Help me get rid of these chrome wheels.
Discussion in 'Wheels & Tires' started by markg, Apr 17, 2019.
  1. Apr 17, 2019 at 7:35 PM
    markg
    markg [OP] New Member
    Mark
    NC
    2007 TRD
    Humm, not bad, but I also want to change the offset a little
  2. Apr 17, 2019 at 7:38 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Save some money and just powder coat them.
    Not my picture
  3. Apr 17, 2019 at 7:42 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Understood, I think these are +50 but not positive. I have SCS SR8s in gun metal and they are +25, which I think is the perfect offset, especially with the flares you have. I want to add flares myself.
  4. Apr 17, 2019 at 7:42 PM
    markg
    Mark
    NC
    2007 TRD
    Now thats an idea.
    Do they make spacers so i can get them set out somewhat?
  5. Apr 17, 2019 at 7:47 PM
    RickC
    Rick
    Knoxville TN
    yes, 1" and 1.5". The 1" are tricky because the original lugs will protrude past the spacer and hit the back of the wheel, unless the wheel has the space to clear the lugs, from what I have read online. I think the factory wheels do have the crevice design that allows the 1" spacer. One inch is 25mm, btw.
  6. Apr 17, 2019 at 9:02 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I've got a set of these that are going up for sale before much longer. Plus I've got a brand new set, still in the box oem TRD center caps for them. What part of nc are you located? This is not actual pic of the wheels I'll be selling, just the exact same wheel.
  7. Apr 17, 2019 at 9:23 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    When I got my TSS with the TSS black wheels I believe they were about +52 offset and sat just inside the fender wells. Went with a +20 when I purchased aftermarket wheels. Sorry I don’t have the same angle pic of the originals but you can see the difference.
    E263910A-224B-4598-97B0-237C5CF36F09.jpg 75AC3F96-DC39-4B66-9A23-1C0AB5D659E2.jpg
  8. Apr 18, 2019 at 7:18 PM
    markg
    Mark
    NC
    2007 TRD
    What do y'all think about this one?
  9. Apr 18, 2019 at 8:16 PM
    ToyLC
    ToyLC New Member
    Yes, see my build in my signature below, I did 1” spacers.
  10. Apr 19, 2019 at 5:24 AM
    markg
    Mark
    NC
    2007 TRD
    Yep, da chrome gotta go.
    Found this, (a picture is worth a thousand tech book pages, LOL)
    So, with the rims i have, +60 the wheels are set inside the wheelwell somewhat far.
    With a +25 (as suggested) it will give me +35 difference toward the outside of the wheelwell.
    With less + offset they will set farther toward the outsid of the wheelwell.
    It all makes sense now. (Honestly, I was very confused with all this offset stuff before i found this pic)
    joonbug[QUOTED] likes this.
  11. Apr 19, 2019 at 5:31 PM
    markg
    Mark
    NC
    2007 TRD
    What size tire? any mods to the front bumper or front mud flaps?
    I went to our local wheel/truck shop today and was ready to get the 20" x 8" +20 offset with my stock tires P275 / 55R20 and with the calculation showing the wheels would be 1.6" father out, the guy said it will rub the front fender plastic and the front mud flap. we went out to measure, I'll agree, it is close. Then he said in reverse, it is more than likely going to rub (all only while turning). He said they can space the bumper forward and I could cut the bulge out of the mud flap. (whats the use in a mud flap with a hole cut in it)
    Anyway, are you getting any rubbing while turning?
  12. Apr 19, 2019 at 7:21 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    No mods done and no rubbing. It’s close but those are the tires that came on the truck when I bought it new. Wheels are 20 x 10, Tires are 285/55 R20. That’s with the wheel cranked all the way left.
    39CCC58C-25C5-4A56-91E6-7FC53C03735B.jpg 405550BC-FE9C-4EE0-9191-DD37C1850C56.jpg
  13. Apr 19, 2019 at 7:40 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Sorry.....20 x 9 @markg
  14. Apr 19, 2019 at 7:46 PM
    markg
    Mark
    NC
    2007 TRD
    Damn, that is close.
    And I have 275 tires so, i will be .2" less then you (.25" will give me almost 1/4" more space)
  15. Apr 19, 2019 at 8:13 PM
    easleycrawler
    Travis
    285/55r20's also. 20x9 +50 offset. Zero rubbing.
  16. Apr 19, 2019 at 8:17 PM
    markg
    Mark
    NC
    2007 TRD
    Thanks,
    +50 is almost stock (+60). I'm thinking of doing +35 which would give it a 1" wider stance. I'm scared of the +20, LOL :notsure:
  17. Apr 19, 2019 at 8:23 PM
    easleycrawler
    Travis
    There is a guy on here with 20x9 0 offset with 275/55r20's. Says it only rubs while in reverse turned all the way.
  18. Apr 19, 2019 at 8:24 PM
    markg
    Mark
    NC
    2007 TRD
    :eek:
  19. Apr 19, 2019 at 8:40 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Yes I would do 20 x 9 but you will be fine with +20 offset on 275 tires.
  20. Apr 20, 2019 at 6:20 AM
    #50
    easleycrawler
    Travis
  21. Apr 20, 2019 at 6:34 AM
    #51
    markg
    Mark
    NC
    2007 TRD
  22. Apr 22, 2019 at 5:17 PM
    #52
    markg
    Mark
    NC
    2007 TRD
    Ok, after measuring, checking, shopping and a lot of research, even spoke to a guy at Fuel and Chris at Autoanything on conference call
    They agreed the 20x9, +20offset and the 275/55R20 will fit without rubbing.
    The guy at Fuel said the Fuel Vapor D569 was actually made for the Tundra (no lift or level)
    Fuel website doesn't even show the wheel with the +20 and 5x150 Bolt pattern in the matte black with dark tint surface.
    Just got these ordered today.
  23. Apr 22, 2019 at 5:25 PM
    #53
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Heads up...Tundras are 5 lug not 6 lug
  24. Apr 22, 2019 at 7:21 PM
    #54
    DCB500
    DCB500 New Member
    Oklahoma City
    Any of the 20 x 9 fuels should fit in the +20 with that size tire.....any other brand also for that matter
  25. Apr 22, 2019 at 7:40 PM
    #55
    markg
    Mark
    NC
    2007 TRD
    Thanks for assist.
    Keeping my fingers crossed
    :fingerscrossed:
    Last thing I want is a :crapstorm:
  26. Apr 26, 2019 at 8:32 PM
    #56
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    @DCB500 do you still have those tss rims laying around?
  27. Apr 26, 2019 at 9:05 PM
    #57
    DCB500
    DCB500 New Member
    Oklahoma City
    I don’t....the place where I purchased my fuels had a guy that buys wheels so they bought them from me and took them off my bill for the new wheels.
  28. Apr 26, 2019 at 9:08 PM
    #58
    easleycrawler
    Travis
    Where are you located?
  29. Apr 26, 2019 at 9:10 PM
    #59
    DCB500
    DCB500 New Member
    Oklahoma City
    Oklahoma City
  30. Apr 26, 2019 at 9:12 PM
    #60
    easleycrawler
    Travis
    Ok. I'll be selling my 20" BBS wheels soon. But not really wanting to ship. Heck, you might not even be interested in them.
