Squeaking with BDS 7" Lift... HELP
Discussion in 'Suspension' started by holdenm9, Aug 23, 2018.
  1. Aug 23, 2018 at 7:05 AM
    holdenm9
    holdenm9 [OP] New Member
    2018 White Tundra TRD Off-Road
    BDS 7" Lift Nitto Ridge Grapplers 35x12.50r20 Moto Metal 20x10
    I need help/suggestions... I've got a 2018 TRD off-road with a 7" BDS lift. I upgraded rear shocks to the Fox shocks and added BDS UCA's to the front end. I've got the bilstein 4600's in the front that come stock with the TRD Off-Road. I've had my lift on for about a month and a half and just stared noticing terrible squeaking when going over speedbumps or uneven terrain at slow speeds. I had the lift re-torqued about 500 miles after installed and he said everything was still good and tight. Does anyone have this same problem or know what it could possibly be? TIA
  2. Aug 23, 2018 at 7:08 AM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Something very very tiny is hitting somewhere when going on bumps.
  3. Aug 23, 2018 at 7:36 AM
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    I responded to your thread in the suspension section, I think it's the sway bar end links, that the issue I had with my 2011 and 2014 Tundras with the 7" BDS.
    Black Wolf likes this.
  4. Aug 23, 2018 at 7:50 AM
    holdenm9
    Yeah, I wasn't sure if it would be seen through a general message thread so i double posted it. trying to get this figured out ASAP. Don't like hearing squeaking from a 3 month old truck. Thanks
  5. Aug 23, 2018 at 7:56 AM
    Midmo_tundra
    Missouri
    I narrowed it down by removing the swar bar and BDS end links and going for a drive, the squeak went away. Or you can try lubricating them, but most lube attracts dirt so try to use a dry lube
  6. Aug 23, 2018 at 8:05 AM
    holdenm9
    I guess i will try lubricating. Sucks that you pay for what you think is a decent lift and the end links aren't worth shit.
  7. May 14, 2019 at 6:29 PM
    bill747
    bill747 New Member
    2018 Toyota Limited TRD 4x4
    I have the 2018 TRD Limited, with 4.5 BDS lift and fox coil overs. I pinpointed the squeak to the sway bar end links. Has anyone found a good cure for this noise other than lubricant? Love the lift, hate the squeak. I am blown away that a company would engineer a lift kit with metal on metal parts, especially because I thought I was buying a quality product.
  8. May 15, 2019 at 3:59 AM
    holdenm9
    I started diagnosis and took the sway bar off. Turns out the squeak was coming from the rear drivers side Ubolts being loose that go over the spacer block and lead spring. Tightened them up and now it has moved to the front. Sway bar still off. Back to the drawing board...
  9. May 15, 2019 at 4:07 AM
    What about having someone drive in an open area slowly while you walk around to see where coming from, make them full lock turns forward reverse, up and down a sloped area like a drive way, mine does this, wasn't doing when I bought it, bought used and already had lift, bought with 26,000, now at 68,000 making all kinds of noises, betting all lift components need to be re torqued
    jeremyd likes this.
  10. May 15, 2019 at 4:22 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Mount a GoPro under there
    TXRailRoadBandit73 likes this.
  11. May 15, 2019 at 4:26 AM
    holdenm9
    That’s kind of what I was thinking too is to re-torque the front end components. Atleast to start with... like I said, those ubolts weren’t exactly in spec, call for 100-120ft-lbs and I had several turns before I even hit 100ft-lbs.
  12. May 17, 2019 at 6:23 AM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Had the same issue on my 2017. Thought it was the sway bar end links, then after replacing them I heard more noise and readjusted the sway bar. Those sleeves were contacting the sway bar connects to the frame. Readjusted them and voila!
  13. May 17, 2019 at 6:31 AM
    holdenm9
    I don’t have my sway bar on the truck and hearing noise still.
  14. May 17, 2019 at 6:39 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Not sure if this would work but I would try spray lubricant in different areas "one at a time"...
    BUGEATER and TXRailRoadBandit73 like this.
  15. May 18, 2019 at 7:02 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    I have the same problem with my bds 4"...
    I put silicone spray on it for a temporary fix but want to know of a specific permanent fix grease or lube?
  16. May 18, 2019 at 7:18 PM
    holdenm9
    What did you lubricate?
  17. May 18, 2019 at 7:24 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    The upper connection to the sway bar link.
