Skid Plate Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by irage, Feb 18, 2019.
  1. Feb 18, 2019 at 2:25 PM
    irage
    irage [OP] New Member
    2011 Toyota Tundra Crew Cab
    Cold Air Intake, CB, Fender Flares
    Over the past couple of years I've done a number os mods to get my truck looking the way I want. I added a cold air intake, custom painted fender flairs, grille replacement, headlight replacement, leveling kit and 20" wheels.
    After the first oil change and clean up after the pressure from 7qts of oil came blasting out all over my wheel I set out to make that process easier. First I replaced the oil drain plug with quick drain option.
    After looking around I decided to install a Fumoto F103N Engine Oil Drain Valve. Easy enough, drain the oil, install and seal the new plug, refill and test. Works like a champ.
    Next I set out to replace the skid plate that many of you may know has to be removed in order to replace the oil filter. Not sure what engineers were thinking when they designed that, but thats the way it is. Mine plate was damaged by the previous owner, so I set our looking for a replacement. From the dealer it was 343.00 with new bolts and clips which is a ridiculous amount. Checking around online I found several others that were cheaper, but none of them had the style that I wanted or the access panel to make it easy to pull the oil filter. In the end I bit the bullet and bought the OEM metal panel. I purchased a 5" bi-metal hole saw and set out to create an access panel. I tied a magnet to a piece of string and tacked it to the oil filter and installed the skid plate with the plan of finding the center. That worked like a champ, so the next step was to remove the skid plate and drill the hole. I marked the center and off-set it by 1 inch as I've learned in the past centering directly under the mark makes it a little awkward to get any leverage. I clamped a piece of wood to the underside of the skid plate, added a little lubricant to the cutting area and did a nice slow cut out in an effort to reduce the burrs. After drilling the hole I filed the edges to remove any sharp edges and burrs and they thoroughly cleaned the area and added 2 5" o-rings and some rubber sealant. The result turned out pretty good. Judge for yourself.
  2. Feb 18, 2019 at 3:17 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
  3. Feb 18, 2019 at 3:18 PM
    vl184009
    Vicky
    Southern, Ca.
    Looks awesome, like it came that way. Good show! :thumbsup:
  4. Feb 18, 2019 at 3:24 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Looks good. Nice work.
    I'm late for your needs but maybe not for others. The RCI aluminum plate with built in filter access is $380. But if you already have a good OEM plate then this mod makes more sense.
  5. Feb 18, 2019 at 4:55 PM
    irage
    Thanks guys. I agree the RCI one does have an access panel, I just didnt like the look. Mine would have been better if the hole had a cover, 5” is a big hole.
  6. Feb 18, 2019 at 5:29 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    Isn’t the o ring going to peel right off first time you slide on it?
  7. Feb 18, 2019 at 6:11 PM
    Dr_Al
    Dr_Al New Member
    Al
    If you have the ability to weld you could replace the o-rings with some 1/4" rod. Weld it to the inside and then use a hammer to massage the little bit of sheet metal to curl it around the rod.
    RitcheyRch likes this.
  8. Feb 18, 2019 at 6:15 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Sweet! Looks really good. I just ended up going with a RCI. I have a question on the Fumoto. How tight did you put it on? It doesn’t look like any torque wrench would work. Did you just go until it stopped turning?
  9. Feb 18, 2019 at 6:22 PM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    That looks great!
  10. Feb 18, 2019 at 6:29 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Nice job! I'm going to do something like that to my skid plate. I'm probably going to do the same thing you did,but I'm going to put a plate over the hole and use some self tapping screws to secure it in place.
  11. Feb 18, 2019 at 6:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Fumotos come with a washer. What I would call the hard fiber type of washer. Spit it in till snug. Then put an adjustable wrench on it and spin around another 1/3 turn or so. No torque wrench required. Just a well calibrated wrist.
    BTBAKER[QUOTED] likes this.
  12. Feb 18, 2019 at 6:40 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Looks great...nice job!
  13. Feb 18, 2019 at 7:15 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Thank you, sir. That’s what I will do.
  14. Feb 20, 2019 at 6:39 AM
    irage
    Love this community. Yes, the first time i hot that skid plate it will tear that gasket off. Fortunately I dont do that often.
    The futomoto plug as someone mentioned only needs a about a 1/3 turn past snug.
    A welded ring is an excellent idea. That may be the next mod.
  15. Apr 18, 2019 at 7:14 PM
    bigep_mex
    bigep_mex New Member
    2012 SR5 Tundra Crewmax
    I really liked that skid plate but I called RCI and the skid plate is for 4 wheel drive only. They said I could modify my truck to make it fit. I don't want to spend that much and still have to modify it or my truck to make it fit. I'll keep the OEM and modify it unless someone has another option.
    Rex Kramer likes this.
  16. May 20, 2019 at 5:39 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Looks good and I really need to cut a hole in my skid plate.
  17. Oct 14, 2020 at 2:25 PM
    RitcheyRch
    Richard
    Santa Clarita, CA
    After all this time, I finally decided to crawl under my truck and remove the skid plate to cut a hole in it. I found out that I don't even have this skid plate. I'm not even sure if it was there when I bought my 2012 in 2014. Oh well, guess I don't need it since never knew it was gone in the first place. :)
    neuberas likes this.
