Coolant Leak - Water Pump?
Discussion in '2nd Gen Tundras (2007-2013)' started by minter66, Feb 17, 2019.
  1. Feb 17, 2019 at 9:56 AM
    minter66
    minter66 [OP] 2007 TSS CrewMax
    So when doing my mods this weekend I slid up underneath my truck and noticed bright pink fluid hanging from the cross frame directly below the serpentine belt. I can’t tell where it’s coming from, I just see the drops at the bottom. Coolant level is before the “low” mark now.
    I’ve read that Tundra water pump seals aren’t the greatest, is this true?
    I may do a pressure test on the system to see if I can spring the leak, looking for anyone else that’s had this kind of issue, and also repair time for a water pump if you’ve done it
    I plan on going with a Gates water pump and not OEM
  2. Feb 17, 2019 at 10:09 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Yep. Unfortunately it's somewhat common. For every one that fails with low mileage,, 5-10 go 100k plus. Toyota "accepts" a weep hole drip or two, but if it's coating your floor or suspension it needs to be addressed. Some swear by alternative pumps and have success, others stay stock.
    Good time to check hoses and belts. I'd recommend you stay with Toyota coolant, but some have had success with Amsoil. I'd just shrug it off as "one of those things" and repair it as soon as practical. I'm at 30k on a 16 and I watch it and towers. Both dry for now. None will strand you, but Toyotas seldom do that.
    TheBeast likes this.
  3. Feb 17, 2019 at 10:19 AM
    FXFormat
    FXFormat New Member
    Yep that area is likely the water pump, dealership will charge $1000 for this job, or you can buy an Aisin one on Amazon and put it in yourself, took me a few hours.
  4. Feb 17, 2019 at 10:36 AM
    minter66
    Yeah, I plan on replacing it myself. Mines a 2007 with 103,000 so I guess it got good life out of it. Good to hear it was only a couple of hours.
  5. Feb 17, 2019 at 10:40 AM
    FXFormat
    FXFormat New Member
  6. Feb 17, 2019 at 10:58 AM
    minter66
  7. Feb 17, 2019 at 2:32 PM
    FXFormat
    FXFormat New Member
    That should be OEM, the gasket was high quality, not a bad job, just take your time and remember to remove all the hoses carefully, they tend to rip/crack if you force it.
  8. Feb 17, 2019 at 2:43 PM
    Dr_Al
    Dr_Al New Member
    Al
    Here's a trick. If you have a jack and jack stands (I have a 2 post lift) remove the wheels so you can lower the truck. It makes it much easier to reach the pump unless you are tall. If you're doing the pump look into doing the thermostat as well. You are right there and the extra cost really isn't that great.
  9. Jun 29, 2019 at 5:39 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Just changed my tensioner pulley and belt due to a squeak and noticed the pink fluid
  10. Jul 22, 2020 at 9:24 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Solar Octane
  11. Jul 22, 2020 at 9:30 AM
    Charvonia Design
    Keith
    Huntersville, NC
  12. Jul 22, 2020 at 11:39 AM
    minter66
    I believe that is what I used when I replaced mine.
    Charvonia Design likes this.
  13. Jul 25, 2020 at 6:32 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I found this when I did my timing belt right after buying my truck with 134K miles. I went with an Aisin kit for mine.
