DIY: Trailer harness relocate.
Discussion in 'Towing & Hauling' started by Beer'd_n_yotas, Mar 30, 2014.
  1. Mar 30, 2014 at 7:18 PM
    Beer'd_n_yotas
    Beer'd_n_yotas [OP] New Member
    2013 Super White Tundra
    Plasti-dipped and lowered!
    This is a simple how to relocate factory harness to license plate light.
    Tools needed:
    10mm wrench
    Phillips screwdriver
    Electrical tape
    Cutting tool (Dremel, angle grinder)
    First, remove harness plug using 10mm wrench.
    9DB86C3D-39F7-4A78-8D4F-A7240A132518_zps_29d1c58846785c34dea97f8f6fbe58edd2595c61.jpg
    Next remove tape holding sleeve on harness plug.
    9CF22222-426A-45B2-B613-94552FF3314C_zps_0b7c86c917e27095983d3272cc0da6548da212f7.jpg
    Squeeze connector as shown and remove.
    0ACBF3DE-70E1-429C-8CC2-DE8F9AC07173_zps_e22573446820c03541aa2b10c4ec66395742611f.jpg
    Press clips in and remove bracket from plug.
    7E6B597C-AD37-488D-90B5-35814F09724E_zps_7206b78219b7eee269e809473bb210b0c7f00b28.jpg
    This is what you should have.
    1F63CD60-639D-4135-B9ED-73DF1BE59EB6_zps_94cd220ca0a002c67111ad3380bfab8eb6937700.jpg
    Remove left license plate light using Phillips screwdriver.
    1106CD45-6E25-4DDE-B529-CCCAF9682A52_zps_4598069731c0859c8d8478e7c126d8bc66739c1f.jpg
    Place bracket over hole from license plate light and trace as shown.
    4D088698-F1D8-4485-AA39-AECE354C7997_zps_ae46b002a4d56627dbc99d4594e1719815a149cf.jpg
    Cut out traced area being careful not to cut to much. It needs to be a tight fit so cut inside the lines and make additional as needed to ensure a tight fit. This is what the cut hole should look like.
    7861FCE0-ABBD-4B6F-90BC-37657AB0F574_zps_a64788ed3425d815c6912413a6713072086880e8.jpg
    Retape sleeve to connector.
    10AD2780-2F81-4A8B-A77F-FE9AE1C6EE19_zps_31691871947a657077e935ad76177e2ae4c974aa.jpg
    Pull connector through cut hole and connect harness plug. You will probably need to pop off wire loom from zip tie on the hitch to get it all the way through.
    31E98C48-0F0E-4833-84B2-5442808D88A4_zps_57321b58c972559b9aa03432d59d20b3f6d47d82.jpg
    Now pop in harness into cut out hole and ensure you get it seated all the way in. All done!
    303B6244-82DD-4E34-B68F-6D76A4EA10EA_zps_cd71830b9f1371c16cb32f4464a5e5740e72c560.jpg
    A3C6EAAF-F8BE-437B-8ABA-2230168CA946_zps_571bb6d288ec681642f7af7aa31273ab7888b855.jpg
    FCC95260-3029-453A-A4B4-9AC07EFBF6CE_zps_cb64598b8c70e078711491d4c11dce57e31653b5.jpg
  2. Mar 30, 2014 at 8:21 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Looks good man. Is there enough light for the license plate from the one light?
    Beer'd_n_yotas[OP] likes this.
  3. Mar 30, 2014 at 8:25 PM
    Added to the DIY. Thanks!
  4. Mar 30, 2014 at 8:58 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Awesome. Looks good. Thanks for the write up.
  5. Mar 30, 2014 at 11:04 PM
    Beer'd_n_yotas
    I've had my wife's a Tacoma like this for years with no issues. I have a LED in my plate light, I think it's plenty lit.
    40F4692C-3AA9-4FBC-88D3-4EFB67E35B24_zps_622e800cc3705b7ca713b94407b2516da9c8d76f.jpg
    Mountun Goat and Bedard20 like this.
  6. Mar 31, 2014 at 7:12 AM
    TruckyTruck
    Gary
    oh yeah, no problem at all there! I think im going to do this. I hate having it hanging there. They look so nice on the 2014s too
  7. Apr 8, 2014 at 9:35 PM
    Corey
    Corey New Member
    Corey
    Washington
    2010 Toyota Tundra DC 5.7l
    Supreme Suspension 3/2 lift, Bora 1.25" spacers, tinted windows, BHLM
    Definitely going to do this! Thanks for the write up.
  8. Oct 6, 2015 at 5:36 PM
    DawgGam
    DawgGam New Member
    Kevin
    Hamiton Ont
    2011 Black Tundra Dbl SR5TRD
    (included in purchase) LineX nerf bars Extang Solid Fold tonneau Weather Tech mats Tow Mirrors (future improvements) Autogas (propane) tint ventshades (Oct 10) back up camera Leer work cap (thinking about keeping the tonneau cover) bed-slide rear 'helper bags'
    An excellent 'must do' (like tomorrow) mod. Thanks
    Worth bringing this old post back up, no?