  18. May 23, 2019 at 5:16 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    This is my long term solution to the problem as recommended by my local auto parts store
  19. May 23, 2019 at 5:28 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    Don't bag on my rusty parts boys...
    I boughts it like dat.
  20. Jun 22, 2019 at 7:11 AM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    Update:
    Its been a month. We've been camping in northern Arizona where the mud is clay like. With recent rains the mud pits were everywhere and unavoidable in many cases due to the dense forest. Of course the Tundra pulled through. Got her home and pressure washed her for over an hour and there's still mud under there.. Mudded out my driveway and neighbors gutters lol.. Long story short.. after all of that, the grease is working perfectly and still no squeaking from the sway bar links.
    Bigboitundra likes this.
  21. Sep 27, 2019 at 8:17 AM
    fore76
    fore76 New Member
    Lee
    2011 Black RW
    Lifted, 35
    I have a 2011 tundra with the BDS lift and I too have the same squeaking discussed. I’ll try to put Li grease on the end links.
    Also, can anyone confirm that the end links are supposed to have some form of rubber bushings aside from the bushing that’s is on the link itself?
  22. Sep 27, 2019 at 8:52 AM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    Ive been told by a lift shop that specializes in BDS suspension that the connection is supposed to be metal to metal... fyi.. ive greased them once and have been camping and mudding a lot...
    BDM Customs. 480 966 61 zero zero.
  23. Feb 24, 2020 at 5:49 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    Update:
    9 months later
    was in the snow
    the squeak is back
    grease reapplied
    problem solved
  24. May 2, 2020 at 9:30 PM
    tmart
    tmart New Member
    Travis
    Sorry to revive this but I have the bds 7 inch lift too and the squeak has been driving me crazy. It gets worse after mudding and stuff which I know has to be dirt in a metal to metal point and I’m wondering if it’s my sway bar links too. For you guys that greased it and it went away, you didn’t remove the sway bar to grease it did you? Just rub some all over pretty much?
  25. May 2, 2020 at 9:34 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    Just rubbed on metal to metal surface..
    Removed nothing..
    Pictured above..
  26. May 2, 2020 at 9:55 PM
    tmart
    tmart New Member
    Travis
    Nice I’m gunna try this tomorrow, thanks man
  27. May 2, 2020 at 10:03 PM
    Ibew640
    Ibew640 New Member
    Anthony
    15 Limited 4x4
    4"BDS
    No problem
  28. May 3, 2020 at 1:13 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Had the exact issue on my 2012 with the same lift. First thing, disconnect the sway bar links and drive it. See if that stops the squeak. I changed my rod end to rod ends with grease zerk fittings sold by Purvis Bearing (https://www.purvisindustries.com/) . If squeak doesn't stop, then removed the skid plate. There are 2 vertical bolts (nuts on the top) attached to the frame. Make sure those are tight. Mine were lose and the squeak turned into a slight knock after some time when turning the wheels from full lock left to right and back. With the skid plate off and me lying under the truck, my brother turned the wheel left to right and you could barely see the boxed part move ever so slightly. It was very unnerving to me. I tightened the EFF out of them and never had another issue for the next 50k miles til I sold it. The new owner, and coworker hasn't had any issue at all with it.
    See post #1 here for a pic (that is my post BTW).
    https://www.tundratalk.net/threads/2012-cm-7-dbs-lift-knocking-noise-solved.718514/#post-9033226
  29. May 3, 2020 at 10:19 PM
    tmart
    tmart New Member
    Travis
    Hell yeah bro I appreciate it, I haven’t had a chance to mess with mine yet since I’m out of town for the week for work but I’ll definitely check it out once I’m back!
  30. Jul 4, 2020 at 11:05 AM
    Davebearpig
    Davebearpig New Member
    2015 TSS Offroad
    4.5" BDS lift, 20x12 fuel off road rims, 35" kumho MTs
    I have a 4.5" BDS lift on my 2015 and it's such a huge pain. I have the truck for a year and I've already replaced the heim joints on both sides, outer tie rod ends, and now the rear shocks are starting to squeak pretty badly.
    I live a long way from a company that can service a BDS lift, so having parts replaced is about a 7-8 hour round trip, plus however long it takes to replace the parts. You would think for the price and claims of the lift, it would be able to hold up to daily driving, but it just isn't. If it wouldn't cost so much, I would have scrapped it a long time ago.
