchase one is the one from klearz or I found one on ebay. When I first bought my truck and had it wrapped but its getting foggy looking.
  13. Apr 4, 2022 at 6:39 PM
    5150bronco
    Justin
    Bay Area, Ca.
    yes I would agree from what I know.
  14. Apr 13, 2022 at 7:29 PM
    jaredmillerdvm
    Anderson, SC
    Ended up buying the one from Klearz. It looks pretty slick!
  15. Apr 15, 2022 at 11:28 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    I went whole hog on mine. Used all the OEM parts but tinted the lens all red, then smoked so it looks all uniform.
    then i removed the unit and rewired the assembly all the same to be one uniform 3rd brake light. eliminating the cargo lights
    I have AUX cargo lights anyways and wanted a different custom but OEM look
