For those that have installed their own coilovers...
Discussion in 'Suspension' started by monaco730, Feb 13, 2019.
  1. Feb 13, 2019 at 1:56 PM
    monaco730
    monaco730 [OP] New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Hello Tundra fam. One day I will be getting coilovers. I want a specific lift measurement (3 inches). When coilovers arrive, you never really know exactly what they are set at from factory. Also, once coilovers are installed, if you don't have the correct lift setting, you are "supposed" to take them completely off and adjust the collars and put them back on (yes some do this without taking them off and use spring compressors). So for those that got new coilovers and wanted a specific height, how did you achieve this? Did you have to guess at the collar position, put on, take off, adjust, put back on, take off, adjust, put back on, etc??? Or is there some cheat sheet out there that I'm not aware of? Thanks for the help.
  2. Feb 13, 2019 at 1:58 PM
    Law323, zcarpenter92, 15whtrd and 2 others like this.
  3. Feb 13, 2019 at 2:01 PM
    monaco730
    16 Inferno Tundra
    I appreciate the info but I already have a purchase plan.
  4. Feb 13, 2019 at 2:08 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    Sas and monaco730[OP] like this.
  5. Feb 13, 2019 at 2:11 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    So you are buying from a dealer that does not know how to set a coilover???? Mine were correct but I checked the setting before I put them on anyway.
    Black Wolf likes this.
  6. Feb 13, 2019 at 2:17 PM
    monaco730
    16 Inferno Tundra
    I am buying Fox shocks but from a second party that is not automotive specific. But regardless if they know how to set a coilover height or not, if i ever want to change the height down the road, my original question would still be in place. What I am looking for is a "cheat sheet" or other's experience on dialing in a specific ride height without taking the coilovers on and off multiple times.
  7. Feb 13, 2019 at 2:18 PM
    monaco730
    16 Inferno Tundra
    Thanks! This seems like the solution. How come so many people talk about having to use a spring compressor and taking the coilover completely off? Maybe Icon and Fox are different. I will be going with Fox, should have mentioned that.
  8. Feb 13, 2019 at 2:24 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Mine were pretty close when I put them on. Still need to adjust the drivers side up a hair to account for the Yota lean though.
  9. Feb 13, 2019 at 2:29 PM
    15whtrd
    15whtrd Mr. Blonde
  10. Feb 13, 2019 at 5:41 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    There are two different types of adjustable coilovers I know of. One uses a clip that can be set at 2, 3, or 4 different settings along the shock body. This kind usually requires complete removal and the the coil spring to be compressed enough in a spring compressor in order to move the clip up or down along the shock body to readjust the ride height. The Bilstein 6112s are like this and come with instructions describing which setting achieves a particular amount of estimated lift.
    The other kind uses a threaded collar that rides along a threaded shock body, or a threaded sleeve on the shock body, to adjust height. These are what I call true adjustables. Once installed, they don’t have to be removed from the truck or disassembled to readjust. Most you have to do is safely lift the front of the truck and use a special spanner wrench (sometimes included when buying new coilovers) to thread the collar up or down to the desired height. I’ve found it a lot easier to remove the front wheels when doing this and spraying a lubricant on the threads. Sometimes even then it may require some force to thread the collar. Oh, and some come with two collars where one acts more as a locking collar. Either way, this kind usually requires a bit of trial and error figuring out how much to adjust to achieve the desired ride height. These are also usually of higher quality, designed more for performance instead of lift, and as a result can be more expensive.
    Hope this helps.
    mtndds98 and monaco730[OP] like this.
  11. Feb 13, 2019 at 7:56 PM
    monaco730
    16 Inferno Tundra
    Thank you for your input. I would be getting the Fox's with the collars. Someone else told me to lubricate the threads as well so thank you for that. With your help and help from others i have learned to jack up the front and leave the suspension at full droop, loosen the set screw but only enough to move the collars and adjust with spanner wrench. I'm glad the entire coilover doesnt have to be removed.
    equin[QUOTED] and 831Tun like this.
  12. Feb 13, 2019 at 8:30 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I’m kinda in this dilemma. I have icon coilovers and want to lower them. The 4x4 shop said they recommend to pull them out and adjust that way. Something about the preload collar is aluminum and it bends the holes and looks ugly. So I’m just gonna have them pull’em out and lower them. $250 to do that.
  13. Feb 13, 2019 at 8:36 PM
    monaco730
    16 Inferno Tundra
  14. Feb 13, 2019 at 8:38 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Fox has their own special wrench for adjusting. Mine was $40 for ADS coil overs. I've never adjusted mine, they were set perfectly when I got 'em from MCM.
    monaco730[QUOTED][OP] likes this.
  15. Feb 13, 2019 at 8:43 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Yes I’m familiar with how to, thanks. One issue is when they installed them, they didn’t leave the screw to loosen to adjust the preload up or down. Thinking they trapped me lol. Figured I didn’t have to specify that to them. They would have if I would have said something. So I kinda have no choice but to pull them.
  16. Feb 14, 2019 at 5:05 AM
    monaco730
    16 Inferno Tundra
    Seriously? I would think the collars would move up or down over time without that since nothing is holding them in place besides the threads on the coil over body. I would think you'd need to have the shop pay for those or get some on your own. I can't believe a shop wouldn't think they served a purpose, and a pretty important one at that
  17. Feb 14, 2019 at 5:54 AM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Whoops lol. I meant that they didn’t leave that screw facing out, so that it’s easily accessible. I was having a few when typing this last night. :crazy: Sorry for the confusion
  18. Feb 14, 2019 at 6:10 AM
    monaco730
    16 Inferno Tundra
    ah, makes sense now. That's annoying. Gotta be some way to get back there with an allen wrench without taking them off.
