2010 RAV4 Weird Shifting
Discussion in 'Other Toyota Vehicles' started by alpinepro4, Sep 13, 2018.
  1. Sep 13, 2018 at 10:14 AM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I noticed driving my wife car the other day I get a weird downshift. This happens at slower speeds. Transmission fluid is at normal level. Any ideas of what causing this?
  2. Apr 20, 2019 at 2:28 PM
    alpinepro4
    Pat
    So we moved up and over a pass, meaning we have to drive a steep pass up and over everyday for work. Since driving up the pass my wife noticed her Rav4 downshifting and upshifting hard. We just replaced the sparks plugs for 120,000 miles maintenance. Now starting to wonder if the transmission need to be flushed and fluids changed. That seem right? I think she had is done before but I can't remember.
  3. Apr 20, 2019 at 2:46 PM
    alpinepro4
    Pat
    Update, looked back through the maintenance records and transmission fluid was changed in 2015. She driven 30,000 miles since then. Not sure what the fluid change intervals are.
  4. Apr 20, 2019 at 2:52 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    A semi anal retentive guy (not gal) will change auto tranny fluid/oil at 50,000 mile intervals. Including filter.
    What color is it on the stick? Pic?
  5. Apr 20, 2019 at 3:06 PM
    alpinepro4
    Pat
    Looks ok.
  6. Apr 20, 2019 at 4:11 PM
    15whtrd
    15whtrd Mr. Blonde
    Try something simple first. Try cleaning the mass aiflow sensor with some proper spray.
  7. Apr 20, 2019 at 4:47 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Intuitive transmission maybe.
    Starts acting in sport mode, hit the cruise control, will stop it. Wifes car does the same. It will shift normal.
    Maybe......
  8. Apr 20, 2019 at 5:20 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    V6 or i4? We have a 2010 v6 with 90k, trans fluid hasn't been touched (planning at 100k) and it shifts like new
  9. Apr 20, 2019 at 5:25 PM
    alpinepro4
    Pat
    It's the V6
  10. Apr 20, 2019 at 5:25 PM
    alpinepro4
    Pat
    Where is the mass air flow sensor. What spray do you suggest?
  11. Apr 20, 2019 at 5:48 PM
    alpinepro4
    Pat
    Found a video on how to get to the sensor, and to use mass air flow sensor cleaner. I should let the sensor dry or an hour before I reinstall it. Hopefully this will help.
    15whtrd likes this.
