What grease do you use in your UCA's?
Discussion in 'Suspension' started by TOTAL CHAOS, Feb 19, 2019.
  1. Feb 19, 2019 at 2:25 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    At TOTAL CHAOS, we recommend super lube but a few installation shops have reported success with red bearing grease.
    HOW TO: Greasing UCA Bushings
    https://youtu.be/xvMdAX2uybs
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    831Tun likes this.
  2. Feb 19, 2019 at 2:42 PM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    Here at our shop, we always use silicone based synthetic greases such as Super Lube or Bel Ray Silicone. It is imperative that you do not use a petroleum based (which most, but not all, red greases are) as it will eat the polyurethane bushings leading to a decreased life span.
    The silicone has a benefit of not washing away easily as well which leads to squeaky bushings!
  3. Feb 20, 2019 at 10:04 AM
    TOTAL CHAOS
    Corona, CA
    I'll try to determine exactly what red grease is being used by shops. A customer had 50k miles on his last ride and now has 25k miles without bushing replacement. No noises and they haven't been re-greased since install :thumbsup:
  4. Apr 3, 2019 at 12:46 PM
    TOTAL CHAOS
    Corona, CA
    Here is an option that customers use with great success!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  5. Apr 3, 2019 at 12:51 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    is this a better option than super lube?
  6. Apr 3, 2019 at 12:54 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I personally like it better than the super lube. I've been using this on all of my TC equipped rides. My Tundra went 25k miles before greasing and my FJ had somewhere around 50k miles with maybe one or two squirts from the grease gun. The Tundra didn't need it but I pumped a little bit of new grease in when the torque was being checked on all of the front end.
  7. Apr 3, 2019 at 12:56 PM
    TOTAL CHAOS
    Corona, CA
    We haven't personally tested it on our shop vehicles so we can't say if this is a better option. We do have customers that prefer this over super lube. I'll let you know if we test this out on our rides
    dcsleeper408[QUOTED] likes this.
  8. Apr 3, 2019 at 12:58 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :thumbsup:
    im almost out of my super lube. i'll give it a shot on the next pick up.
  9. Apr 3, 2019 at 1:00 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I use Super Lube on all of my poly bushings and have not had any squeaking yet
    dcsleeper408 likes this.
  10. Apr 3, 2019 at 1:03 PM
    Bailey
    CO
    Can't imagine you'll have any complaints
  11. May 1, 2019 at 9:14 PM
    Keisuketak
    Keisuketak New Member
    Santa Cruz, ca
    2016 CM 4x4
    How would this work? If at all
  12. May 2, 2019 at 1:41 PM
    GravityGear
    Aurora, CO
    I tend to use Boeshield T-9 on uniballs. But that's just because I also use it as chain lube and it's chillin at the house at all times.
    Keisuketak likes this.
  13. May 3, 2019 at 11:25 AM
    TOTAL CHAOS
    Corona, CA
    Sorry, it's a little hard to tell the specifications and application for that grease. The photo is blurry and doesn't link to the product page
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Keisuketak[QUOTED] likes this.
  14. May 3, 2019 at 11:54 AM
    Keisuketak
    Santa Cruz, ca
    2016 CM 4x4
    Sorry here is the description
  15. May 6, 2019 at 4:41 PM
    TOTAL CHAOS
    Corona, CA
    We don't have experience with this grease so we can't say exactly how it performs with our arms. It looks like it'll work for this application
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  16. May 7, 2019 at 12:57 PM
    Keisuketak
    Santa Cruz, ca
    2016 CM 4x4
    Thanks!
