Now closed! 10" JBL sub & box from tech12volts group buy.
Discussion in 'Deals & Group Buys' started by Pudge, Jan 4, 2019.
  1. Feb 21, 2019 at 8:38 AM
    #541
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    Agreed. 2 tips I saw that really helped.
    First, make sure the box is closer to the door than you think. The screw hole for the old box is a good guide. I'd say the box needs to be ~1 inch from it or so.
    Second, once the seat is in place, sit on it, then get off and thread in the rear passenger side bolt first by hand. Then tighten it down to barely tight. Then do the driver rear bolt next, same way. Then the other 2 front bolts. Once they are all hand tight, then torque them in the same order.
    Flush seat....done.
    Migraine likes this.
  2. Mar 6, 2019 at 1:30 PM
    #542
    TXTundra2722
    2015 Black Tundra
    Just got my sub installed and it sounds awesome with the amp through James! I had originally recieved a damaged sub from him, (not his fault, UPS treated it like Ace Ventura) and he was quick to send out a replacement. Thanks again James for the group buy discount and pudge for assisting him with notifying all of us.
    ZPMAN and Pudge[OP] like this.
  3. Apr 13, 2019 at 4:59 PM
    #543
    FlyByMike
    FlyByMike New Member
    2018 MGM Tundra Platinum 4x4
    Finally got around to installing my new sub, following Flying Dave’s instructions. Definitely an improvement over the stock sub and well worth the money!
    flying dave and Pudge[OP] like this.
  4. Apr 13, 2019 at 7:41 PM
    #544
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    It's really a solid bang for your buck. Some people have asked me if they add an amp to the stock sub, or changing the sub for another 8", or changing headunit will improve the bass in their truck. I really can't imagine any of that can be done for $200 and certainly won't sound as good as it does with this sub and box. I was shocked when I finished my install.
    tja1080 and FlyByMike[QUOTED] like this.
  5. Apr 14, 2019 at 5:38 AM
    #545
    tja1080
    tja1080 New Member
    TJ
    Virginia Beach
    2016 Platinum
    Definitely best bang for the buck so far. But now after replacing the rest of the speaker, and the head unit, and adding an amp, I’m think of either upgrading this sub, or adding another...
    Pudge[OP] likes this.
  6. Jul 22, 2019 at 9:28 PM
    #546
    What the!?
    What the!? New Member
    2017 Pro
    I finally got a chance to install this box along with the Infinity amp James sold me.
    This box does not disappoint and neither does James. This man knows his stuff. I had a question about the install on a non-JBL system and he was very responsive to my email.
    Bottom line, his prices and excellent customer service has won a customer for the long haul. I’m going to buy everything for my audio needs from him.
    Thanks again!
    Rica25 likes this.
  7. Sep 6, 2019 at 6:43 AM
    #547
    zookaroo
    zookaroo New Member
    Shawn
    2019 Tundra 1794
    So, I believe the consensus on this post is the Blue wire is positive and the white wire is negative. I actually have been needing the positive and negative wires for the front tweeters, So I went to my Dealership service and they pulled up the wire schematic for me and gave the colors. Also I was curious about the subwoofer since I have this replacement as well. We looked it up and the white wire is positive and blue is negative.
  8. Nov 4, 2019 at 3:46 PM
    #548
    randman70
    randman70 New Member
    I need this!! Will this fit in a 2020?
  9. Nov 5, 2019 at 5:36 PM
    #549
    randman70
    Any chance we can get another group buy going?
  10. Nov 5, 2019 at 6:41 PM
    #550
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    Yes. Please. Take. My. Money.
  11. Nov 22, 2019 at 3:03 PM
    #551
    randman70
    2 ohms for 2020 JBL.. I feel I’m gonna need a separate amp for the sub, it’s a little better than the stock sub, but... and I’m sure it’s capable of so much more.
  12. Sep 19, 2020 at 7:07 AM
    #552
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I know this is a year old thread... I’m thinking of buying one of these subs for my 2020 Trd Pro (My 2010 Tacoma JBL stereo sound better than this Tundra JBL system!)
    For those that bought just the sub upgrade with JBL system have you felt the need to upgrade anything else since replacing the sub??
  13. Sep 21, 2020 at 5:07 AM
    #553
    FISHN43
    FISHN43 New Member
    Ohio
    Crickets......
    Anyone??
