Victory4x4 Tundra Diff Skid! Intro pricing!
Discussion in 'Deals & Group Buys' started by brimy311, Feb 1, 2019.
  1. Feb 20, 2019 at 2:15 AM
    #181
    brimy311
    brimy311 [OP] New Member
    Kalamazoo
    2018 Tundra Platinum
    That is all correct.
    There is no torque specs. The tighter you crank it down, the top straps will just bend. You just want to get it tight.
    Yzed608[QUOTED] and Sunnier like this.
  2. Feb 20, 2019 at 10:34 AM
    #182
    Yzed608
    Yzed608 New Member
    Wisconsin
    Ok, sounds good. Thank you.
  3. Feb 20, 2019 at 11:00 AM
    #183
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    @brimy311 what type of hardware comes with the diff skid? Is it stainless?
  4. Feb 20, 2019 at 12:58 PM
    #184
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    truth.. how many manufacturers has this been brought up to and they just disregarded it...probably 50% of the people that order tundra parts from these companies, know about or are on this website...so when we tell you we want something..we want it lol. its nice to see a company grab their balls and just produce the parts. they will be successful with turn around times like this.
  5. Feb 21, 2019 at 4:30 AM
    #185
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    ok so how much are these skids now??
  6. Feb 21, 2019 at 6:11 AM
    #186
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Got mine done last night. Everything went on perfectly. All hardware was complete.
  7. Feb 23, 2019 at 5:24 AM
    #187
    brimy311
    Kalamazoo
  8. Nov 16, 2019 at 11:03 AM
    #188
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    sure hope it works better that the a arm brackets they sold ME!! they cut my rims an Had to cut a 1/2. inch off for clearance. won t buy from them again!! ya I e-mailed them about it an never got a response!! -1/2*
    osidepunker likes this.
  9. Nov 16, 2019 at 4:07 PM
    #189
    brimy311
    Kalamazoo
    Once we discovered there was a. Issue with the LCA skids, we reached out to every customer effected. The customers were all given options to solve the issue, including a full refund option. If we were not able to reach the customer via the phone, we left voicemails and send emails to the contact info provided with the order.
    If you did not receive that message, I would still encourage you to reach out to us directly so we can handle the issue. You will want to speak with Chris. 269.353.1184. Please give us a call.
  10. Nov 16, 2019 at 4:10 PM
    #190
    Sonicbluerider
    Dennis
    2019 Tundra
    wow "NEVER" came to my inbox!!!!! took about 45 days for my order ! u once printed a shipping label an 2 hours later cancel it! hope u improved your game up there
  11. Nov 16, 2019 at 4:48 PM
    #191
    Sonicbluerider
    Dennis
    2019 Tundra
    once adjust on 10,500 through Canada Yukon Alaska back South on pch through calif and Arizona Colorado their unit worked perfect!! an we took my Tundra on roads other vehicles would even look at !! so if their new products work as advertised go for them!!!! Dennis
    jewsNbrews likes this.
  12. Nov 16, 2019 at 4:48 PM
    #192
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    Does anyone have any first hand reviews of this product, that they can give, in which the skid made hard contacts and supported all or substantial weight of the rear?
    I’m not interested in install or fitment, only guys that have bashed and drug them across rocks and used it for its intended purpose.
    Thank you in advance !
  13. Nov 16, 2019 at 5:18 PM
    #193
    Vizsla
    Vizsla ☠️☠️☠️
    Like this? Beat the fudge out of it, serves its purpose. As others mention the fit is way off, one of the allen bolts eats into the third member if you use it, and I’ve knocked it loose at least 3 times. Better than nothing.
  14. Nov 16, 2019 at 7:31 PM
    #194
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    @Vizsla thank you!
    That’s what I wanted to see and hear.
  15. Nov 17, 2019 at 7:13 AM
    #195
    osidepunker
    Alex
    2013 Tundra DC 4x4
    #drivebetter :duh:
    :devil:
    Vizsla[QUOTED] likes this.
  16. Dec 18, 2019 at 8:18 PM
    #196
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    Not for a lack of trying, but mine hasn't been tested yet.
    It's hard to smack the diff when you're on 35s.
    Double Badass likes this.
