  1. May 21, 2019 at 7:02 PM
    #4441
    Washed it after the weekend.
  2. May 21, 2019 at 8:18 PM
    #4442
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Id say a bit but not much and now the sway bar sticks about 8" further off the back of the axle. it was the only way to get it to reach after the leaf swap.. The shock mounts hang super low so ill be chopping those soon and doing some off the axle tube instead which will also allow me to use my current kings and not go for extended
  3. May 22, 2019 at 2:20 AM
    #4443
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Now I understand the reason for mounting the sways that way. I’ll stick to the conventional way as I only have summo springs in the back.
    Just noticed how high your rear is back there.
  4. May 22, 2019 at 8:30 AM
    #4444
    Cmaccullen
    Cmaccullen X-ray
    2011 Tundra
  5. May 22, 2019 at 9:36 AM
    #4445
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    I got exactly what I asked for with these leafs at 3" on the passenger and 3.25 on the driver. Hardly squats with the current weight and ride buttery smooth. The test will be the TT this weekend.
    Yea id always seen trucks mount them this way that were 6" plus and never understood it either until I got under there and just looked at it again. Id gone ahead and moved it this way before the leafs ever even made it to be built so it may have fit where it was in the original spot but I wasn't moving it back to find out haha. The other option was keep it in original spot, cut the connecting round bar from the bushing ends and weld in a new piece of round bar. Id probably have made it a little thicker as well. We will see how this method works out and revisit later if needed
  6. May 22, 2019 at 5:15 PM
    #4446
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    going out to drop the rci skid plate so i can change the oil filter. the trap door is a great idea if you don't use hardware that rusts in place and is recessed allen head. took 20 minutes to get one out...other is just destroying my allen wrench. only been on since november so bit of a disappointment :(
    CaptSpaulding and rvrats2 like this.
  7. May 22, 2019 at 8:15 PM
    #4447
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    I’ve noticed my heavy sliders actually smooth out my drive on payment and over speed bumps initially. Maybe a shackles upgrade over stock will make the ride even better
  8. May 22, 2019 at 9:26 PM
    #4448
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    I feel like I noticed that as well when I was in my Tacoma.. not so much on either tundra ive had.. I cant wait to add filler plates to mine though, I finally laid out a filler design im happy with and cant wait to put into production on my sliders! Shackles shouldn't change your ride much if any, I had mine on the middle setting for 1" and they were fine. Ive always run shackles or rebuilt my leaf springs on any rig ive had. If I do anything next ill be upgrading bumps while im doing the shock mounts! That rear bumper you've got aughta help soften the ride up for you a good bit as well. Do you have the swaybar?
  9. May 22, 2019 at 9:32 PM
    #4449
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    As for what ive done today, The gf and I swapped the tensioner and idler pulley and slapped on a new belt.. hopefully this gets rid of the awful belt squeal we've had. Also put in some new nutserts for the skid to bolt up. 3 of my 5 skid bolts were all chewed up and the nuts were stripped so I had to drill them all out and knock them loose from inside the frame but now the skid goes on easy as ever!
  10. May 23, 2019 at 2:31 AM
    #4450
    ryanw4x4
    ryanw4x4 New Member
    South West Washigton State.
    2011 SR5 Trd OFF-ROAD
    New wheels off a 19. Big difference in looks.
  11. May 23, 2019 at 4:33 PM
    #4451
    Abefroman
    Abefroman New Member
    Springfield, MO
    2009 Tundra SR5 4X4
    Got my katzkin seats installed! B4/AfterB96EAD87-DBA6-43CD-A543-A6610DE1DE19.jpg1966B55E-914A-4B09-9993-DF24FB37AFCC.jpg AE7924CD-766F-4CCE-869E-67613E858F34.jpgFC066907-532F-4129-B30C-ACD6641E4554.jpg 8D0051C5-4124-4554-8EC3-4693905BF9F7.jpgEDEC14C9-65E2-412D-94F6-AB12318C9B0E.jpg
  12. May 23, 2019 at 5:24 PM
    #4452
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :eek2::thumbsup:
    Abefroman[QUOTED] likes this.
  13. May 23, 2019 at 5:31 PM
    #4453
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    I second that... those covers look great!!!
  14. May 23, 2019 at 5:56 PM
    #4454
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Great new look!:thumbsup:
    Mountun Goat likes this.
  15. May 23, 2019 at 6:15 PM
    #4455
    Waterboy45661
    Waterboy45661 New Member
    Tommy
    07 Red SR5
    Wow, those look great!
    Abefroman and Mountun Goat like this.
  16. May 23, 2019 at 9:02 PM
    #4456
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Took the truck out for a spin with the dh bike to a local gravel slope. Couldn’t help but take a pic of her after.
  17. May 23, 2019 at 9:03 PM
    #4457
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Always appreciate a picture of the beast man. How did the tailgate pad work out?
    Mountun Goat[QUOTED] likes this.
  18. May 23, 2019 at 9:16 PM
    #4458
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    @Abefroman, which seat heaters did you use? :thumbsup:
  19. May 23, 2019 at 9:20 PM
    #4459
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Awesome! They look great
    Your screen name is awesome too
  20. May 23, 2019 at 10:00 PM
    #4460
    Abefroman
    Springfield, MO
    2009 Tundra SR5 4X4
    Not sure. I had someone do it for me. Didn’t trust myself to get that done to the level of quality i wanted done. Had him throw in some seat heaters while he was at it. Ill see if I can find out
  21. May 23, 2019 at 10:02 PM
    #4461
    Abefroman
    Springfield, MO
    2009 Tundra SR5 4X4
    Thanks. You might appreciate this pic375A1762-A434-4D85-B77B-273479A98525.jpg
  22. May 23, 2019 at 10:58 PM
    #4462
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks haha. Worked perfectly! Such a good upgrade for me!
    CaptSpaulding[QUOTED] and Rica25 like this.
  23. May 24, 2019 at 8:10 AM
    #4463
    Trooper2
    JR
    Fun pic!
    Is the Ferreri still down there? LOL
  24. May 24, 2019 at 8:55 AM
    #4464
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Down by the tree where it landed I hope. Great pic Abe!
  25. May 24, 2019 at 11:12 AM
    #4465
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    OH MY GOD. LEGENDARY!
  26. May 24, 2019 at 5:34 PM
    #4466
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    Finally found time to install the Carriage Works Grille that I purchased several months ago.
  27. May 24, 2019 at 6:04 PM
    #4467
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    Washed her, waxed her, and replaced the standard 4x4 badge with a retro land cruiser reproduction badge20190524_174701.jpg 20190524_182255.jpg
  28. May 24, 2019 at 6:51 PM
    #4468
    Abefroman
    Springfield, MO
    2009 Tundra SR5 4X4
    No Ferrari lol. It looks like a secluded area, but is actually in the middle of the burbs. Only bout 5 minutes away from the home alone house.
  29. May 24, 2019 at 6:52 PM
    #4469
    Abefroman
    Springfield, MO
    2009 Tundra SR5 4X4
    Thanks! It was a fun day!
  30. May 24, 2019 at 6:54 PM
    #4470
    Abefroman
    Springfield, MO
    2009 Tundra SR5 4X4
    It is in a burb north of Chicago in Highland Park. Lotta Frank Lloyd Wright homes in the area. Also close to the home alone house. If you ever up there with time to kill you should check it out!
