Cigarette lighter power accessory outlets not working - fuse
Discussion in 'General Tundra Discussion' started by csuviper, May 26, 2015.
  1. May 26, 2015 at 6:02 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I thought I was going crazy because I checked under the dash fuse box first and found a fuse labeled "CIG". Thinking that meant cigarette I checked it. Not blown.
    Checked a few others labeled power and accessory. Not blown. Checked a few under the hood as well and nothing.
    Finally figured it out!! It's the fuse labeled "PWR OUTLET". It is a 15A fuse.
    Hope figuring this out will help someone else save some time.
    Geebamm, The Grip, Patch999 and 5 others like this.
  2. May 26, 2015 at 6:06 PM
    Weird. "CIG" is supposed to run the cigarette lighter.
    1Tundra5 and 4x4_Angel like this.
  3. May 28, 2015 at 11:38 AM
    Aurora CO
    pooder2006 likes this.
  4. May 28, 2015 at 11:40 AM
    Aurora CO
    I had a real pain with that one. You would think that the 15A pwr out was for the 12V Aux out and the other 15A for CIG out. Two separate circuits. At least you fixed it.
  5. May 29, 2015 at 7:47 AM
    Victor
    Victor New Member
    victor
    San jose ca
    2012 Thundra SR5 Crewmax TRD
    Hay guys. I would like my outlets have constant power without having to turn my key on any ideas
    4x4_Angel likes this.
  6. May 29, 2015 at 8:25 AM
    csuviper
    Broomfield, CO
    I am actually going to be doing this with one of mine soon for charging the phone if needed when the truck is off.
    1. Remove the wire that is currently tied to the center of the cig ligher accessory outlet.
    2. Find a source that is power all the time. I'm going to look in the fuse box first. If found then use a Bussmann BP/HHH ATM Add-A-Fuse and tie the wire to the middle prong of the cig lighter accessory outlet.
  7. May 29, 2015 at 9:53 AM
    Victor
    Victor New Member
    victor
    San jose ca
    Sounds good keep me posted. Ill check it out.
  8. Feb 26, 2016 at 2:19 PM
    Bear River
    Bear River New Member
    2015 Tundra 4x4
    I had the same issue with my power outlets/usb going out. The fuse box in my Tundra no longer has a fuse labeled as 'PWR OUTLET' and I've checked most of them. Can't find it. Any ideas?
  9. Feb 26, 2016 at 3:23 PM
    csuviper
    Broomfield, CO
    Take a pic of your cover. I'm sure we can figure it out.
  10. Feb 27, 2016 at 5:28 AM
    Bear River
    2015 Tundra 4x4
  11. Feb 27, 2016 at 8:02 AM
    Bear River
    2015 Tundra 4x4
    Thanks @RowdyRon found the under dash fuse box and the power outlet fuse was there just as pictured in the original post.
  12. Feb 27, 2016 at 9:39 PM
    csuviper
    Broomfield, CO
  13. May 27, 2016 at 7:45 PM
    Mcdansan
    Mcdansan New Member
    Question, I need mine on all the time as well for charging phone. Why not just remove old fuse and run hot wire (with fuse ) to old fuse location?
  14. May 27, 2016 at 8:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good info, thanks for sharing.
  15. Oct 25, 2016 at 2:54 PM
    TheBeast
    TheBeast The Beach
    quick question: power outlet also covers the USB port inside ? can you charge your phone on the USB port b/c my iphone is not charging there. thx
  16. May 20, 2018 at 8:44 AM
    2018 TRD Sport
    2018 TRD Sport New Member
    2018 TRD Sport
    Since this came up as the top Google search result for “2018 tundra cigarette lighter fuse”, I thought I’d update this information for the 2018 model2018 Tundra Under Hood Fuses.jpg .
    It has apparently moved from under the dash, to the fuse box located under the hood labeled “P/OUTLET NO.1”.
    I also found out you need to be careful when probing the Cigarette outlet with a test light! :frusty:
  17. Jun 29, 2018 at 7:30 AM
    Tip DS
    Tip DS New Member
    Jay
    I have two 12V outlets beside my 2010 Tundra's front dash cup holders. ONE of them is blown, while the other is still operational. I'm pretty sure this is due to shorting the outlet... (boring story.) Anyone know how they are distinguished in the fuse panel? One is PWR OUTLET and one is CIG???
  18. Jun 29, 2018 at 7:33 AM
    csuviper
    Broomfield, CO
    The cig lighter excessory outlets are labeled "PWR OUTLET". CIG is for something else.
