Getting ready to Swap HU
Discussion in 'Audio & Video' started by zookaroo, May 9, 2019.
  1. May 9, 2019 at 11:05 AM
    zookaroo
    zookaroo [OP] New Member
    Shawn
    2019 Tundra 1794
    Just a few questions Before I make the purchase
    Does the wattage matter from the HU, I have the JBL system? If so what speakers does the HU run?
    Also what mounting kit matches up the best? (The Scorche from the Pics I seen the it appear off in color and does not line up with the other trim)
    Opinions on these HU models
    https://www.crutchfield.com/p_500ILX107/Alpine-iLX-107.html?avf=Y
    https://www.crutchfield.com/p_158XAV210/Sony-XAV-AX210SXM.html?avf=Y
    https://www.crutchfield.com/p_130AVW4500/Pioneer-AVH-W4500NEX.html?avf=Y
  2. May 9, 2019 at 11:14 AM
    TheBeast
    TheBeast The Beach
    I like Metra mounting kit better. just get the crutchfield ready harness and it will plug your new HU straight to your current system. Make sure to tell them you have JBL system.
    I went with the new Alpine ILX-W650.
    I do the install myself but that's because I rewired the whole truck anyways.
    https://www.crutchfield.com/p_500ILXW650/Alpine-iLX-W650.html
    https://www.crutchfield.com/p_264PASCON/Crutchfield-ReadyHarness-Service.html
    however if you need to retain steering wheel audio commands you will need to add a Maestro or Axxess device.
  3. May 9, 2019 at 1:31 PM
    tundraal
    tundraal New Member
    The Pioneer has a clear resistive screen, which is not favored by most. The Alpine has the better capacitive touch screen.
    For the money, I'd probably go with something like this - https://www.crutchfield.com/p_113DDX9705/Kenwood-DDX9705S.html?tp=20217
  4. May 9, 2019 at 1:36 PM
    TheBeast
    TheBeast The Beach
    this is a great choice too. Has the Maestro compatibility and 2 USB out as well.
  5. May 9, 2019 at 1:45 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    My vote is the Alpine, because of the capacitive screen. I resistive Car Play screen would be infuriating, I think.
    I'm looking at the same Alpine model for Wireless Carplay
  6. May 9, 2019 at 3:03 PM
    zookaroo
    Shawn
    2019 Tundra 1794
  7. May 9, 2019 at 3:04 PM
    zookaroo
    Shawn
    2019 Tundra 1794
    Thanks everyone for the input, does HU actually power any of the speakers if you have the JBL?
  8. May 9, 2019 at 3:52 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    No, it does not
  9. May 9, 2019 at 4:12 PM
    zookaroo
    Shawn
    2019 Tundra 1794
    I guess then how does the system benefit getting louder? Most say the system sounds way better and louder just changing the HU. Sorry If it seems like a dumb question.
  10. May 9, 2019 at 4:30 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Believe with non JBL new HU is 50 watts x 4 vs. maybe 20 watts with stock HU.
    New HU only with JBL will be passive or Low powered, using existing amp for power, hence not much if any improvements.
    If you could bypass the amp you may get improvement, not sure what JBL system amp rated at.
  11. May 9, 2019 at 5:49 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
