Full audio upgrade completed (pics)
Discussion in 'Audio & Video' started by yoneytan, Jun 24, 2018.
  1. Mar 8, 2019 at 10:35 AM
    #91
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    That makes more sense. I'm around pretty much anytime you're out here or if i'm ever in your neck of the woods i'll hit you up.
    You can position it on the lower part of your double din. I had mine installed on the upper part and removed the set screws from the sides of the screen, i am now able to tilt it up and access the little tray behind it. Theres no need for the set screws as the screen stays put without them.
    jamesmro[QUOTED] likes this.
  2. Mar 8, 2019 at 10:37 AM
    #92
    jamesmro
    jamesmro New Member
  3. Mar 15, 2019 at 11:12 PM
    #93
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Do you think adding a new headunit to the JBL amp via a maestro will improve the sound significantly? I have all new speakers and a sub from tech12volts already, I have an amp I could wire up but could save some cash and just stick with the factory amp of the headunit is enough to push it a little better. Or should I bite the bullet and send the extra 400 on an aftermarket amp and install
  4. Mar 15, 2019 at 11:34 PM
    #94
    yoneytan
    Asi
    14 CM
    The right amp it will make a world of difference. I say go for it.
  5. Mar 17, 2019 at 5:13 PM
    #95
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    I want this !!! But i have a few questions is it worth getting the tnd kit seams like 500 is alot for dash kit and maestro and a few wire harnesses also is there any extra vehicle setings you can do with this ... like turn off seatbelt chimes or just the same ones that are in the stock head unit also anyone install the truck accessories controller yet i was wondering if that was worth it
  6. Mar 17, 2019 at 5:15 PM
    #96
    Beastmode1794
    Voice comand winch controls?
  7. Mar 21, 2019 at 5:52 PM
    #97
    jamesmro
    jamesmro New Member
    @yoneytan can you post a picture of the reverse camera quality?
  8. Apr 4, 2019 at 9:17 AM
    #98
    Baoser
    Baoser New Member
    Bao
    2016 Lifted Tundra Ltd Crew Max
    XD Wheels, 4" lift, All new speakers except center channel, T1000 and T400 amps, infinity doors and dash. JL subs. NSV knight rider light bar, LED heat lights, fog lights and interior lights.
    https://www.googleadservices.com/pa...hUKEwiB_Yj76bbhAhVD5awKHX0jD3QQ9aACCDY&adurl=
    Check out this Tesla style head unit for the Tundra.
    I like the one u guys have posted how ever because I have the NVS Auto light bar made for the tundra and I had to switch out the bottom face plate (where they have the cigarette lighter plug) out to make room for custom switches. The Tesla style replaces the all that and would get in the way for me.
  9. Apr 5, 2019 at 2:30 PM
    #99
    TRD JUJU
    TRD JUJU New Member
    JULIANNY
    2008 GREY TUNDRA CREW MAX
    realest thing ive read so far ! lol
    Baoser, Broncobroke and Sas like this.
  10. Apr 6, 2019 at 7:34 AM
    #100
    kfeltes
    kfeltes New Member
    Tundra 1794
    Hi all, I added the f309 tundra kit to my 1794 a few weeks back and I’m very happy with it. It sounds better and I can actually read the screen.
    All speakers and the amp are stock (JBL) and I cannot figure out how to get the sub to the level it was at with the stock radio. It’s driving me nuts. Even with all the sub setting turned up it doesn’t deliver what I know it’s capable of. Is anyone else having this issue?
    The next issue is call volume on calls. The audio is very low and it’s impossible to use while driving. I’ve turned all the settings I’m aware of to the highest levels. The volume increased but not to the level it was at with the stock radio. Does anyone else have this issue?
  11. Apr 13, 2019 at 9:06 AM
    #101
    jamesmro
    jamesmro New Member
    I put the f309 in my ‘18 CM for 2 weeks. I ended up going back to factory HU, fixing the audio, replacing all speakers and adding a sub, and amplifying with a JL Audio 5 channel.
    Truck sounds 10x better than it ever has.
    I just couldn’t get into the Halo9. I wanted to like it for CarPlay but I found the UI to be pretty awful.
  12. May 13, 2019 at 8:00 AM
    #102
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Just installed in my '17 1794. Not seeing the TPMS. Installed with the MAESTRO RR and the MAESTRO TO2. What year is your truck? Did you have to purchase something else to see your TPMS?
  13. May 13, 2019 at 8:13 AM
    #103
    yoneytan
    Asi
    14 CM
    Mine is a 14 and installed using Maestro. You should be seeing your TPMS. Might have to do with the set up. Try toggling through all the settings. Wish I could be more help.
  14. May 13, 2019 at 8:17 AM
    #104
    tinyt1553
    Tom
    Cypress, TX
    did you use the obd connector? I tried using mine but all it did was make the unit power on without turning the ignition to acc or on position
  15. May 13, 2019 at 8:22 AM
    #105
    yoneytan
    Asi
    14 CM
    I didn't do the install but pretty sure the OBD connector was used. If you can figure that out i'm sure it'll solve your problem.
    tinyt1553 likes this.
  16. May 13, 2019 at 8:24 PM
    #106
    Pudge
    CT
    I get tire info on my kenwood with maestro rr via the obd plug
  17. May 4, 2021 at 11:34 AM
    #107
    Handbanana
    Handbanana New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    What camera did you replace the rear camera with and how did you
    Mount it?
