Let's talk pressure washers
Discussion in 'Detailing' started by HBdirtbag, Dec 4, 2017.
  1. Apr 18, 2019 at 6:12 PM
    #211
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
  2. May 14, 2019 at 8:20 AM
    #212
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Sas likes this.
  3. May 14, 2019 at 8:33 AM
    #213
    briarpatch
    briarpatch New Member
    That's a good deal. I've gotten kind of tired of dragging it out to wash a car.....so I'm going with a more permanent solution....the comet 1700 stationary pressure washer. A little less PSI, but higher GPM than some of the portable units.
    ToyoMafia and Voyagermike like this.
  4. May 14, 2019 at 8:45 AM
    #214
    Voyagermike
    Voyagermike New Member
    California
    Not sure if you've ordered your comet yet. But when I was shopping around for one I originally came across these guys that had the most info in them and the best price.
    Use 10off to get 10% off
    https://lidetailers.com/collections/pressure-washing
  5. May 14, 2019 at 9:03 AM
    #215
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    curious to see how you like this, i've had my eye on one for some time.
  6. May 14, 2019 at 9:06 AM
    #216
    briarpatch
    they seem to be back ordered no matter who you reach out to......I just sent them a message......did you order one from them?
    Voyagermike[QUOTED] likes this.
  7. May 14, 2019 at 9:12 AM
    #217
    Voyagermike
    California
    No I haven't ordered one from them yet. Wasnt sure on stock at the moment. Hmm
  8. May 14, 2019 at 9:17 AM
    #218
    briarpatch
    they seem to be a hot commodity
  9. May 22, 2019 at 7:05 PM
    #219
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Ryobi is using Honda engines on their pressure washers. I picked up a 2.3gpm, 2900 PSI Ryobi at HD for about $350. Seems to work like a champ. Did my driveway, walks, and first floor siding and it’s powerful.
  10. May 22, 2020 at 3:02 PM
    #220
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Anyone have or used the Griot's Garage 2200 power washer? thinking of replacing my 1500 greenworks power washer. Not enough power anymore. Looking at gas PW too, but like quite of electric.
  11. Jun 7, 2020 at 6:30 PM
    #221
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just got this Sun Joe SPX-3000 the other day and I love it. What I do not love, however, is the foam cannon I bought to go with it. The foam consistency isn't the problem - it's that I have to use a brush to get stuff clean still. Anyone have a recommendation or suggestion as to what they do or use? TIA
    Y0TA PR0 likes this.
  12. Jun 7, 2020 at 6:58 PM
    #222
    briarpatch
    Different color, but the same one I have. The foam cannons that they sell stink. To me, the king of foam cannons is still the MTM PF22....they now have a new version with a redesign of the bottle....called the PF 22.2. It is expensive, at around 90.00. You can buy an Amazon cheapie for around 20.00....and there are a million of them on there. I have both.....and the MTM is definitely better.....is it 70.00 better.....I dunno. That would be up to the user. My one recommendation for maximizing the use of a foam cannon with any electric p/w, is to switch the orifice in the foam cannon from the standard 1.25mm to the 1.1mm....it will make a big difference in the thickness of the foam. Maxshine has a good quality foam cannon for around 31.00, also available on Amazon. Pan the Organizer on Youtube does a review on it.
  13. Jun 7, 2020 at 7:31 PM
    #223
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This one has a good orifice (lol) at 1.15mm. I just don't like that I still have to use a brush to get stuff clean.
    I'm now on Amazon looking for a brush attachment.
  14. Jun 8, 2020 at 5:08 AM
    #224
    briarpatch
    A brush attachment for a pressure washer will destroy your paint. You can't rely on a foam bath alone to remove everything. Was that your expectation....that covering your vehicle with foam would be all you had to do?
    ToyoMafia and Bama like this.
  15. Jun 8, 2020 at 6:35 AM
    #225
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    First time with a foam cannon. I don't see the point of using one if I still need to scrub everything down.
  16. Jun 8, 2020 at 9:31 AM
    #226
    briarpatch
    Foam cannons are sometimes used as a 'pre-wash'....prior to a contact wash. Depending on the strength of the soap, you can remove a fair amount of road grime, but in most cases, a contact wash is still necessary. If I know I'm doing a full detail, I'll begin with a foam cannon loaded with Purple Power Vehicle and Boast wash. This will remove some road grime, as well as break down some of the more stubborn stuff and degrade any residual wax/sealant.
    The whole idea of the pre-wash, or the pre-rinse for that matter, is to remove as much loose stuff as possible. This minimizes the risk of wash induced marring of your clearcoat. Maybe the foam cannon is not for you, but I think you'll find the SPX3000 strong enough to give your vehicle a pretty intense rinse prior to contact wash.
    I've broken mine out when the pollen got so bad on the truck I could not stand it. I was oddly satisfying to see all that yellow crap running down the driveway.
    truefunk and texasrho83[QUOTED] like this.
  17. Jun 8, 2020 at 10:16 AM
    #227
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I love this little pressure washer. It has the perfect amount of power (see below) lol.
    I always rinse the whole truck down first so the loose dirt/grime will come off before I hit it with a brush. I guess I saw too many advertisements or mistakenly understood that the foam would remove more than I saw on my two vehicles.
  18. Jun 8, 2020 at 10:56 AM
    #228
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I just got the same one an pulled it out this weekend to clean my alumawood patio cover, works great. I was totally impressed w/the quality and sound. Can't wait to use it for other projects...
  19. Jun 8, 2020 at 11:12 AM
    #229
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I love that the motor completely cuts off the minute you release the trigger
  20. Jun 9, 2020 at 4:30 AM
    #230
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    If you go with gas, get one with a honda engine, my last one was so old the deck cart fell apart and the Honda engine would still run. I believe mine was around 300 or so from same club, 3500 psi, just have to be careful if washing truck and make sure choose the right tip
    texasrho83 likes this.
  21. Jun 9, 2020 at 8:42 AM
    #231
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    You're right those smaller honda engines are almost bulletproof. Got one on my log splitter and generator, they're beasts, gas efficient too.
    don3032[QUOTED] and texasrho83 like this.
  22. Aug 8, 2020 at 9:58 PM
    #232
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    I got the SunJoe 3000 and have 0 regrets! Only advice is get quick connects, and a shorter gun!
  23. Aug 9, 2020 at 9:00 AM
    #233
    briarpatch
    ^^^^Best advice you can give for a SPX3000 owner....additionally, get yourself a 50ft hose or, at the very least an extension.....makes your life so much easier.
  24. Aug 9, 2020 at 4:59 PM
    #234
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This! I bought another 25' of hose and I'm good to go now!