  14. Sep 21, 2020 at 6:39 AM
    #554
    You’ll want to upgrade the amp for sure.
    rockmup likes this.
  15. Sep 21, 2020 at 2:29 PM
    #555
    FISHN43
    FISHN43 New Member
    Ohio
    An for the sub or for the whole system?
  16. Sep 21, 2020 at 2:49 PM
    #556
    I had just the sun and speakers which was great, but it needed the amp to make it even better
  17. Sep 21, 2020 at 2:59 PM
    #557
    FISHN43
    FISHN43 New Member
    Ohio
    Ok, thanks. I sent a message to James @ tech12volts the other day. Waiting to hear back from him.
  18. Oct 9, 2020 at 12:46 PM
    #558
    Elduder
    Elduder New Member
    Anyone happen to know the price for just the box w/o the sub?
  19. Nov 22, 2020 at 8:12 PM
    #559
    03socaltundra
    03socaltundra New Member
    2013 Rock Warrior
    Anyone put this in a 2013 or earlier? Wondering how the figment is.
  20. Dec 29, 2020 at 6:46 PM
    #560
    Bluesttape
    Bluesttape New Member
    Jesse
    2021 Grey Platinum
    Floating this thread back up to the TOP!
    I love the idea of a $200 drop in replacement to bring the sound up from ~junk. That said, I also don't want to spend $200 if I am going to want to improve later. Buy once, cry once they say. Although, I'm not looking to dump a bunch of dough after buying a `21 Platinum.
    Is it worth it? And is it good enough to not want more?
  21. Jan 2, 2021 at 8:29 AM
    #561
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    If you don’t plan to do anything else to the system this setup is perfect. It addresses the main deficiency of the factory JBL system (severe lack of bass). If you plan to do more, i.e. full speaker/amp replacement the box here is good but James can build you something more substantial.
  22. Jan 2, 2021 at 6:10 PM
    #562
    Brooksman9
    Brooksman9 New Member
    Patrick
    2020 Platinum Tundra
    Just installed my sub. Used white to negative and blue to positive. Is this correct?
  23. Jan 2, 2021 at 6:44 PM
    #563
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I have just placed an order for this, how long on average does it take to get. Thanks.
  24. Jan 3, 2021 at 7:37 AM
    #564
    Brooksman9
    Patrick
    I think it was around two weeks from order to door IIRC.
    Omohundro likes this.
  25. Jan 4, 2021 at 1:40 PM
    #565
    Brooksman9
    Patrick
    Anyone?
  26. Jan 4, 2021 at 5:51 PM
    #566
    Omohundro
    Jody
    McMinnville TN
    So I don’t have mine yet but I’m looking through the forum and ran across this. Still looking to to verify it. 27285ADA-2984-4585-ABE3-BAE8472E721E.jpg
  27. Jan 4, 2021 at 5:55 PM
    #567
    Omohundro
    Jody
    McMinnville TN
    I see you found that lol, sorry. How about this. 2CA9A05A-3624-4F17-8FD4-457E7A5B752B.jpg
    Brooksman9 likes this.
  28. Jan 5, 2021 at 3:52 AM
    #568
    Brooksman9
    Patrick
    I sent James a message on Facebook and he replied the blue is positive and the white is negative so your last post is correct. That was how I had it hooked up. Works fine. Sub is an improvement over factory for sure. You can really tell the difference on better input. I have a lot of music from my computer that was downloaded here and there at different compression ratios and some sounds a lot better than others. I imagine if I still had XM it would sound better too. The factory system still lacks balls though. But that will have to be addressed at a later date.
  29. Jan 5, 2021 at 11:25 PM
    #569
    SilentSteven
    SilentSteven New Member
    2020 Platinum
    I can’t wait to receive my sub and install it. Will have to remember all the install tips in this thread
  30. Oct 8, 2021 at 4:54 PM
    #570
    Bergy24
    Bergy24 New Member
    Resurrecting an older thread with lots of info. I received mine today and had installed in 1/2 hour max. This thread was very helpful and made it very easy with no guess work. I put the seat on a small piece of 2x4 to eliminate poking the floor. James said that some 2021’s may have a smaller amp and the difference between oem and the new enclosure may not be very noticeable. I took a gamble and and while I have played with the settings a lot, it does seem to sound better with a little more punch. I’ll play around with it more tomorrow on a 2hr road trip. James was easy to work with and his communication was top notch. No issues with my seat lining up either.
