295/70r18 Cooper STT Fitment Issues BMC
Discussion in 'Wheels & Tires' started by CyberViking, Apr 7, 2019.
  1. Apr 7, 2019 at 6:05 PM
    CyberViking
    CyberViking [OP] New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Just got some new wheels and tires installed yesterday and had to do a slight BMC to accommodate them. I was wondering if anyone else had similar issues with this tire? I was rubbing the body mount on the outer tread lugs.
    I'm running a +20 Fuel vector wheel, 295/70r18 Cooper STT pro with an Eibach 2.5" coil-over setup. A 3" setup MAY have prevented it but it would've likely still been a few paper widths away (too close).
    Edit: This is on a 2018 TRD Sport model.
  2. Apr 7, 2019 at 6:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yeah those STTs run pretty big. Depending on your UCAs, you probably could’ve moved your wheels forward enough to clear with an alignment.
  3. Apr 7, 2019 at 6:29 PM
    CyberViking
    The Ozarks
    I'm no mechanic so I had no idea it was a possibility. Is that something that could be done with stock UCAs? It did seem to be worse after I got it aligned. I didn't go with a 3" lift in the first place because I wanted my alignment perfect; I had read of people having problems without aftermarket UCAs
    joonbug[QUOTED] likes this.
  4. Apr 7, 2019 at 6:31 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Running 0 offset 3in lift and 295 70 18 no cab mount chop just inner liner and mud guard.
  5. Apr 7, 2019 at 6:34 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I’m running 295/70R18 on cooper stt Pro. I have the same issue. Rubbing on the body mount just a hair but only on reverse. I have 2.5 fox coilovers.
  6. Apr 7, 2019 at 6:37 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  7. Apr 7, 2019 at 6:41 PM
    CyberViking
    The Ozarks
    Now that you mention it, it did seem to be only in reverse. It sounded horrible and I could see slight cuts on the lugs where it was rubbing on the tire. My body mount on the driver side was not welded entirely where it was rubbing so there was a sharpish lip that caused the minor gouging.
  8. Apr 7, 2019 at 6:59 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    Another thing is when I do a full lock on reverse then I don’t rubbed at all, it’s only when I do a 3/4 reverse. I’m planning to do a body chop in future.
  9. Apr 7, 2019 at 7:03 PM
    CyberViking
    The Ozarks
    Faht Nocker[QUOTED] likes this.
  10. Apr 7, 2019 at 7:06 PM
    CyberViking
    The Ozarks
    Yep a hard turn would've cleared mine too. I took a cutting wheel to the body mount; it actually turned out really well and I went over it with some paint to prevent rust. Eventually I'll get a plate welded in but for right now it'll do.
  11. Apr 7, 2019 at 7:09 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    I’m running +20 fuel assaults on 35x12.50’s on a 3” Toytec eibach Kit and I clear the body mount...
    That surprises me that you’re hitting, hope you can get that bad boy chopped soon!
  12. Apr 7, 2019 at 7:18 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I'm running method +25 with stt maxx 295/70r18
    On bilstien 6112s set at 1.9 inches 3rd setting.
    I clear my body mount by 1/4 inch and I have not hit it yet.
    I'm also surprised you're hitting I was planning on doing a bmc if mine didn't clear.
  13. Apr 7, 2019 at 7:21 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    As long as your camber isn’t maxed out, it’s possible. Should give you more caster too. Takes a good alignment shop that knows what they’re doing.
  14. Apr 7, 2019 at 7:24 PM
    Faht Nocker
    Woody
    Milky Way
  15. Apr 8, 2019 at 4:27 AM
    CyberViking
    The Ozarks
    Good call..I'll have to measure again from center wheel. If I have the same issue as this guy then I'll probably never order anything from Toytec again. I'm clearing now with the BMC but unfortunately now that I know it could be wrong, I'm going to have to fix it.
  16. Apr 8, 2019 at 5:17 AM
    Faht Nocker
    Woody
    Milky Way
    Sounds good. If your lift doesn't measure out... I would put a shim or two in there to help with clearance. Call toytec to confirm that is ok.
  17. Apr 28, 2019 at 8:56 PM
    Okietundra
    Okietundra New Member
    OKC OK
    2015 Silver Sky CM TRD OFF ROAD
    So would the stock trd rims (+60 I think) do ok with the 295 70s on a 3/1 level?
  18. Apr 29, 2019 at 4:10 PM
    CyberViking
    The Ozarks
    I doubt it. I'm guessing you'll rub on the UCAs but I could be wrong.
