LED Turn Signals
Discussion in 'Lighting' started by Trddude2017, Oct 13, 2018.
Led turn signals
  1. Yes, your experience with them.
    25 vote(s)
    80.6%
  2. No
    6 vote(s)
    19.4%
Multiple votes are allowed.
  1. Nov 8, 2018 at 1:00 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Okay - is there any other plug and play options like the Triton V6 bulbs?
    After Tundra front blinkers, Tundra rear blinkers, Tundra rear brakes, Lexus rear Brakes, Lexus rear blinkers, Lexus front blinkers - I’m over $600 LMAO
    ETA - I have the 2018 LED’s on the Tundra in front
  2. Nov 8, 2018 at 1:10 AM
    Boosted4runner
    WA
  3. Nov 8, 2018 at 8:45 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Yes I used these on my Honda
    http://www.vleds.com/shop-bulb-numbers/7443/7443-6-hv-a.html
    I also used vled resistors. Every car when converting signals from holegens to led will require resistors.
  4. Nov 8, 2018 at 10:21 PM
    Boosted4runner
    WA
    Dang. So you have to tap into your factory wiring? I know it’s just a t-tap, but I hate using those whenever possible.
  5. Nov 9, 2018 at 5:44 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If you don’t want to tap and buy the tritons and you don’t have to.
  6. Nov 30, 2018 at 5:24 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Finally, after an unexpected day off and the temps in the lower 70's, got the VLED bulbs in the OEM Tundra housings. As suspected but not comfirmed had to install resistors with the back turn signals to rid hyperflash. Have resistors with the front Tritons installed but didn't carry over. Thrilled beyond belief, I'm sure that a vehicle a mile back saw my turn signals last night. IMHO LED's in the back are the way to go.
    Picts are in the daylight but obvious improvement. Next step is the Third Brake light.
  7. Nov 30, 2018 at 5:25 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Driver side LED, Passenger side OEM
  8. Mar 26, 2019 at 4:16 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    What bulb did you get here. Didnt find it on this thread.
  9. Mar 26, 2019 at 5:04 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Still working fine but some of the reviews don’t look promising.
  10. Mar 29, 2019 at 8:04 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  11. Mar 29, 2019 at 11:37 AM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
  12. Apr 6, 2019 at 12:21 PM
    WrongwayUp
    WrongwayUp New Member
    Andrei
    working on them.
  13. Apr 15, 2019 at 5:55 PM
    woah62
    woah62 Resident Evil
    2017 Sunset Bronze Mica Tundra SR5
    @iHacker
    So I am installing these on my 2017 Tundra. I know down the road I plan on installing led turn signals in the rear. Will this resistor be okay to stay in the front and to use in the back when I add those? Or should I change the front and add a different one in the rear?
    These are the front turn signals
    https://gtrlighting.com/gtr-lighting-armor-series-7440-7443-led-bulbs/
    These are the resistors.
    https://gtrlighting.com/gtr-lighting-50-watt-6-ohm-gold-style-resistors-for-custom-installation/
  14. Mar 2, 2020 at 1:08 PM
    jp_over
    jp_over New Member
    Joe
    East TX
    2017 CrewMax SR5 4x4, white
    One of my front signals just went out so I'm looking to replace with a "plug and play" LED.
    Any long term updates for those who upgraded? I don't care about brighter, I just want LEDs to do exactly what the factory bulbs do but hopefully last longer (2017 SR5 with about 38k miles).
    Thanks!
  15. Mar 2, 2020 at 2:05 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Added the JDM Astars to my Canadian 2018 TRD Sport - no hyperflash and super bright. Five minutes to install. Highly recommend.
    jp_over likes this.
  16. Mar 10, 2020 at 6:39 PM
    TheHutchTTU
    TheHutchTTU Wreck 'Em
    North Texas
    2016 White Tundra Limited 4x4
    Reading through the thread @r1-superstar linked, it seems like it depends on whether or not your truck came with LEDs from the factory. If it didn't and you want a plug-n-play option you'll need to buy the VLEDs (https://www.vleds.com/vehicle-specific/toyota/tundra.html)
    jp_over[QUOTED] likes this.
  17. Mar 10, 2020 at 7:59 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Will be 2 yrs on front in May 20 and in November of 20 on the rear, VLEDS Triton with plug and play with resistors in front. And yes resistors in the back with the non Triton bulbs. Do not be afraid of resistors, and the price of VLEDS. Have LED front H/L and still need resistors on all 4 corners. Hyper-flash without and no Hyper-flash with resistors while installing. Have not re-visited since installation. As soon as VLED has the the 921 for the cargo lights and the 3rd brake lights I will complete the LED set up. good luck all,
    jp_over likes this.
  18. Mar 10, 2020 at 8:02 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I used JDM Astar bulbs and resistors. Switchbacks in front and regular in rear. You have to have a resistor at each light. No issues with them.
    jp_over likes this.
  19. Mar 10, 2020 at 8:37 PM
    TheHutchTTU
    North Texas
    They already have these. They list up to '17 but I would imagine they are the same for an '18.
    https://www.vleds.com/vehicle-specific/toyota/tundra/14-17.html
  20. Mar 10, 2020 at 9:11 PM
    #50
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Yes, just email VLED sales to make sure.
  21. Mar 11, 2020 at 5:15 AM
    #51
    jp_over
    jp_over New Member
    Joe
    East TX
    Thanks for all the input. I ended up just doing the DRL disable mod + new OEM bulbs and sockets (both sockets showed signs of overheating). By eliminating the daytime running lights (DRL) I have hopefully solved the overheating issue and thus won't have to replace bulbs and/or sockets as often.
  22. Mar 11, 2020 at 6:41 AM
    #52
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I like "hyperflash", more noticeable, I also run headlights instead of DRLs, drls not bright enough, I want to be NOTICED well before impacts!!! Plus no resistors = less amp draw on system, more power for Tunes!!!
  23. May 15, 2020 at 6:24 PM
    #53
    Sickining
    Sickining New Member
    Che
    San Francisco, CA
    2019 tundra CM Ltd
