T100 HELP (KICK PANEL FUSE DIAGRAM)
Discussion in 'Off-Topic Discussion' started by TXRailRoadBandit73, Apr 14, 2019.
  1. Apr 14, 2019 at 11:45 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Trying to find out and search the web on my kick panel fuse cover diagram, to identify what fuses are to what, to no avail on web search, I have a 15 amp fuse blade that's out, the cover been missing for a long time
    Slot #8 is a 15
    '97 T100 with 3.4 V6 4x4
    I have the Haynes manual but doesn't show what fuse is for what, calling anyone who has a T100 who has the cover or anyone that knows someone who has and can send a pic or anyone who has better web skills than I do to find out what fuse is to what, any help is much appreciated, Thank you!!!
  2. Apr 14, 2019 at 11:55 AM
    15whtrd
    15whtrd Mr. Blonde
  3. Apr 14, 2019 at 11:59 AM
    15whtrd[QUOTED] likes this.
  4. Apr 14, 2019 at 12:02 PM
    15whtrd
    15whtrd Mr. Blonde
    One way to find out, pull a fuse from the diagram corresponding to your fuse block. If that fuse disables and jives with the diagram it should be correct. Try a few to make sure.
  5. Apr 14, 2019 at 12:07 PM
    Thanks
  6. Apr 14, 2019 at 12:25 PM
    @Roman would you have the panel? Or label?
  7. Apr 14, 2019 at 5:03 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    OK Friend. I just pulled the cover plate off of my fuse box on my 1997 T100 3.4 liter V6 4X4.
    For the slot you've got in the drawn red circle the winner is >>>>>>>> STOP 15A.
    If you want a photo of it DM/PM your cell and I'll text you a photo of the inside of the cover.
  8. Apr 14, 2019 at 5:08 PM
    Greatly appreciated!
  9. Apr 14, 2019 at 5:09 PM
    Let's see your T100!
  10. Apr 14, 2019 at 5:16 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    It's shows it 21 years. Though I'm the original owner and have taken good care of it. Somewhere around 265,000 miles (because I up sized the tires years ago I have to add approx. mileage to account for the low indicated reading on the odometer) and she just keeps going. I get at least two offers a year from random members of the public to buy it. But she's got the Mama Toyota factory manual 5 speed. There's just no getting rid of her. Just put Billy 4600's all the way around and she runs perfect.
    15whtrd likes this.
  11. Apr 14, 2019 at 5:23 PM
    346+ miles speedometer cable just broke few weeks ago, a/c compressor out (I want an OEM one) replaced all u joints from tranny on back, need to do front transfer case one's
    All new brake system needs be done, upper/lower ball joints not that there bad but needed, having trouble finding a fuel vapor pressure sensor for CEL
    15whtrd likes this.
  12. Apr 14, 2019 at 5:27 PM
    How big tire you go? I have Rancho RS5000 need to change, so 4600's better? I need to put more into T100, I'm done with Tundra for now
  13. Apr 14, 2019 at 5:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    265/75/16's. Have run that size for prolly the last 200,000 miles. The math says they are 8% larger in circumference than the stock size.
    I had the Rancho 5000's too before the Billy's. Better? Since I only drive on the road it's hard for me to say. I does have a wonderful firm ride now and I love that. No more having to be concerned about road shallow holes or short curbs. F it >>> hit it.
  14. Apr 15, 2019 at 10:34 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  15. Apr 15, 2019 at 10:45 AM
