Clay bar my truck
Discussion in 'Detailing' started by Deezy99, May 11, 2019.
Should I clay bar my truck to restore the paint?
  1. Have it professionally done
    5 vote(s)
    16.1%
  2. Do it myself
    25 vote(s)
    80.6%
  3. Don’t worry about it
    1 vote(s)
    3.2%
  1. May 11, 2019 at 7:28 AM
    Deezy99
    Deezy99 [OP] New Member
    Dave
    2010 tundra SR5 double cab
    Tonneau cover Vent visors Backup camera Bed extender
    After washing and waxing my tundra I noticed water spots. The shine is nice but up close it’s dull. Would clay bar help this situation?6098DD92-31A8-4449-AE93-7610A0A94A0D.jpg 39A73437-CE75-4503-8CCF-E11DBE092426.jpg
  2. May 11, 2019 at 7:39 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
  3. May 11, 2019 at 7:45 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    If water spots bother you, Clay, clean, ceramic coat. :thumbsup:
    War Machine likes this.
  4. May 11, 2019 at 8:13 AM
    Trooper2
    JR
    Thinking if there are spots after waxing, then the clear coat may me etched. A clay bar may help, if not maybe s compound. Then reseal with polish or wax.
  5. May 11, 2019 at 3:13 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    clay bar will remove the water spots and the wax as well. If you do clay bar the truck make sure to wax it again. If you can use a hose hooked up to soft water. or check out the thread about CR spotless from @War Machine
    https://www.tundras.com/threads/cr-...e-spent-the-money-so-you-don’t-have-to.44764/
    What do you think @Notachickmagnet ?
  6. May 11, 2019 at 3:39 PM
    six7zero
    six7zero New Member
    Pacific Northfresh 503
    15 SR5 Crewmax
  7. May 11, 2019 at 4:03 PM
    Faht Nocker
    Woody
    Milky Way
    if you already have clay bar and you do not have the nano mitt then try this. Get a damp chamois put the clay bar in the middle of it and wipe the whole truck down. No need for detail spray and the chances of dropping the clay bar are minimized.
    Deezy99[OP] likes this.
  8. May 12, 2019 at 2:15 PM
    War Machine
    War Machine SSEM # 5 3MW
    Yes sir a clay bar or mitt should do the trick. It’s handled all of the ones I’ve had to remove.
  9. May 13, 2019 at 4:26 AM
    briarpatch
    briarpatch New Member
    the pic looks like your truck is Pyrite Mica....same as mine. It's not an easy color to get to pop. As others have said, the clay will remove the wax you have on there now, so, unless it really bothers you, I'd wait until your current protection is at least degraded before I'd start over. Prep is the key, so if you've the tools and the inclination, a polish step after the clay will help with any swirls or micro-marring from the clay. Some do a panel wipe at this point, before proceeding to either sealant or wax.
    There are a lot of 'one step' products on the market, such as HD Speed, Blackfire AIO, Meguiars D166 and McKees 360, which combine some abrasives with protection. There's also the recently released Meguiars 3 in 1 wax, which may do the trick for you. Just out of curiosity, what wax did you use on your truck?
    Trooper2 and War Machine like this.
  10. May 13, 2019 at 6:50 PM
    owb2gp
    owb2gp New Member
    ID
    I was a novice until I found this site. I've clayed 4 vehicles so far with a mitt and it's very easy. Just use a lube or detail spray. Definitely plan a few hours to do this. Here are my steps from @War Machine and @Pudge.
    Clean wheels and tires.
    2 bucket wash
    Iron x for decontamination
    Clay bar or mitt or both (don't forget lube)
    I usually do a quick wash next
    CarPro Hydro2
    Dry entire vehicle
    Beadmaker or CarPro reload ( haven't used reload yet but I have some coming)
    Polish wheels
    Apply waxaddict Tyre feeder on tires and trim
    Boom
    Shit looks amazing once completed! Co-workers think I spend a ton to have my truck detailed.
  11. May 13, 2019 at 7:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Glad I could help out. It's amazing easy and not nearly as daunting and time consuming as most people think.
    I was a novice too before I learned from @SouthBoundSteve and @driverdog and now learning more from the active detail guys like @War Machine and @briarpatch . So many people (like I once was) are afraid of detailing their cars because of the time, effort, skill, and money it would take to do so. But the products that are available now make things so much easier and quicker than ever, there is no excuse to not get out there and try on your own vehicle. Going from clay bars to clay mits cuts out a good 3 or 4 hours of work. changing out the old paste waxes in favor of a nice spray sealant saves just as many hours and triples the longevity of protection, it's a no brainer. I now laugh when I see amour all, when I once would load up on it when it was on sale.
    Anything that you would ever need to know about detailing your truck can be found right here on tundras.com. I have really enjoyed doing my own detail jobs and people can not believe that I do it all myself and when I tell them what I use, they are blown away. If I had some spare time I would absolutely do some of my friends cars and make some quick cash while getting some practice and testing products
  12. May 14, 2019 at 4:31 AM
    War Machine
    Same here. Didn’t know a thing about detailing until I joined here. Those same guys got me interesting and taught me a ton. I took what they taught me and grew my knowledge from there. My old red Tundra did many runs through automatic washes, I’m sorry to say.
    Deezy99[OP] and driverdog like this.
