Question/Advice : 2016 SR5 MGM CREWMAX 4x4 / 6" LIFT / 35's / Rockstars
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Pcoz, Apr 2, 2019.
  1. Apr 2, 2019 at 12:29 PM
    Pcoz
    Pcoz [OP] New Member
    Patrick
    Southern MD
    TRD Grill and Hood Bulge
    So, I'm finally looking to pull the trigger on lifting my truck. I went down to the local custom shop and got a quote for the following:
    6" Rough Country Lift / No Struts
    Nitto 35" Nitto Ridge Grapplers
    Rockstar 20" rims Matte Black / Machined
    The total was $5,300 which included all the accessories, replacement TPM's, etc. and an alignment.
    My questions are:
    Is this a good set up ?
    Is this a reasonable price ?
    Any input, insight, or comments and recommendations would be greatly appreciated !
    Thanks in advance....
    Pinay likes this.
  2. Apr 2, 2019 at 5:29 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    To me it depends on what youre willing to spend for what the lift will do. Are you planning to do any wheeling at all on trails or off-road? If you say yes, then spacer lift is not the way to go. I have a 6" rough country lift and am about to spend more than your cost to fix it right so i can get on the trail. Spacer lift is absolutely no good on the trail. If you plan to be a pavement princess (not saying its a bad thing) then you will be fine and just a matter if if your budget can handle the cost.
    TXRailRoadBandit73 and Pcoz[OP] like this.
  3. Apr 5, 2019 at 5:16 PM
    Pcoz
    Patrick
    Southern MD
    Thanks for the input. Yeah, Pavement Princess for sure, lol.
    On top of that, my wife was not too keen on me spending over $5K on this....something about the cost of a vacation or something, blah, blah, blah :censored:
    Anyway, I'll look into a level kit or cheaper 3-4" lift with some decent rims and tires on a budget.
    Time to start diggin' through this forum for ideas !
    Thanks again !
    Ted4311 and Pinay[QUOTED] like this.
  4. Apr 5, 2019 at 5:24 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yeah, thats a common issue with members on the site! :rofl:
    Let us know how else we can help you spend your money!!
  5. Apr 5, 2019 at 5:42 PM
    Mnorris1206
    08 tundra
    I personally started with that same exact lift I love a tundra lifted alot but do yourself a favor and get the lifted struts . @Tundra4Pinay is right you do not want to off road it at all . will not work out for you. Here is my truck 6" rc lift now with the struts. Much better ride. Screenshot_2019-02-18-07-16-37-1.jpg
  6. Apr 5, 2019 at 5:56 PM
    @Pcoz are you 4WD? If so, your rear crossmember will be cut, once that's done you won't be able to go lower in the future less you know a good welder, and if you don't want that, go 4" or lower, check out @Toytec Lifts you can do a 3/1 lift and still have 35's
    Pcoz[OP] and Mnorris1206 like this.
  7. Apr 5, 2019 at 6:00 PM
    Mnorris1206
    08 tundra
    I guess that's very true. I am one of the few lucky or unlucky few that didn't have to cut the rear crossmember . But yes the new lift kitsch from rough country you have to do this. I dont like the idea but all 6" and up kitsch do it. But you can also have just as much in a 4" kit all depends on what you want for your truck and budget.
  8. Apr 5, 2019 at 6:01 PM
    Pcoz
    Patrick
    Southern MD
    Thanks ! I was just looking at that. I'll definitely check that out.
    I was also looking at the Rough Country 3.5" lift. It's much cheaper than the 6" and looks like something I can do myself. Now I'm looking at what rims and tires will work....on a wife friendly budget :thumbsup:
  9. Apr 5, 2019 at 6:05 PM
    Customwheeloffset.com
    andy9743 and Pcoz[QUOTED][OP] like this.
  10. Apr 5, 2019 at 6:07 PM
    Mnorris1206
    08 tundra
    Looks good I still suggest doing the 3.5 lifted struts if you can you will have a less bumpy front end
  11. Apr 5, 2019 at 6:13 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    My crossmembers are not cut and it’s a Rough Country lift, only for another two weeks...
  12. Apr 5, 2019 at 6:14 PM
    You 2wd or 4wd?
    Pinay[QUOTED] likes this.
  13. Apr 5, 2019 at 6:14 PM
    Mnorris1206
    08 tundra
    Yep you and I have the "older" kit
  14. Apr 5, 2019 at 6:14 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    4x4
  15. Apr 5, 2019 at 6:16 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I wish I had that kinda luck with the lottery, cuz this suspension makes me wana rob a bank!
  16. Apr 5, 2019 at 6:16 PM
    I see your a 2015 I'm a '14, we may have the older version lift kit, a RC tech told me that this wasn't needed to be done, so technically we can take this kit off or we can get the kit that's can make us 4.5"
    Mnorris1206 and Pinay[QUOTED] like this.
  17. Apr 5, 2019 at 6:18 PM
    RC tech we can go 4.5" which would be rear blocks, U bolts, front spacers believe under $250
  18. Apr 5, 2019 at 6:18 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yeah I’m not sure Ima like going lower than my stance currently, but I want to get on trails so I guess it’s a trade off
  19. Apr 5, 2019 at 6:21 PM
    Mnorris1206
    08 tundra
    My main issue is I love the ride height now I'm at 6" I dont think I would go back down. Well the only way I would is to buy another truck lol
  20. Apr 5, 2019 at 6:24 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Umm, I’m 5’2” and I don’t wanna get closer to the road :rofl:
  21. Apr 25, 2019 at 8:21 AM
    drirules
    drirules New Member
    andy
    2014 Grey Tundra SR5 TRD 4x4 crew cab
    6 inch pro comp coil over lift kit, TRD air intake, 36 x 12.5 18 tires, Fuel Maverick 18 X 9 rims, Bushwacker fender flares, Rhino front bumper with 12000 pound winch, and 4.88 Nitro gears.
    The other hidden cost is having to re-gear everything. I got the 6 inch coil over pro comp kit with 35" Mickey Thompson tires, and I noticed my transmission kept hunting for the 6th gear. Turns out the bigger tires drops your RPM's just enough to prevent the 6 gear from kicking in. Not to mention the loss of power. Re-gear cost me another 3500.00 but this was 4 years ago. Just something else to consider
  22. Apr 25, 2019 at 8:31 AM
    I keep seeing on here, if your 37's on up that we should re-gear????
  23. Apr 25, 2019 at 10:28 AM
    drirules
    drirules New Member
    andy
    The threads I read said 35 inch tires and up. This was years ago when I lifted my truck. I started experiencing those problems with 35 inch tires.
  24. Apr 25, 2019 at 10:38 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    I know the feeling... Who gave wives so much power... Mine has the look and I instantly regret bringing up whatever crazy idea I had.... Good luck with the lift decision and the backlash from wifey!!
