35s, 295s, or 305s
Discussion in 'Wheels & Tires' started by Billthecat67, Mar 17, 2019.
  1. Mar 17, 2019 at 12:55 PM
    Billthecat67
    Billthecat67 [OP] New Member
    • I have a 2018 TRD Sport and have received but not installed a Readylift SST 4 inch lift along with 20x9 +18 Anthem wheels. Really having a tough time on choosing tires. I want an AT or hybrid tire and I want the look of 35s with just an inch or two outside my fender. How much trimming should I expect to have to do for each of the listed above sizes? Any input would be appreciated.
    jewsNbrews likes this.
  2. Mar 17, 2019 at 1:09 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Try hankook mt 315/75/16
  3. Mar 17, 2019 at 2:54 PM
    Billthecat67
    Thanks but my wheels are 20x9.
  4. Mar 17, 2019 at 3:12 PM
    TheBeast
    TheBeast The Beach
    with a 4 inch lift, you gotta go 35"s. gotta fill that wheel well. need some aggressive hybrid tires like Toyo R/T or Nitto Ridge Grapplers imo
  5. Mar 17, 2019 at 4:04 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    can't wait to see that lift installed. thats the one im thinking of doing !
    mjgonz1 likes this.
  6. Mar 17, 2019 at 4:17 PM
    mjgonz1
    mjgonz1 New Member
    Michael
    Milwaukie Oregon
    2018 trd sport white crewmax
    Interested in trd dual exhaust
    I've got the same truck, looking at either the BDS 4.5 inch or a 3 inch coil over. Undecided but definitely got to go with 35's no question and should have light trimming of front mud flaps and lower plastic on bumper. Have you looked at the gallery of tundras on customoffsets.com? There is a few '18 tundras with different size lifts to view
  7. Mar 17, 2019 at 4:28 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I’m always in Custom Offsets page lol.
    TundraDude4x4 and mjgonz1 like this.
  8. Mar 17, 2019 at 4:52 PM
    Billthecat67
    I'm always on custom offsets page, that's actually who I got my wheels from. Chose the Readylift because it's a bolt on, no cutting! I can always upgrade later.
    mjgonz1 likes this.
  9. Mar 17, 2019 at 5:44 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Can’t wait to see it ! Do you have a date for install yet ?
  10. Mar 19, 2019 at 12:16 PM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    That's exactly what I did to my '19 Platinum last weekend. I have 20x9 +18 and BFG Ko2's 35x12.5x20. I had to do a BMC and trimmed both front wheel wells. You need to trim the lower front section of the wells and use a heat gun to mold the fender liner so that it is more forward in the well. I trimmed about 3/4 to 1 inch on the lower part and also did a small cut on the edge of the front bumper plastic. You should not need to trim any metal parts just the ABS stuff. I also used the little metal bracket that the front air dam bolts to. I bent in outward and put it back on so that it pulls the liner forward. That worked really good. Will send some pictures when done. I am doing all the lift components, tire mounting, and alignment this weekend.
  11. Mar 19, 2019 at 12:56 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I'd look into 285/75/18 or 35/12.5/18 to get the look you want and fill the wheel well. Anything smaller will look like your truck skipped leg day.
    joonbug likes this.
  12. Mar 19, 2019 at 7:06 PM
    WHITEOUT
    WHITEOUT New Member
    2016 Tundra TRD 4x4
    K&N Cold air intake Roll-up bed cover 2.5-1 ToyTec spacer lift 20x9 Maverick D539's wrapped in 33" AMP terrain pro's Westin HDX matte black drop steps TAC Bully Bar Upgraded front grille (chrome to Black honey comb style)
    Today I did 305/55/20 on 20x9 +20 with a 2.5” front spacer and 1” rear block. Removed mud flaps and no rubbing yet! Hopefully it stays that way!
  13. Mar 20, 2019 at 8:40 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Falken Wildpeak AT3s. 305/65-18 (33.6 x 12) on 18x9 +25mm offset. I went with this combination because I felt it was a good match; tire/rim ratio. I didn't want skinny/tall tires nor did I want short/wide tires. IMHO, this was the best balance for what I was going for. They fill the wheel well just enough without looking over stuffed. There is just enough wheel poke to give it a nice stance without being a "bro-dozer".
  14. Mar 24, 2019 at 2:44 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    get it installed yet ?
  15. Mar 24, 2019 at 3:56 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I have 285/65/r20s and I think they fill the wheel well nicely and best of all no trimming necessary.
  16. Mar 24, 2019 at 4:04 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    40s or bust.....
    Mwray8909 and Medic343 like this.
  17. Mar 24, 2019 at 4:23 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Go with 35 for sure. I would go with a All terrain tire. Plenty of all-terrains that looks aggressive. The ride will be better than an MT.
  18. Mar 25, 2019 at 9:56 AM
    niscur38
    niscur38 New Member
    Running 20x9 +18 anthems on 35x11.5’s FBG coils 3/2. Looks perfect to my eyes.
  19. Mar 25, 2019 at 10:02 AM
    sundance
    sundance New Member
    Nice truck! What front bar is that?
  20. Mar 25, 2019 at 10:03 AM
    sundance
    sundance New Member
    Nice truck. I love my Falkens... How are they treating you?
  21. Mar 25, 2019 at 10:56 AM
    WHITEOUT
    WHITEOUT New Member
    2016 Tundra TRD 4x4
    Thanks it’s the TAC bar you can find it in Amazon pretty cheap
    sundance likes this.
  22. Mar 25, 2019 at 11:42 AM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    When you figure out how to get 18in tires on 20in wheels let me know!
    GarTX526 and Medic343 like this.
  23. Mar 25, 2019 at 11:51 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Trim the wheels a bit.....:anonymous:
    joonbug likes this.
  24. Mar 25, 2019 at 12:07 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Oops, didnt read correctly my bad :anonymous:
    What he said :rofl:
  25. Mar 25, 2019 at 7:48 PM
    swede78
    Lars
    westminster co
    Nothing yet
    I didn't mean to bust you but thought it was funny:cheers:
  26. Mar 25, 2019 at 8:47 PM
    r1-superstar
    DB
    UTAH
    Thank you. Tires are doing Great!
    sundance[QUOTED] likes this.
  27. Mar 26, 2019 at 8:19 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    No worries. I thought it was funny once I reread everything:rofl::cheers:
  28. Apr 23, 2019 at 3:14 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    did you get your lift kit installed yet ?
  29. Apr 23, 2019 at 4:55 PM
    Billthecat67
    Got it put on Thursday. Still rolling stock wheels & tires until next week. Rides nice!
  30. Apr 23, 2019 at 5:13 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
