Where beer money went
Discussion in '1st Gen Builds (2000-2006)' started by Darkness, Aug 16, 2018.
  1. Feb 24, 2019 at 6:33 AM
    #61
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    What's the verdict with the spc cam bolts? Did the truck align well?
  2. Feb 24, 2019 at 7:50 AM
    #62
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    They worked out, pretty good alternative to Toyotas $400+ mind blowing price for bolts/sleeves/washers/nuts
    The tech got me within specs pretty easy, normally they go to the high end on caster but this time they didn't. It might be a better balance than what I'm used to because the camber doesn't shift as greatly when I turn, so it's pretty stable on freeways.
    TX-TRD1stGEN[QUOTED] likes this.
  3. Apr 13, 2019 at 10:31 PM
    #63
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    That big gapping hole scares me. :D :p
    Super clean "build" though
  4. May 2, 2019 at 11:41 PM
    #64
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    What projector shrouds do you have? and got a good pic of them? going to be ordering new headlights soon.. what housings did you use? factroy ones or aftermarket? (i aint paying for OEM if im going retro)
    Darkness[OP] likes this.
  5. May 17, 2019 at 8:06 PM
    #65
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sorry man, didn't see this.
    I'm running Apollo 2s for shrouds. I might have better pics at home. I had bought the black headlight kit that a lot of guys here have, I think I off Amazon. I got that because it had what used to be hard to find black corners with amber signals. I took them apart and painted the insides even more black and the shrouds too.
    I'm running a D2s kit from Retrofit Source with the 55 watt ballasts. I rarely come across anybody with better lighting.
    Casper421 likes this.
  6. May 20, 2019 at 10:40 AM
    #66
    FirstGenVol Brake Czar
    2002 AC
    Are these something that need to be replaced, or just something you wanted to do? I'm still trying to learn more about alignments.
  7. May 20, 2019 at 2:11 PM
    #67
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think it depends where you live. Mine lasted 15 years and probably would have been okay if I didnt remove them to replace lower control arms. Alignment shops only loosen them a bit to make adjustments, once I got past "loose" and went towards taking off they were stuck. Years of rust/sediment accumulated near the end of two bolts and they stripped because of it.
  8. Jul 7, 2019 at 10:25 AM
    #68
    Professional Hand Model
    Fred
    Hand Protectors
    Did you ever do your rear bearings? Those old front ones of yours looked gnarly.
  9. Jul 7, 2019 at 12:41 PM
    #69
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nope, haven't had a need to so far but I considered it. Just from the mileage and age it seems like a good idea but not high on my priorities.
  10. Jan 26, 2020 at 10:08 PM
    #70
    empty_lord
    05 rollover special
    You got a picture of that power thing you put in your bed? im trying to figure out what im going to do back there.
  11. Jan 27, 2020 at 6:10 AM
    #71
    Fred
    Hand Protectors
    I like how you tied right into the caliper with the flexible hose. How is that working out for you so far?
    Where did you finally mount that dangling clip hanger?
  12. Feb 17, 2020 at 7:07 PM
    #72
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @empty_lord and @Professional Hand Model my sincere apologies, I should sub my thread because I didnt see those questions.
    Empty knows he was looking for Casper.
    Handy, I picked up a set of banjo lines from a first gen Tacoma, that eliminated the hard line completely. I also have a set of Tundra style lines that would do the same, just not sure where they are. Solo Motorsports has them, they use them with their lift spindle kit, I picked a pair up off them years ago and never installed them.
    I've got a small number of parts I don't need somewhere, maybe I'll do some give aways here some time.
  13. Feb 18, 2020 at 5:15 AM
    #73
    Fred
    Hand Protectors
    Thanks. I just noticed your lines when studying for my recently performed brake job and that was the only reason for asking. My re-used OEM hard lines are working fine.
    Darkness[QUOTED][OP] likes this.
  14. Feb 25, 2020 at 8:24 PM
    #74
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    This made me laugh
  15. Feb 25, 2020 at 9:38 PM
    #75
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    :rofl: it's TRUE!
  16. Feb 25, 2020 at 9:40 PM
    #76
    empty_lord
    05 rollover special
    i have a feeling your next car is going to be neon green. just a hunch
  17. Feb 25, 2020 at 9:42 PM
    #77
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn close! I wanted to buy this yesterday, it's called "Reseda Green"
  18. Feb 25, 2020 at 9:43 PM
    #78
    empty_lord
    05 rollover special
    LOL im a smart man apparently!
  19. Oct 18, 2021 at 9:53 AM
    #79
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    We have the same wheels
  20. Oct 18, 2021 at 9:56 AM
    #80
    TRDGen
    TRDGen Schnooogins
    Travis
    I need one of those
  21. Oct 18, 2021 at 10:17 AM
    #81
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It isn't as easy for 06 but seems possible. Some smarter guys than me are figuring that out in the yellowbox thread. It is very nice to have.
    TRDGen[QUOTED] likes this.
  22. Oct 18, 2021 at 10:36 AM
    #82
    TRDGen
    TRDGen Schnooogins
    Travis
    That's odd. I expected 05 and 06 to be the same.
  23. Oct 18, 2021 at 10:41 AM
    #83
    TRDGen
    TRDGen Schnooogins
    Travis
    No ass shots of the truck? Shameful
  24. Oct 18, 2021 at 11:05 AM
    #84
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    05/06 have a different trans and a very different wire scheme than older trucks. 04 seems to be flip a coin.
    Don't have any pics of the rear really. This is a few years back.
  25. Oct 18, 2021 at 6:51 PM
    #85
    TRDGen
    TRDGen Schnooogins
    Travis
    I thought yours was 05. So it's 04?
    That rear bumper black out yet?
  26. Oct 18, 2021 at 6:54 PM
    #86
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    03. Not gonna bother painting the bumper since it isn't staying long term. Next year I'm building tube bumpers.
  27. Oct 18, 2021 at 6:55 PM
    #87
    TRDGen
    TRDGen Schnooogins
    Travis
    So 03 got the first face lift? For some reason I thought it was 04.
  28. Oct 18, 2021 at 7:00 PM
    #88
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    03 had a lot of changes. Face lift, different trans, 13w brakes mid year, no side molding on the bed, maybe a few other things. 04 is first year of the double cab, the bastard year with some one year only parts, no vvti or 5 speed.
  29. Oct 18, 2021 at 7:10 PM
    #89
    TRDGen
    TRDGen Schnooogins
    Travis
    And here I thought the 00-04 all had the same 4 speed auto is 95-04 tacos and 96-02 4runners. A340 or A430 I think. Does yours have the ECT button?
  30. Oct 18, 2021 at 7:18 PM
    #90
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No fancy buttons on mine.
