1st gen AC cabin air filter
Discussion in '1st Gen Tundras (2000-2006)' started by lsaami, Mar 16, 2019.
  1. Mar 16, 2019 at 12:35 PM
    lsaami
    lsaami [OP] Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    im trying to find the location of the cabin air filter on my truck. It’s not behind the glove box like most, and online searching isn’t much help. Do these trucks not have one? Am I just an idiot?
  2. Mar 16, 2019 at 12:46 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There isn't one on the first gen trucks.
  3. Mar 16, 2019 at 1:35 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Its not there. Your manual is your friend for maintenance.
    It would be cool if someone did a ‘filter add mod’. You game?
    theblurry1 likes this.
  4. Mar 16, 2019 at 1:37 PM
    lsaami
    Minnesota
    Haha. Good idea, but sounds like a ton of work. Not worth it to me. ;)
  5. Mar 16, 2019 at 2:57 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wish they did have filters. From my blower to my vents is full of crap, I bet if they had filters it wouldn't be that way.
    MD0811 and lsaami[OP] like this.
  6. Mar 17, 2019 at 7:10 AM
    speedtre
    speedtre New Member
    Inland Northwest
  7. Mar 17, 2019 at 7:47 AM
    Fred
    Hand Protectors
  8. Mar 17, 2019 at 7:48 AM
    Fred
    Hand Protectors
  9. Mar 17, 2019 at 12:09 PM
    Fred
    Hand Protectors
    Snapped a pic of the intake port under the cowl.
    speedtre likes this.
  10. Mar 17, 2019 at 12:17 PM
    Fred
    Hand Protectors
    I’d reconsider and go with the TS option with the filter inside the cab.
  11. Mar 17, 2019 at 1:25 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Agreed, that's the one I meant to say I was probably going to do....
  12. Sep 27, 2019 at 9:07 PM
    Connor Macleod
    Connor Macleod New Member
    This is kind of funny. Took my 2000 Tundra to good ol' Toyota to get an oil change. First, it took them an hour and a half. Secondly, they tried to charge me $48. Told them I've been getting them done for 20 years at around $29. They said prices go up each year. I said, It's not synthetic, what does it have to do with me? Quickly searched Toyota Owners.com and found a coupon for an oil change, boom 29.95 up to 5 quarts. So, roughly $38. better than $48, right? Small victory. Then the rep tried to tell me "it's 7 quarts". ME: "The 5VZ-FE? No, actually, it's 5.6, but we'll round up and go with 6." He then checks his computer and confirms. Gee, Thanks for the confirmation.
    Anyways, what brought me to this thread and why I had to post. Technician "Green OK's" all of the miscellaneous box checks he has to do with steering rack, body, brakes, tires, etc. EXCEPT: Under the hood Air Filter (Red X) and Cabin Air Filter (Red X).
    I think in my head, I just checked the under the hood air filter last week, it's brand new. Cabin Air Filter? I didn't think I had one. Thanks Toyota. Now I gotta check the oil and tire pressure, make sure this guy did any work at all.
    Schcoman and lsaami[OP] like this.
  13. Sep 27, 2019 at 9:23 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    You are very smart Grasshopper. Though, in my tiny pea brain I always say "if I have to check behind you then why the hell not just do it myself?"
    My daughter's boyfriend just put new tires on her Corolla. When she came by and stayed for a moment I checked the wheel lug nuts (140 lb-ft) and reset them to something that can actually be removed by hand and checked the tire pressure. 29 lbs in two of the tires. :poking:
  14. Sep 26, 2020 at 8:42 AM
    jelco
    jelco New Member
    Has anyone made a filter to put inside the cab for the 1st gen?
  15. Sep 26, 2020 at 12:38 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Maybe try this post?
  16. Sep 26, 2020 at 1:25 PM
    Fred
    Hand Protectors
    Believe me when I say I tried hard to make a filter option work, but its a hard task to make something that is easily serviceable.
  17. Sep 26, 2020 at 3:41 PM
    jelco
    jelco New Member
    Did you try making a filter to put in the box that houses the evaporator core?
  18. Sep 26, 2020 at 3:45 PM
    Fred
    Hand Protectors
    Not easily serviceable.
    shifty` likes this.
  19. Oct 10, 2020 at 2:20 PM
    jelco
    jelco New Member
    but may be the only option
  20. Oct 11, 2020 at 2:07 PM
    Fred
    Hand Protectors
    Take some pics of your job if you decide to do it. Only problem I see with that location, other than difficult serviceability, is that its on the positive side of the blower wheel. Most filters tend to be installed on the negative (pull) side.
  21. Dec 7, 2022 at 2:29 AM
    benrobert
    benrobert New Member
    When traveling in an RV, one thing you must ensure is that the air conditioner is functioning satisfactorily. Therefore, keeping it clean and making sure it functions properly will be to your advantage. The filters should be cleaned every two weeks, according to the manufacturers' recommendations. However, if you are only using one campground, you can only clean it once per month.
  22. Dec 7, 2022 at 3:48 AM
    bmf4069 Yup, that's car parts in a dishwasher
    Also, are you a bot? If you're not a bot say potato.