  9. Oct 18, 2015 at 4:43 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Just moved mine yesterday.Didn't lower spare-tire but removing rear tag helped with access.1017151048.jpg
  10. Oct 18, 2015 at 5:47 AM
    csuviper
    Broomfield, CO
    I like the position you put yours. Will prob do this at some point
  11. Oct 18, 2015 at 6:10 AM
    CMB
    CMB New Member
    Cecil County MD.
    Thaks Brian, I just didn't have the heart to hack a taglight off.This position requires some grinding/sawing/drilling or chopping but it was the best spot for me.:thumbsup:
    Maxi13 likes this.
  12. Jan 13, 2016 at 9:10 PM
    nitro943
    nitro943 New Member
    mike
    Im doing this asap!
  13. Sep 5, 2016 at 9:48 AM
    CMB
    CMB New Member
    Cecil County MD.
    Hey folks,just a heads-up(YourResultsMayVary) I did this mod a while back. "Looked" great,till I needed to actually use it for my boat trailer. Wouldn't stay put because of all the flimsy plastic and very little metal surrounding it. After buying a new Step-Pad and Plug-Bracket,I'm back to stock.....$91 later!:facepalm:
    NewImprovedRon likes this.
  14. Sep 5, 2016 at 10:38 AM
    csuviper
    Broomfield, CO
    Bummer. Well I am def going to be doing the relocate but my plans are an angle bracket to place it tucked up under the bumper.
  15. Sep 5, 2016 at 10:56 AM
    CMB
    CMB New Member
    Cecil County MD.
    Yep, the metal clips that keep the plug in place, need more than plastic around 'em, when using the receptacle. Your bracket should firm it up enough.
  16. Jan 8, 2017 at 8:19 PM
    bstundra
    bstundra New Member
    James
    Eastern Long Island NY
    2008 Blue Streak metalic DC tundra
    3 inch rough country lift, lift uniball ball joint UCA's 35x12.5's, ultra maverick 18x9 , 17% tint, Jensen v7022 with factory style back up camera in tailgate handle, led interior lights, led plate lights, led fog lights, magnaflow catback
    does anyone know if I can put this style plug on my 08 (older plug style) with out completely rewiring it. [​IMG] the picture is the kind I have on my truck
  17. Jan 15, 2017 at 11:58 AM
    Specialized
    Specialized New Member
    2017 Tundra DC TRD 4WD
    Just FYI, my new 2017 has the plug receptacles mounted up by the license plate already. Apparently Toyota reads our DIY pages. :)
  18. Jan 15, 2017 at 12:17 PM
    sc134
    sc134 O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    Yuppp my 2017 comes relocated. Think it's the only change from previous models
  19. Jan 15, 2017 at 1:43 PM
    CMB
    CMB New Member
    Cecil County MD.
    There've been several changes but most of 'em have been (Beancounter) feature- deletions:rant:
  20. Jan 15, 2017 at 1:46 PM
    sc134
    sc134 O.P.S.
    What are the changes from the 14-16 to the 2017?
  21. Jan 15, 2017 at 1:50 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I tried to do this... The spare tire got in the way of the back of the plug.
  22. Jan 15, 2017 at 2:33 PM
    CMB
    CMB New Member
    Cecil County MD.
    :sorry:,mine's a 2010, ignore me:lalala:
    sc134[QUOTED] likes this.
  23. Aug 10, 2017 at 5:50 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    Could you make a metal backing with a hole the shape of your cutout? Maybe about an inch larger than the hole in the back side?
    Frozen Tundra likes this.
  24. Aug 11, 2017 at 12:31 AM
    CMB
    CMB New Member
    Cecil County MD.
    That might work if there's room for a plate large enough. On mine, I'd have to spring the mounting-clips too far to accept a plate and the shape of the mounting area prevented a plate large enough to add any integrity. I found out there's quite a bit of pressure involved in hooking/unhooking the trailer plug!:facepalm:
  25. Sep 22, 2017 at 7:27 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    I'm wondering if you could use the old plate as a backer (only grind off the angle part) and modify the prongs (cut them back) to allow for the metal plus the plastic? You could epoxy it behind the plastic. CMB, you did say there was metal you cut though in some spots so it may be uneven if you try to add a backer just left of the licence plate location?
  26. Sep 23, 2017 at 8:00 AM
    CMB
    CMB New Member
    Cecil County MD.
    Sorry it took so long with my reply, we just got back from vacation. On my 2010,I didn't think I had enough metal to hold-up to all the "yanking" I do ,on the trailer plug. I might've been able to come up with something but at the time, my best bet was just going back to stock, good luck!
  27. Dec 17, 2018 at 5:37 PM
    tundracrazy
    tundracrazy New Member
    Wisconsin
    Good idea
  28. Sep 21, 2020 at 7:26 AM
    cartroub
    cartroub New Member
    Laramie, WY
    06 Tundra DC Limited
    Turns out the trail is forcing me to do this mod
  29. Oct 14, 2020 at 12:15 PM
    Jennifer
    Jennifer New Member
    Jennifer
    2007 Tundra 8' bed
    That is SUUUUUWEEEEEEEET!!! Thank you for posting.
  30. Feb 24, 2021 at 5:44 PM
    Dickey
    Dickey New Member
    Katie
    Spring, TX
    2008 tundra dc 2wd and 2011 tundra cm trd 4x4
    My Tundra harness is always full of sand and mud so the relocation by the license plate!!!