    If one works and the other doesnt then its not the fuse.
    WawaLunar likes this.
  19. Jun 29, 2018 at 7:44 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    How long does this take to do??? Something i definitely need.
  20. Jun 29, 2018 at 8:09 AM
    csuviper
    Broomfield, CO
    Not long at all.
    4x4_Angel[QUOTED] likes this.
  21. Jun 29, 2018 at 9:13 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Sweet. I'll be doing this soon
  22. Sep 12, 2018 at 3:59 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    So if I read this correctly, all 3 are tied to one fuse? Each outlet doesn't have a separate fuse, correct?
  23. Oct 2, 2018 at 5:31 PM
    crackerplease
    crackerplease New Member
    This happened to me and my 2003 tundra. Lost radio and cig lighters. I found 2 fuses blown. One under the hood and one under the dash. They were labeled radio and pwr acc. Both were 15a fuses. I found the radio one easy enough. Once I replaced the radio fuse, I couldn’t figure out why it still wasn’t working. Had to pull out every fuse to find the other blow fuse. Worst case - check all the 15a fuses. Good luck
  24. Mar 2, 2019 at 7:57 PM
    Creed3712
    Creed3712 New Member
    2018 White Tundra SR5 4x4 5.7L
    I had a bad phone charger that was blowing out the fuse on the 12v power outlet, first in the center console and then under the radio, before I figured out it was the charger. Replacing the fuse in the fuse box located under the hood labeled “P/OUTLET NO.1” resorted power to the 12v power outlet under the radio but 12v power outlet in the center console is still out. I have looked at all the 15A fuses but they are all good so now I'm stuck. I need the wiring diagram to figure this out.
    2018 Tundra SR5
    ***UPDATE***
    Ok, I figured it out on osucowboy96 post when he put up the quote from csuviper. The “P/OUTLET NO.1” in the fuse box under the hood goes to the 12v power outlet (cigarette lighter) under the radio. Then there is a 2nd fuse box under the dash to the left of the emergency break (break is in the way and had to engage it to get room) and there is a 15A fuse called “PWR OUTLET” and that is for the center console 12v power outlet (cigarette lighter) that is inside the armrest and the back seat area.
    I’m guessing they added in the 2nd fuse box for the SR5 upgrade package (maybe for other upgrade packages as well). Hope this helps anyone trying to figure out why one is out but cant find the bad fuse.
  25. May 14, 2019 at 6:09 PM
    osucowboy96
    osucowboy96 New Member
    Wichita Falls, TX
    2017 Inferno CrewMax
    Need some help from you experts. I'm thinking of tapping into this box for my dash cam, and need to know an always powered fuse to tap into and an ignition switched fuse to tap into. Thanks in advance!
  26. May 15, 2019 at 8:42 AM
    csuviper
    Broomfield, CO
    I always check with a multimeter to see which are always on and which are accessory only power
    NewImprovedRon likes this.
  27. May 15, 2019 at 9:44 AM
    osucowboy96
    Wichita Falls, TX
    Got it, thanks. Did a little research and also figured out you need to know which side is positive and which side is negative to make sure the tap goes in correctly. I'm learning a lot, appreciate all the help!
  28. May 17, 2019 at 8:28 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    ...and if you look at the right side of this photo you can see a relay marked the same (P/OUTLET NO.1"). You can remove this relay and fashion a jumper to have the cig outlets hot all the time, key on or off. Fuse still protects the cicuit. Here is a pic:
  29. Jun 3, 2019 at 3:38 PM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    FWIW, in my 2018 Tundra Limited, the 15A fuse for the two cigarette lighter / aux ports in the lower center console, as pictured below, is in the fuse box under the hood and labeled "PWR OUTLET 1". The fuse box under the dash only has a 15A fuse for "PWR OUTLET 2", which I assume is the one in the rear of the vehicle.
    Also, I discovered the factory fuse puller, which is indicated in the manual as being stored in the fuse box under the hood next to the 3 spare fuses, was missing. For those tiny little fuses, my Swiss army pocket knife pliers did not make purchase on the sides of the fuse -- they kept slipping off the fuse. I had to get my needle nose pliers to get the fuse out.
    WawaLunar and West Texas Tundra like this.
  30. Jul 21, 2019 at 3:36 PM
    EfreeTex
    EfreeTex New Member
    2019 SR5 TSS
    Has anyone been able to identify the relay for the power port in the console and in the back? I guess it would be the power relay for the Power Outlet 2 fuse.
