Fix for dim blinkers?
Discussion in 'General Tundra Discussion' started by CCLJ03, Mar 22, 2019.
  1. Mar 22, 2019 at 9:43 AM
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I can’t help but nice that my front blinker bulbs seem very dim. Actually kind of hard to see during the day.
    What’s the most cost effective fix for this?
    LED bulbs are brighter but don’t I need some kind of harness/resistor to keep the correct pace for blinking?
  2. Mar 22, 2019 at 10:03 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Paul B, Smoky and CCLJ03[OP] like this.
  3. Mar 22, 2019 at 10:14 AM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
  4. Mar 22, 2019 at 11:40 AM
    CCLJ03
    Craig
  5. Mar 23, 2019 at 6:07 AM
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    If changing the rears to LED then yes it will hyperflash, brake lights no problem, but the rear blinkers will hyperflash
  6. Mar 23, 2019 at 7:10 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    VLed makes them with internal resistor to alleviate hyper flash, but pricey.
    CCLJ03[OP] likes this.
  7. Mar 23, 2019 at 4:11 PM
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    I installed Lasfit LED bulbs today that I bought from a forum member. He bought them on Amazon I believe. No hyperflashing and they are way brighter than stock bulbs. Pretty easy to install too, took me 5 minutes.
  8. Nov 10, 2019 at 4:24 PM
    Smoky
    Smoky New Member
    2020 Plat CM Silver Sky 4x4
    I have a 2020 plat CM. Ordered the LASFIT front turn signal bulbs which are supposed to be "error-free," but they are not. They weren't a whole lot brighter and they instantly hype-flashed.
    The problem with the dim blinkers is that only the dim wire is juicing the bulb. The OEM amber bulb has two elements, but only the dim element will light with the flasher or turn signal. The high wattage wire is absent. Seems like this may end up a recall issue.
    Anyone else have any success with a 2019 or 2020 LED replacement w/o having to install a separate load resistor?
  9. Nov 12, 2019 at 12:52 PM
    Smoky
    Smoky New Member
    I can CONFIRM that these (in the link) will work w/o adding a resistor(s). Directly plug them into the socket after removing the stock amber bulbs. No hyper-flash. Polarity irrelevant. At least three times as bright as the stock bulbs. Highly recommended.
    My Tundra is a 2020 Platinum, so they should also work fine with the 2019 as well. $17.99 on Amazon. Highly recommended.
    https://www.amazon.com/dp/B00PHVUWR8
    JDM ASTAR 1260
    (7440 7441 7443 7444 Amber)
    Highly recommended.
  10. Nov 12, 2019 at 1:25 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Cool, Smoky, I just ordered a pair for my 2018.
    Smoky likes this.
  11. Nov 12, 2019 at 5:20 PM
    Smoky
    Smoky New Member
    Word. I've seen on here where they work well for your model year and older. Couldn't find any sure info on mine and I was skeptical at first b/c I purchased the LASFIT and they created hyper-flash. Good luck
  12. Nov 12, 2019 at 6:25 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I noticed not long ago that because the blinkers are also DRL, the yellow coating had partially melted off of the bulb.
    One of my headlight assemblies is newer than the other so the bulbs in that side were also newer. This caused the blinker bulb on the older side to appear less bright. $3 fix. :notsure:
  13. Nov 13, 2019 at 9:41 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Well, I have the identical headlight/DRL setup you have (LED headlights) so I am pretty sure these will be plug and play.
    We'll see.
  14. Nov 14, 2019 at 4:49 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Just installed my set (boy, they got here quick). Amazing difference, very bright. They work perfectly! I had to loosen the battery on the driver's side and shift it over to get that bulb out, but overall eezee peezee.
  15. Nov 17, 2019 at 6:32 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    I too had the dim turn signal in the front and realized that nothing with these trucks are cheap. I went with the "VLED" with the plug and fit resistors. Been doubt free for almost 2 years. Can see the blink over the LEDS in the front. Feel that others can see as well. Well worth the investment.
  16. Nov 17, 2019 at 7:03 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    JDM works great. Installed in my 18 and made a world of difference in brightness.
  17. Nov 17, 2019 at 7:09 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Hell, it's winter time. Just add some of this.
    08crewmax, Turtle, 2manytoys and 2 others like this.
