Lift options
Discussion in 'Suspension' started by ytank1, Oct 5, 2016.
  1. Oct 5, 2016 at 4:19 PM
    ytank1
    ytank1 [OP] New Member
    MD
    Good afternoon Tundra fam. I was looking into getting my crewmax lifted and stopped by a local shop to ask questions. They recommended a Ready Lift 3 front and 2 back kit. Does anybody have experience or have the same kit on their truck? They are claiming the ride will be close if not same as factory. Also do I need to install after market shocks with this kit? Im also looking into getting rims and tires after the lift and looking at a Fuel 20 by 9 with +1mm offset with Toyo open country R/T 275/65/20, 34.1 tall by 11 wide. The measurements were given to me by the shop when I told them the look Im going for which is a slightly aggressive stance with about 1 inch or a little less sticking out past my fender. Any insights and or advice is greatly appreciated. Thanks in advance.
  2. Oct 5, 2016 at 4:35 PM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    We always prefer our customers to get an increase in performance along with the lift they are looking for. We would recommend doing a replacement coilover and upper control arm (this will allow you 3" of lift in the front) and you can either day an add-a-leaf, expansion pack, or block in the back if you are looking to lift the rear. A spacer is simply going to push your suspension down because you are shoving a shock with a spacer on top into a spot that was design for the factory size shock. This is going to give you less down-travel equating into a rougher ride. A bolt-in 2.5" coilover is going to give you a smoother ride and its going to help your ride quality when you move to the 20" rims.
    ytank1[OP] and Law323 like this.
  3. Oct 5, 2016 at 4:47 PM
    Look at toytec.com everyone here has good things to say bout it...and coachbuilder rear shackles I have rough country 4.5" lift it's rough alright I wana switch over to coil overs n shackles get some more opinions
    ytank1[OP] likes this.
  4. Oct 5, 2016 at 4:53 PM
    Spoony1
    Spoony1 New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    Here is a picture of mine I have a 4 1/2 inch BDS lift. The ride is great.image.jpg
  5. Oct 5, 2016 at 7:04 PM
    Inferno16
    Inferno16 New Member
    read this thread. Im Inferno16. Cost and pics included
    https://www.tundras.com/threads/3-1-level-lift-w-bilstein-5100.7340/
    ytank1[QUOTED][OP] likes this.
  6. Oct 6, 2016 at 11:58 AM
    ytank1
    MD
    Thanks fellas
  7. Oct 7, 2016 at 6:21 AM
    Blankcheese
    Blankcheese New Member
    Johnny
    '16 SR5 DC 4WD
    Wondering how tall your garage door is?
  8. Oct 7, 2016 at 9:04 AM
    Spoony1
    Spoony1 New Member
    They are 7ft doors.
