295/70/18 or 285/60/20 on a 3" lift?
Discussion in 'Wheels & Tires' started by renlo, Jun 29, 2017.
  1. Dec 6, 2017 at 9:54 AM
    #91
    greytundra87
    greytundra87 New Member
    Andy
    2016 Tundra TRD Offroad Crew Cab Bilstein 6112 Camburg UCA
    Bilstein 6112 Bilstein 5100 rear Wheeler Offroad add-a-leaf Camburg UCA Nitto Ridge Grappler 295/70R18 Spydertrax 1.25 Wheel Spacer
    295s
  2. Dec 19, 2017 at 5:50 PM
    #92
    greytundra87
    Andy
    Got the 285/70r18 ridge grapplers with the fuel +20s. Tiny bit of rub still but barely noticeable. Truck looks and drives awesome. Extremely quiet tire. Very happy
    TRDPROSean, equin, Steve6 and 6 others like this.
  3. Dec 19, 2017 at 6:24 PM
    #93
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2015 MGM TRD 4x4 Crewmax
    Toyota spray in bed liner/ 30" LED Lightbar/ Pro Comp Pro Runner SS @ 2.5"/ Husky Xact fronts/ Weathertech rear/ NFAB steps/ 275/70R18 BFG KO2's/ LED interior from GTR lighting/ Tekonsha Prodigy Trailer brake Controller
    How do you like them compared to the 295s. I think your truck looks bad ass well done sir!
    greytundra87[QUOTED] likes this.
  4. Dec 19, 2017 at 6:26 PM
    #94
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    I got the same offset and tire size. Cant beat it. I think it sits just right
    Steve6 and greytundra87[QUOTED] like this.
  5. Dec 19, 2017 at 7:36 PM
    #95
    greytundra87
    Andy
    I am really happy i reduced the rubbing. The 295s fill it out a little more, but it’s not all that noticeable. Drive is the same
  6. Dec 19, 2017 at 7:38 PM
    #96
    Muleycrazy13
    Buckeye, AZ
    Plus you saved 10 pounds of rolling weight per tire ha ha. I think you have helped me make my decision as well. Thanks for following up on this thread!
  7. Dec 19, 2017 at 7:38 PM
    #97
    Muleycrazy13
    Buckeye, AZ
    Pics?
  8. Dec 20, 2017 at 3:19 AM
    #98
    DaBoro54
    This is the best one I have on my phone
  9. Dec 20, 2017 at 4:57 AM
    #99
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    This is what I want... I need bigger rubbers and this has made my mind up. I have been on the fence about new rims but I really like these. Can you take a picture of your skid plate? I want to do this before I take it to the tire shop
  10. Dec 20, 2017 at 5:46 AM
    #100
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Looks great. Glad to hear there is virtually no rubbing.
  11. Dec 20, 2017 at 8:21 AM
    #101
    Newm
    Newm New Member
    KC
    Looks great man....your truck sits right. :thumbsup: After seeing some pics I am leaning towards the 285/70 vs the 295/70 once my wheels arrive.
  12. Jan 6, 2018 at 4:51 PM
    #102
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I’ve always liked MasterCrafts - I have them now
    Ben_onewise likes this.
  13. Jan 6, 2018 at 6:56 PM
    #103
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Nice truck man! What setting are your 6112’s set at? And no wheel spacers correct?
  14. Jan 6, 2018 at 11:09 PM
    #104
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    So far I'm very happy with them. The tread pattern and sidewall is very similar to Cooper STT Pros, which makes sense considering they are made by the same company.
    DalTee[QUOTED] likes this.
  15. Jan 10, 2018 at 3:28 PM
    #105
    Marco
    Marco New Member
  16. May 26, 2018 at 6:54 AM
    #106
    aztundraguy
    aztundraguy New Member
    2017 Tundra CM TRD Offroad
    6112/5160,Icon Billet UAC,Diff Drop,Billet .250 shim Lean Correction, CB Bump Stop Extensions, 275/70r18 w/ 18x9 +12 offset
    I believe it was a lot to do with the caster adjustment if you’ll get any rubbing.
  17. Jul 20, 2018 at 10:03 PM
    #107
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Are you running spacers?
  18. Aug 30, 2018 at 6:00 AM
    #108
    cshayt
    cshayt New Member
    Huntsville, AL
    2017 Tundra Crewmax TRD
    RC 3/1.5 Level, 1.5" wheel spacers, Nitto Ridge Grappler 295/70/18s, 2018 Tundra honeycomb front grill.
    Here's my ride with RC 3"/1.5" leveling kit and newly installed 295/70/18's on stock wheels with 1.5" Bora spacers. Tires rub on front wheel well liner at full turn, especially in reverse. Luckily not rubbing on the cab mount, so hopefully I can get it under control with the heat gun trick or something. IMG_2927.jpg IMG_2935.jpg rubbing.jpg
  19. Aug 30, 2018 at 6:38 AM
    #109
    aztundraguy
    I wanted to keep as much of the infender liner as possible, I pushed it forward and marked it, cut as needed.
    DaBoro54, Watt maker, equin and 2 others like this.
  20. Feb 21, 2019 at 5:15 AM
    #110
    MaticsSoCal10D
    MaticsSoCal10D New Member
    2018 CrewMax Limited 4x4 Cement Grey
    TRD Rear Sway bar. NFab Running Bars. S&B air intake. Flowmaster 50 Series
    295 70R 18
    With 5100 Bilstein 2.5 level kit.
    Toyo Open Country MT
    ProComp 9in wheels
    I'm having rubbing issues as well. A few YouTube tundra channels said this was the biggest tire I could install without any mods, but of course that isn't the case. It doesn't look too bad. Maybe some shaving or trimming will do the trick. I hope I dont have to install the wheel mount plate kit. My local lift shop said it would be a few weeks before they can get me in :mad:.
    Dgjman and (deleted member) like this.
  21. Feb 21, 2019 at 8:13 PM
    #111
    CJpe007
    CJpe007 New Member
    2019 Cement Tundra Limited TRD
    Bakflip Fibermax cover
    Nice Truck! I had the same set up on my 07 Tundra and I had to trim the skid plate a little so mine didnt rub. Not sure if that your issue or not but thought I would throw that out there.
  22. Feb 23, 2019 at 12:13 PM
    #112
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Whats involed in adding bumper spacers? Is it relatively easy to do?
    derkks likes this.
  23. Feb 23, 2019 at 1:03 PM
    #113
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    Pardon my ignorance but, what are bumper shims:confused:
  24. Feb 23, 2019 at 1:14 PM
    #114
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
  25. Feb 23, 2019 at 3:48 PM
    #115
    Hobbesdsm
    Eddie
    jwl019[QUOTED] likes this.
  26. Feb 27, 2019 at 7:27 AM
    #116
    jwl019
    jwl019 New Member
    N.E., Louisiana
    Anyone running 285/70r18 with a +12 offset and 2.5" lift? If so, what was involved in making them fit? Pics?
    If it won't work somewhat easily (minor plastic trimming or bumper shims), would 275/70's be a better route to go?
  27. Oct 24, 2019 at 7:40 PM
    #117
    Ryan_Sal67
    Ryan_Sal67 New Member
    2019 Tundra Limited 4X4
    Is this a 3”? Also what size tires
  28. Oct 24, 2019 at 8:40 PM
    #118
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    Great looking truck. What bar is that attached to your front bumper? Also, are the 4 amber pods mounted to the bar, or directly to your bumper?
  29. Oct 29, 2019 at 7:35 AM
    #119
    Merallica377
    Merallica377 New Member
    Jon
    Awesome looking truck....
