Where do i trim this.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by R-C, Mar 23, 2017.
  1. Dec 31, 2018 at 8:21 AM
    Voyagermike
    Voyagermike New Member
    California
    Sorry no experience with these. Didnt know they made them until after I trimmed my liners. If I would have known before I trimmed I would have purchased them. They seem to make great products. And have heard nothing but positive experiences.
    georgiey22[QUOTED] likes this.
  2. Dec 31, 2018 at 8:32 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Thanks Mike. I’ll share some details and photos after I complete the install in the next week or so. Looks like an easy install with the benefit of maintaining infrastructure and plenty of clearance for my 34” tires.
    Voyagermike likes this.
  3. Jan 2, 2019 at 7:18 PM
    Tundrool
    Tundrool New Member
    18 cm trd silver sky
    Got my 1/4” strut spacers in and well liners re-installed... everything fits now w/no rubbing... shop honored their original claim that they would make itright as promised... looks and feels perfect!! I suppose I will see if this minor mod affects anything long-term, maybe this is a good alternative to trimming heat gun etc... shall see
  4. Jan 3, 2019 at 12:03 AM
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    1.5 wheel spacer but get the 1.25
  5. Jan 6, 2019 at 8:24 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Sorry to hijack but I had to ask. All you guys adding tires and stuff...did any of you end up like me with my passenger rear tire sticking out of the wheel well more than the drivers rear?
  6. Jan 7, 2019 at 1:26 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have not added tires and stuff yet, but in checking out where I thought it would end up with different offsets, I have noticed that the stock left and right are different. The bed seems to line up perfect with the cab, so it must be the axle that is off by a bit.
    OR18TRD likes this.
  7. Jan 8, 2019 at 7:32 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    I’m going to start a #MeTooToyota movement regarding this BS. Truck shop I went to said they think they can get me pretty close to being right.
    Boerseun and OR18TRD[QUOTED] like this.
  8. Jan 30, 2019 at 10:35 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for posting!!!
    We work with quite a few Toyota dealerships and with the amount of trucks they have on the showroom floor they always build a few great ones but can't cut anything, stuffing the largest tires and wheels they can safely.. but always run into clearance issues at the lower front bumper. At their request We designed a few versions and finalized on what we have now. Simple install yet extremely effective on adding additional clearance. Thanks everyone!
  9. Apr 17, 2019 at 1:58 AM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    What size tires are yall needing to trim for? I dont want to trim anything. I'll take the front flap off but no cutting.
  10. Aug 29, 2019 at 1:33 PM
    SethMcK
    SethMcK New Member
    Seth
    2015 White Tundra 5.7L
    JBA long tube headers with BAMufflers' mids & 7" exhaust, 2019 Pro LED headlights, leveling kit, 20" wheels, retractable tonneau, remote start, blacked out emblems, TRD rear sway bar, all lights replaced with LEDs, lots of other little mods, still working on it...
    Voyagermike[QUOTED] likes this.
  11. Nov 23, 2019 at 2:20 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Bilstein 6112 at 2.5" w/ 1 Coach Builder Shim on each side JBA UCAs Bilstein 5160 Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Leer 100XR Decked Drawers
    Wanted to thank @BRNG ITT for posting the pics earlier in this thread. I got my liners cut and installed back in today pretty smoothly and it looks really clean.
    When I look at post #9 in this thread, I think missed a cut around the existing hole that has a metal reinforcement, which makes the outer side on mine warp a little bit.
    But, combined with the Coachbuilder bumper shims I also added, hopefully I'll have plenty of clearance for my future setup.
  12. Dec 13, 2019 at 10:49 AM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    Tried pulling my bumper off to do the ships myself, that was a mistake. Got everything unbolted and then couldn’t get the bumper off by myself.
    Mnorris1206 likes this.