  13. Jul 11, 2019 at 5:19 PM
    Kyk1e
    Kyk1e New Member
    Kyle
    Limerick, Pa
    2017 Toyota Tundra TRD Pro
    What type of “lube” would you recommend if I’m going to use a nanoskin mitt? I’m a novice when it comes to the clay bar. I’m doing as much research as I can before I do.
    Last wash I did the following:
    -2 bucket method with Adams mega foam
    -hand dry
    -Jesper powerlock sealant
    -wax
    -beadmaker
    Hope I’m doing it right. Any input would be appreciated.
    Thanks
  14. Jul 11, 2019 at 6:00 PM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    From my limited experience, i was happy with the Mothers synthetic(?) clay bar thingie...
  15. Jul 11, 2019 at 6:20 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    I’ve used mothers and chemical guys medium. I like the chemical guys a lot more, just seems like it lifted a lot more. I used mother’s quick retailer to lube the clay bar. Spray in front of the clay bar as you go, plenty of lube and wipe over a few times until it feels slick. As far as water spots, if clay bar doesn’t get rid of it try white vinegar. It’s what I use on mine whenever I go to wax it as I have tons of iron in my sprinkler system being on well water and the cars get it at least 2 times a week. For really tough water spots I use the chemical guys water spot remover but sparingly.
  16. Jul 11, 2019 at 6:43 PM
    War Machine
    You can buy a dedicated clay lube, or just get some detail spray from Walmart. That Nanoskin mitt is pretty easy to use, so don’t stress about it.
    As for the process you listed, cut the wax out altogether. It’s completely unnecessary with Beadmaker. If you really want to use wax though, put it on last.
    Also, I love Jescar Powerlock, but in my experience doesn’t bond very well with Beadmaker. Either Hydro2 or Gyeon Wetcoat work much better with it in my opinion.
    Powerlock is a fantastic product, but in my opinion works best when on it’s own, no wax or other sealant on top of it.
    Kyk1e[QUOTED] and Pudge like this.
  17. Jul 11, 2019 at 8:06 PM
    Pudge
    CT
    I for clay lube I have used mothers detail spray, Carprol ech20, soap and water, Griots speed shine. Everything worked fine in my opinion, this last time I used ech2o and some carpro immolube and I really liked the immolube, I also used it on my pads when I was buffing some scratches out. It's hard to describe how the immolube makes a difference but it is a petty cool product.
  18. Jul 11, 2019 at 8:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Wash with blue dawn
    Clay bar
    Wash with blue dawn again
    Dry
    Wax
  19. Aug 8, 2019 at 12:20 AM
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    So I'm planning on doing a full detail this weekend and have been doing a lot of reading on the forums. I don't have quite the detailing arsenal yet, but will in the future. As far as I know, my truck had never been fully detailed, do with what I got, here is my process. Let me know if I need to add or change anything.
    Wash with Dawn - two bucket
    Iron X
    Clay bar with lube
    Wash again
    Dry
    Meg's M0316 glaze
    Meg's black wax.
    I'm hoping to get Shine Supply Wise Guy, waxaddict Tyre feeder (if it comes back in stock), CG Mr pink, hydro2 and beadmaker.
    Hopefully my process will initially work until I get more stuff, thoughts?
  20. Aug 8, 2019 at 4:29 AM
    Trunk Monkey
    Trunk Monkey Truck's
    Steph
    2019 Tundra TRD PRO - VooDoo Blue
    Retrax One MX, NFab Predator Pro steps, Husky X-Contour mats
    You should never use dish soap for washing your car.
  21. Aug 8, 2019 at 4:51 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It does a good job stripping wax off. When you clay and rewax you want all the old junk off
  22. Aug 8, 2019 at 6:14 AM
    briarpatch
    There are people who believe that, and people who don't. Typically, the water behavior you see after you wash with Dawn is a result of the surfactants in the soap more than it's ability to strip wax. There are 'strip' washes out there...Chemical Guys sells one (Clean Slate) and Adams sells one....neither do a very good job. You're better off buying something like Purple Power Vehicle and Boat Wash to help strip off old waxes/sealants. The clay bar will take care of anything that's left.
  23. Aug 8, 2019 at 8:00 AM
    Bust
    Bust New Member
    Shean
    Yes sorry, I forgot to mention that part. First initial wash with Dawn, then I would wash again with my megs shampoo. Other than that, does everything sound in place?
  24. Sep 30, 2019 at 6:08 AM
    josef
    josef Babe Magnet
    Josef
    Victoria TX 77904
    2002 tundra which I recently sold for $5,500 and bought 2019 limited.
  25. Sep 30, 2019 at 7:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    ive had good luck with mothers and adams clay
  26. Sep 30, 2019 at 10:05 AM
    briarpatch
  27. Sep 30, 2019 at 10:34 AM
    War Machine
    Any from a known brand like Mothers's, Meguair’s, etc is going to be good. I use a mitt instead. Makes the job a whole lot easier and it’s reusable.
    Nanoskin (AS-016) AutoScrub Fine Grade Wash Mitt https://www.amazon.com/dp/B00DOS0LH2/ref=cm_sw_r_cp_tai_EXJKDb26RPVJM
  28. Sep 30, 2019 at 11:33 AM
    Pudge
    CT
    I would recommend a good name brand clay like mothers, griot's, carpro, or meguiars if you wanna use real clay. But the new rage is synthetic clay mits or clay towels, or a pad like mothers speed clay. They are cheap and work just as good as clay and are much easier to use and faster.
    sunnysideTRD and War Machine like this.
