Can I get closer to UCA?
Discussion in 'Wheels & Tires' started by Lambeau, Mar 20, 2019.
  1. Mar 20, 2019 at 8:45 AM
    Lambeau
    Lambeau [OP] New Member
    2019 Black Tundra Platinum 4x4
    XP Package, 20” Rockstar, 295/60/R20 Nitto G2, Line-X Bedliner, Undercover Elite LX Tonneau Cover, Remote Start, NSV Hood Bulge Light Bar, Predator Running Boards, TacoTunes SQ1 Sound System, Toytec Boss front coilovers, Toytec Boss rear shocks, Coachbuilder +2 rear shackles
    Just installed Boss lift. This picture is with 275/55/20 on +50mm offset wheel. Can I go to 285/60 or 285/65? I'm estimating the tire will be about 0.6-0.7" from UCA with 285's.
    Watt maker likes this.
  2. Mar 20, 2019 at 5:13 PM
    Lambeau
    I know you guys are tired of answering these type of questions but the only reason I’m asking is because Discount Tire said I have to stay with 275s. I think I could go to 295s but not sure how close is too close. There are a lot of experts on this site that have dealt with this I’m sure. Just looking for help before I throw away a bunch of money on tires.
  3. Mar 20, 2019 at 5:22 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Personally, I think you’d be ok.
    But, I am, in no way, an expert!
    What say you @Hattori seen anything like OP’s describing?
    Lambeau[OP] likes this.
  4. Mar 20, 2019 at 5:24 PM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    wow buddy I dunno about a 295 omg. you may squeeze a 285 on there keeping your fingers crossed. I would look in to a negative offset wheel.
    Mnorris1206 likes this.
  5. Mar 20, 2019 at 5:24 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You can run a 295/60/20 on the +50. It’s very close to the UCA. But plenty run it without issue.
    Watt maker and Lambeau[OP] like this.
  6. Mar 20, 2019 at 5:25 PM
    reelcracker
    Farva
    2018 off-road d/c
    There ya go. Perfect.
    Lambeau[OP] and Law323 like this.
  7. Mar 20, 2019 at 5:26 PM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    You will be pretty close to that UCA going any wider or taller but you still have a little room. You can throw on a set of wheel spacers if you want to keep your current wheels if you get too close though. How tall did you go on your lift?
  8. Mar 20, 2019 at 5:27 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    A negative offset for 295’s? o_Oo_O
    No, +18 offset would run 12.5’s without hitting the UCA’s. OP doesn’t need a negative offset for the size he wants.
  9. Mar 20, 2019 at 5:30 PM
    Mnorris1206
    08 tundra
    For sure or get some wheel spacers. Alot of people frown on that but they are ok as long as you know how to use them and install them correctly.
  10. Mar 20, 2019 at 5:38 PM
    conlons26
    Raleighwood, NC
    Agreed not the best solution but the cheapest, I would tell discount tire to put them on worst case you get a set of spacers if they are rubbing...unless your looking at new wheels then go for something in the mid + 20's offset
  11. Mar 20, 2019 at 5:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Lol deleted my last post. Mine wasn’t on the stock wheels. You will easily fit the 285’s. I think you’ll fit 295’s too. Will be close but it should clear. Remember, only half the width you gain will go towards the uca. If you go to 295, that’s only 10mm, less than half an inch, towards the uca.
  12. Mar 20, 2019 at 6:03 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I think mines even closer than that lmao
    I wheel, run it and have no hesitations or worries personally.
    To each their own though. End of the day it's your ride, do as your comfortable .
    conlons26 likes this.
  13. Mar 20, 2019 at 6:17 PM
    Lambeau
    Thanks for the feedback. I did a 3/1 lift with Toytec Boss coilovers on front and Coachbuilder +2 shackles on back. It’s pretty much level right now. When I change tires I may dial down the front to 2.5” to get a little rake.
    conlons26[QUOTED] likes this.
  14. Mar 20, 2019 at 6:21 PM
    Lambeau
    Good to know! Nice looking truck!
  15. Mar 20, 2019 at 6:30 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Like everyone else has said, you should be good. It’s like a 3rd gen on 17” wheels, they look like they’re gonna rub the calipers but no matter what they’ll never come into contact, dooooo it. I have 285/55/20’s and they’re close to the UCA but has never touched even on some axle twisting wheelin I’ve done. Waiting for the tires to go out then I’m going with a +25 method wheel in 17”.
  16. Mar 20, 2019 at 6:31 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I have 295-55-20 toyo rts on the tss wheels without rubbing. The clearance I have is about half what you show there.
    Lambeau[QUOTED][OP] likes this.
  17. Mar 20, 2019 at 8:38 PM
    Lambeau
    Thanks for the help!
  18. Mar 21, 2019 at 10:49 AM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    I'm on 35x12.50s (like 315s in metric) with +50 offset, no spacers, stock UCA. I'm fairly close to the UCA, probably about 1/2" at the closest point. Ask DT to do a test fit. That's what I did. They were surprised 35s fit, but I had calculated it numerous times and knew they would.9C17EE0F-D458-4E4B-A75D-1C3E46DA0DDC.jpg
  19. Mar 21, 2019 at 10:55 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This is a fairly easy issue. You have 275 width. A 295 is 20mm wider. So measure your clearance in mm. Do you have more than 10mm to spare? If so then they will fit
    Watt maker and BlackSheep like this.
  20. Apr 12, 2019 at 9:29 AM
    LiftMeUp
    LiftMeUp New Member
    Following hard! Trying to determine myself, 275/65/20 on stock with 3" lift or fit 285/65/20 is the question!
  21. Apr 12, 2019 at 12:23 PM
    Lambeau
    I had no trouble with 295/60/20 and +50 offset.
  22. Apr 15, 2019 at 8:31 AM
    LiftMeUp
    LiftMeUp New Member
    Not as tall but not as wide, so that's good. Which wheels you have?
  23. Apr 15, 2019 at 9:34 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    ohh... you've got tons of room.
    I went from 275/55/20 to 295/55/20 on the stock 20x9 +50mm offset wheel:
    for my next set, I am going to go with 295/60/20.
  24. Apr 15, 2019 at 8:38 PM
    Lambeau
