Dash inner structure and mounting points
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Tunda, Feb 22, 2019.
  1. Feb 22, 2019 at 8:46 PM
    Tunda
    Tunda [OP] New Member
    Vancouver, BC
    2018 Platinum CrewMax
    I am trying to figure out and hopefully eliminate the cause of a plastic snapping sound that seems to happen more when the temp is low. It seems to come from the top of the dash area on passenger side. And overall the dash just doesn't feel solid and firmly in place.
    I am trying to find out the location of the attachment points of the dash and other possible areas that could allow movement and noise. I'd like to hopefully insulate or lubricste these areas to get rid of this sound.
    Does anyone have any photos of what it looks like behind the dash? This way i can try to target specific areas. I'd like to do everything possible at first without having to remove dash which could potentially lead to other issues.
    Cheers.
  2. Feb 22, 2019 at 11:14 PM
  3. Feb 23, 2019 at 7:13 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Most all of the creaks and noises in my dash were pass side and bottom of the A pillar trim where it meets the dash .lots of plastic and bad fitment causing all sorts of noise when its cold .Prob the 1 biggest complaint i have with my Tundra.Other wise its an awesome truck
  4. Feb 23, 2019 at 7:45 AM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I upgraded some of the trim on my dash this summer with parts from a Limited model. On cold mornings I now have noises on the pass side that I didn't have before the swap. I'm wondering if it's the leatherette panel rubbing the hard plastic wrong. When it warms up the sound is gone making it hard to pin point
  5. Feb 27, 2019 at 1:35 PM
    Tunda
    Vancouver, BC
    So far i have taken the glove box and oh-shit handle trim piece off. Tried insulating a bunch of places but can't seem to get rid of the noise. Sad thing is, there are other rattles and noises aside from this.
    The dealership is useless as they do more damage than anything. I am reluctant to let them remove the entire dash.
    These trucks cost a lot of money and it is shameful for Toyota to build such a rattle box. My truck only has about 1000 miles on it. Should have gone with the F-150.
  6. Mar 1, 2019 at 5:46 PM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    I traded at 18’ f150 Lariat loaded for a 19’trd Pro. I had several rattles in the dash of the f150. 10spd trans is quirky and clunky. I had several issues. Glad I made the swap. So far my Tundra is rattle free and seat are more comfy and the ride is better. I had 20’s on the Ford
  7. May 1, 2020 at 9:46 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    For me it was the temp control panel. It’s hard to pin point noises. What I did was dis assemble what I could and then drive it. Replace 1 piece and drive it. Replace a second and drive it. Didn’t have the noise until the last piece which was the temp control unit. Good luck!
  8. May 2, 2020 at 4:42 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    I am having the same issue. I had a noticeable creak when it was cold out this winter and the Toyota dealership I bought my Pro from replaced my pass side A pillar cover, that seemed to make creak go away. Now I have a buzzing noise coming from I think pass side in dash somewhere but I cannot pin point it.
    I had to go to another Toyota for a service and they took a look...but didn't put much effort into it, the dumb service tech moved my gps farther away from driver side A pillar and said fixed...gps wasn't touching pillar in the first place. I also had him look at driver side rear seat as it squeaks when folded up on gravel roads, he said all tight no noise all good...I can just slightly move it and make it squeak...useless !!
  9. May 2, 2020 at 4:57 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Ive had one new & now one used Tundra, both from 2016, both have been the quietest inside the cabs for a truck. Id compare both to my father in laws 550 Mercedes Benz.
    Hope you can get a remedy soon :popcorn:
  10. Sep 2, 2020 at 11:12 AM
    DaleDanTony
    DaleDanTony New Member
    14 SR5 CM
    on my 2014 CM, i have a vibration that is happening behind the dash at around 2000 (edit: 1000-1500 rpm) RPM. higher or lower revs, it goes away. tried to pinpoint it on dash/stereo/vent area...holding or jamming fingers into pieces..seems to be behind the dash. anyone else?
  11. Sep 2, 2020 at 12:49 PM
    Inquiringone
    Ter
    NorCal 408
    Recently I removed several dash panels on the face of the dashboard which enabled sight into area above glove box, passenger side a/c vent and drivers side a/c vents out let and black cover panel under the steering column, I’d had to pull wire for added on accessories. While the dash was apart I rebooted up the battery and took it for a test drive to listen for any raddles or possible creeks. Didn’t find anything.
    What I learned is you can have a lot of the dash taken apart and still drive around without issues.
    If your having noises pop up, you can take parts off that have no wires supplied to them and have full access to the dash. My suggestion would be have a buddy drive while you hunt for sounds raddles, and such.
    Hope that helps anyone having those annoying thing happening.
    Good luck fellow Tundralights.
    DaleDanTony[QUOTED] likes this.
