6112/5100 question
Discussion in 'Suspension' started by Ruberto231, Feb 13, 2019.
  1. Feb 13, 2019 at 10:38 AM
    Ruberto231
    Ruberto231 [OP] New Member
    07 TRD
    Hello all,
    I have been reading and reading on here and am going with the above set up. My question is on the fronts if I run at the top setting, what bump stops do I need? Is there one for the shock or is it the CB ones that extend the factory bumps? Question for the rear is with the 5100’s and the ToyTec shackle on the highest setting will I need a shock extension? If so where can I find those?
    Thank you all
  2. Feb 13, 2019 at 10:44 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  3. Feb 13, 2019 at 11:33 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    From what I understand, you will not need a shock extension with the Toytec shackle and the 5100s. That's what I'm also installing in the next day or two.
  4. Feb 15, 2019 at 6:58 AM
    Ruberto231
    07 TRD
    Thanks guys!
    r1-superstar likes this.
  5. Feb 15, 2019 at 7:35 AM
    r1-superstar
    DB
    UTAH
    They arrived. I will install tomorrow.
    BlackSheep likes this.
  6. Feb 15, 2019 at 8:08 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    nice, post pics when done..
  7. Feb 15, 2019 at 9:06 AM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    the 6112's come with spacers for the bumpstops, they look like thick washers, simply unscrew stock bumpstop, slap washer on re install.
    equin likes this.
  8. Feb 15, 2019 at 9:09 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The spacer washers are provided with the front shocks. Nothing is needed in the rear.
    6112 needs it in the top 2 settings out of 4 options. 5100 top 2 out of 3 options
    Dmas and equin like this.
  9. Feb 17, 2019 at 4:35 PM
    Ruberto231
    07 TRD
    Thanks guys. My frame is getting replaced this week and all my parts will be in tomorrow. The dealership will be installing everything since the truck will be disassembled anyway. Hopefully I will have the truck back by the end of the week.
    OR18TRD and Boerseun like this.
  10. Feb 18, 2019 at 10:59 AM
    r1-superstar
    DB
    UTAH
    HAHAHA!!! Is that what those four Large washers sitting on my workbench are for? I just went and installed two per side and added some blue loctite as well.
    Boerseun[QUOTED] likes this.
  11. Feb 18, 2019 at 12:07 PM
    Boerseun
    Ferdie
    Sarasota Florida
    I think a lot of those are thrown away as "WTF are these for?"
    r1-superstar[QUOTED] likes this.
