TRD Pro Grille
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sundog1, Mar 13, 2016.
  1. Mar 16, 2017 at 11:56 AM
    #181
    FireAC
    FireAC New Member
    NB, Canada
    2016 Platinum Magnetic Grey Metallic
    Thanks, that's what I was hoping for the lower.... I just gotta find out if I'm ordering the right grill!
  2. Jun 29, 2017 at 10:58 PM
    #182
    WOODY3006
    WOODY3006 New Member
    2008 CM
    Rough Country 3/2
    Roman, if I have the Platinum tundra can't I just get the grille and not the surround and bulge?
  3. Jun 30, 2017 at 5:04 AM
    #183
    PMG
    PMG New Member
    That would be a no, Woody.
  4. Jun 30, 2017 at 6:58 AM
    #184
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  5. Apr 7, 2018 at 10:08 AM
    #185
    Stevenboise
    Stevenboise New Member
    Old Man Emu suspension. Brute Force Fab front bumper, rear dual high clearance rear bumper, sliders and headache rack.
    I have only seen the SR5 blacked out badge everywhere I've looked.
    I have a Limited and have never found a blacked out Limited badge. Are these Limited blacked out badges not made?
  6. Apr 9, 2018 at 8:16 AM
    #186
    Roman
    Roman
    Franklin, TN
    Not from what I have seen, no. I know Toyota does not make them in black, and I've never sen them in black in the aftermarket.
    Stevenboise[QUOTED] likes this.
  7. Mar 7, 2019 at 6:27 PM
    #187
    Cheesey
    Cheesey New Member
    Na
    Do the trd pro grills fit on a 2012 tundra white?
  8. Mar 8, 2019 at 6:19 AM
    #188
    Roman
    Roman
    Franklin, TN
    No, they do not.
  9. Mar 8, 2019 at 7:26 AM
    #189
    Cheesey
    Cheesey New Member
    Na
    Is there any substitute for the 2012 stock grill
    Thanks
    Mountun Goat likes this.
  10. Mar 8, 2019 at 8:05 AM
    #190
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    This is coming, I’m sure the grilles will probably interchange. 35FF1F37-A65A-4EFF-9A4A-AF5E6B604908.jpg
  11. Mar 8, 2019 at 8:48 AM
    #191
    Roman
    Roman
    Franklin, TN
    ^Definitely a possibility.
  12. Mar 8, 2019 at 9:04 AM
    #192
    Cheesey
    Cheesey New Member
    Na
  13. Mar 8, 2019 at 9:12 AM
    #193
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Yessss!!!! Will be a $3k headlight and grill swap tho:(
  14. Mar 8, 2019 at 9:22 AM
    #194
    Omohundro
    Jody
    McMinnville TN
    It’s only money, you’ll make more next week!
  15. Oct 13, 2019 at 1:42 PM
    #195
    NativeDaughters
    NativeDaughters New Member
    Colin
    2014 tundra black limited
    @Roman can I get the links for this grill for a 2014 tundra black limited? Thanks my guy!
    Roman likes this.
  16. Oct 13, 2019 at 2:46 PM
    #196
  17. Oct 13, 2019 at 5:23 PM
    #197
    NativeDaughters
    Colin
    Yeah I found it right after. Thank you!
  18. Oct 13, 2019 at 6:31 PM
    #198
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I wonder if anyone has done this full swap on an 07-13.
    I say full because I know the lights and trim have been swapped but, I'm more curious about the grille.
  19. Oct 13, 2019 at 7:07 PM
    #199
    :hattip:
  20. Oct 13, 2019 at 8:27 PM
    #200
    kgb4187
    kgb4187 New Member
    If you want the grille you gotta swap the bumper with it since they're a different shape than the Tundra's.
  21. Oct 13, 2019 at 8:58 PM
    #201
    Scuba
    Scuba Sober member
    Austin, Tx.
    Oh so you tried?
  22. Feb 16, 2020 at 11:48 AM
    #202
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    SUPER WHITE 2016 Plat 4x4
    TBD
    Roman likes this.
  23. Feb 16, 2020 at 5:39 PM
    #203
    TheHutchTTU
    TheHutchTTU Wreck 'Em
    North Texas
    2016 White Tundra Limited 4x4
    You don't need the hood bulge, but then you'll have the black grille and white surround with a piece of chrome on top (unless it's already white). So if you want everything to match then you do need the hood bulge.
  24. Feb 16, 2020 at 5:48 PM
    #204
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    TBD
    Looks like this currently:
  25. Feb 16, 2020 at 7:00 PM
    #205
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    @Roman Do they offer the hood bulge and grill (TRD Pro grill) in 218 Black?
    If not, I'll buy the 202 black and have it repainted to match the 218.
  26. Feb 16, 2020 at 7:54 PM
    #206
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    On platinum tundras all you need is the center grill but separating the lower of your stock grill is kinda a PITA and takes a little patience. Not sure if a oem pro grill from Toyota is separate from the lower part. You can find pro clones on Ebay for $75 on up like I did.20190502_213246.jpg
    Kichinko[QUOTED] likes this.
  27. Feb 16, 2020 at 7:55 PM
    #207
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 GMC 2500 AT4 Gasser
    I have the exact same truck, you don’t need a new hood bulge. Just be aware that there is two versions of the TRD pro grill, a new version came out when the auto braking system was introduced.
  28. Feb 16, 2020 at 8:06 PM
    #208
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    TBD
  29. Feb 16, 2020 at 8:08 PM
    #209
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    TBD
    I was just gonna go at it with a pick tool and pry tool, thanks for the words of warning
  30. Feb 16, 2020 at 8:23 PM
    #210
    ZPMAN
    Minnesota
    Remember the four screws, and it takes a little patience.