  13. Feb 9, 2020 at 9:27 AM
    Mnorris1206
    08 tundra
    Just did bumper shims on my truck I left all the plastic attached then loosed all nuts on one side then the other but leaving one but barely on the other then pulled the loose side just enough to get shims in. Then did the same to the next side.
    Truck after shims
    TS1794 and jimbrophotodotcom like this.
  14. Feb 14, 2020 at 11:19 PM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    My bumper supports would not break loose at all. I ended up completely taking the bumper apart that was fairly easy and got them installed in about an hour doing it that way.
    Mnorris1206[QUOTED] likes this.
  15. Jul 10, 2020 at 12:54 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Thanks so much for this! Just wondering, I’ve seen others drill a hole in the yellow circle that I marked on your photo, but yours uses the factory hole. Any figment issues when putting the liner back on?
  16. Jul 10, 2020 at 12:58 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    Cancel that. I was looking at the something different. Thanks for the pics, I’m looking to do this project this weekend!
  17. Jul 10, 2020 at 1:45 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    2020 MGM CM TRD Pro
    Lots.
    I installed the CoachBuilder Bumper Shims as part of the CB Pro Kit. This moved my front bumper out by a good 1/2". To accomplish that I removed three of the four bumper nuts on both sides of the bumper then loosened the remaining nut almost all the way off on both sides. I removed this last bolt completely on one side and was able to push out the bumper and slide in one bumper shim then the second on that side. I restarted the nut on that newly shimmed side and then repeated the process on the other side. After all 4 shims were in place i reinstalled and torqued all the bumper bolt nuts. I did not have to remove the bumper using this process. After I installed 35x12.5 Toyo Open Country AT III's on the stock TRD Pro rims I had just the slightest of rub at full lock in reverse. I took a heat gun to the plastic liner and used a basketball to "roll" over the warmed/hot liner. That easily molded the wheel liner forward enough for complete clearance without ever cutting any plastic. If you look at the liner you can't even tell I "modified" it. If need be there is enough play in the wheel liner (on a 2020 at least) to remove the bottom screws of the liner under the plastic bumper end cap and push the liner forward and drill a new hole in the plastic liner to line up with the existing rivnut to hold it forward. You can get at least another 3/8" - 1/2" inch clearance this way without any cutting of the wheel liner. Good luck with your project this weekend.
  18. Jul 10, 2020 at 1:53 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    Got it. Yes, I have a very slight rub in full lock reverse. Do you have any pics of the liner after applying the heat gun method?
  19. Jul 10, 2020 at 2:12 PM
    TampaRD Pro
    Stanley
    2020 MGM CM TRD Pro
    Lots.
    After "modification" with heat gun and no cutting/drilling.
    mdrabicki likes this.
  20. Jul 10, 2020 at 2:53 PM
    #50
    junior
    junior Member
    Zach
    Santa Cruz, CA
    Word. Glad you got it sorted! If you look at my installed pic I had misaligned something so it buldged out a little bit in the middle—to fix it I know I had some recutting but I can't remember what exactly I did
  21. Oct 14, 2020 at 2:45 PM
    #51
    JeffC995
    JeffC995 New Member
    2019 Magnetic Grey Crewmax
    More than 3 years later and this post is still helping Tundra owners, namely me.
    Thanks you
    TS1794 and dpast88 like this.
  22. Oct 16, 2020 at 8:51 PM
    #52
    FFFvamos
    FFFvamos New Member
    Thanks! Trying this tomorrow.
  23. Oct 17, 2020 at 4:32 PM
    #53
    FFFvamos
    FFFvamos New Member
    Done. Thanks for the pics. Made it easy to figure out.
  24. Nov 4, 2020 at 2:38 PM
    #54
    mdrabicki
    mdrabicki New Member
    Mark
    2020 Toyota Tundra TRD PRO
    Thank you very much for this idea! I also used a heat gun and a small piece of 1" pipe to roll over the area that was rubbing and gently mold it into a curve towards the front like you. I never would have thought of this!
    jmdaniel likes this.
