Bilstein 5100 front struts with Eibach springs
Discussion in 'Suspension' started by Paul344, Apr 24, 2019.
  1. Apr 24, 2019 at 5:32 PM
    Paul344
    Paul344 [OP] Just a Dog
    Paul
    2012 Black Crewmax Tundra Platinum
    Headlights (Ebay) don't do it! Eibach front lift springs, Bilstein 5100 Struts and Shocks. Set on lowest groove. 3" in the front. Front sway bar lower kit.
    I purchased the Bilstein 5100 series front struts and rear shocks for my 2WD 2012 Crewmax Tundra. After receiving this package I decided to buy new springs. I was going to buy stock, but then found the Eibach front lift springs. Reading that these were for their struts I called Eibach about using these with the Bilsteins. The technician told me they would be fine with the Bilsteins, but only use the two lowest settings. I was not ready to buy bigger tires or shackles, so I put them on the lowest setting. My truck is stock, but is a Platinum so probably weighs the most for a stock Tundra, but this raised the front 3 inches and made my truck level. This combo works well on paved surfaces. It is not a harsh ride, very smooth in fact. Very happy with the outcome. I have not been off road yet.
    To do it all over I would have just bought the complete kit from Eibach, but if you already have the Bilstein 5100 series this springs are a great add on.
  2. Apr 24, 2019 at 5:34 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Thanks for the input, can we see a picture of your Tundra?
    And welcome to the club!
  3. Apr 24, 2019 at 6:00 PM
    Paul344
    Paul
    Thanks, photos
    CaptSpaulding likes this.
  4. Apr 24, 2019 at 6:48 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Glad it worked out. Going to do the same thing and get the top strut shock mounting plates so I can get everything together and not fool with taking the OEM ones apart.
  5. Apr 24, 2019 at 7:15 PM
    Paul344
    Paul
    I did the same. I bought the KYB top strut mounts from Rock Auto.
    VTYOTA likes this.
  6. Apr 24, 2019 at 7:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Shocks
  7. Apr 24, 2019 at 7:20 PM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Your Tundra is neither red nor a 2015.
  8. Apr 24, 2019 at 7:26 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Great looking truck, it sits much better now too.
  9. Apr 24, 2019 at 7:31 PM
    Paul344
    Paul
    Thanks, next wheels and tires.
  10. Apr 24, 2019 at 7:48 PM
    Paul344
    Paul
    Okay, I understand front shocks. Long story on the 2015 Red Tundra, I have the 2012 Black one now.
  11. Jul 6, 2019 at 5:11 AM
    Paul344
    Paul
    Here is an update after the new wheels. Installed KMC XD series Heist (XD818) 18" x 9" with 30m+ offest. Goodyear Wrangler UltraTarrain 285/65-18. I have no rubbing. The next set of tire I buy will be 295/70-18. Not to aggressive, but I like the way it turn out. The shock setup and springs in the front are great. I would like to do something more in the back for towing. I am thinking air bags.1.jpg 2.jpg 4.jpg
    Zeke82 likes this.
  12. Feb 23, 2021 at 12:08 PM
    Ianstundra
    Ianstundra New Member
    Ian
    Have you taken it offroad yet? How was it? Were there any problems? And has anyone else done this?
  13. Feb 23, 2021 at 2:05 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Yes the OP mentioned what Eibach said about bottom 2 notches BUT it is important to note that there still very easily could be an issue with block height. IMO I'd want to check that before going out romping and potentially damaging a shock. Just my 2 cents.
  14. Oct 13, 2021 at 3:57 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Still have these rims?
