Can’t believe this
Discussion in '2nd Gen Tundras (2007-2013)' started by Kn4x2, Feb 12, 2019.
  1. Feb 12, 2019 at 4:04 PM
    Kn4x2
    Kn4x2 [OP] Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    I bought my 2010 V6 Tundra about 4 months ago from a local Toyota dealer with 63000 miles and an excellent service record. I have put about 4800 miles on it.
    The coolant level in the reservoir has gone down about 1/2 inch maybe a little more and today while changing my oil I noticed a small amount of milky oil in the fill tube.
    I thought I bought the right truck for me (spent a little more for a low milesge vehicle) and now I have put even more into it (which I cannot afford).
    Super bummed ☹️
  2. Feb 12, 2019 at 4:20 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @Kn4x2, are you seeing white smoke out of your exhaust? Is there any sign of oil in reservoir , and are you having to fill your reservoir frequently?
  3. Feb 12, 2019 at 4:22 PM
    Kn4x2
    2010 DC 2WD
    Small amount of smoke this morning. I have appt next week to have the dealer inspect it. Haven’t had to add any coolant
  4. Feb 12, 2019 at 4:24 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Was the dipstick milky? If not, you're just dealing with condensation in the crankcase, it happens during the winter more So and especially if doing short trips.
    Longer trips with the oil up to operating temps will keep it at away.
  5. Feb 12, 2019 at 4:26 PM
    rons23
    Ron
    Kill Devil Hills
    Well Kevin, it could possibly be a head gasket, but hopefully it's something simple. Keep us posted, and hope you make out good
    NewImprovedRon and Brownsfanhere like this.
  6. Feb 12, 2019 at 4:27 PM
    417Tundra
    417Tundra New Member
    Levi
    2013 platinum
    My Tacoma that I had before the tundra would do that especially in the winter. I would drive it but not far enough to "super heat" the engine. Therefore it would create condensation that I would see in the fill tube and under the cap. Just a thought. 4.0 V6
    Black Wolf, landphil and 040Tundra like this.
  7. Feb 12, 2019 at 4:36 PM
    Kn4x2
    2010 DC 2WD
    Oil and dipstick looked fine.
    Thanks. I worry about everything, unfortunately
  8. Feb 12, 2019 at 5:05 PM
    Aurora CO
    2010? V-6?
    Jrharvey02 likes this.
  9. Feb 12, 2019 at 5:27 PM
    Jrharvey02
    Jrharvey02 New Member
    My coolant level is just below the “low” line when engine is warmed and parked, once parked in garage over night, it fills back up to exactaly in between the “full” and “low” level by the next morning. Make sure you’re checking your fluids at the same operating (or non-operating) temperatures.
  10. Feb 12, 2019 at 5:46 PM
    Kn4x2
    2010 DC 2WD
    I check the coolant in morning so it has a complete cool down overnight.
    Black Wolf and Jrharvey02 like this.
  11. Feb 12, 2019 at 5:54 PM
    Kn4x2
    2010 DC 2WD
    That’s correct
    landphil likes this.
  12. Feb 12, 2019 at 6:03 PM
    Jrharvey02
  13. Feb 12, 2019 at 6:13 PM
    Kn4x2
    2010 DC 2WD
    4.0 V6
    Jrharvey02[QUOTED] likes this.
  14. Feb 12, 2019 at 6:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    My 4.0L Tacoma also did the same thing in winter. The oil filler tube is so long that the top end is cool from the air blowing off the fan, and it collects a lot of “mayonnaise”. It looks odd, but not a problem. If you are really concerened, send in an oil sample.
  15. Feb 12, 2019 at 6:27 PM
    Kn4x2
    2010 DC 2WD
    Thanks for the info, I hope that I am worried over nothing
    landphil[QUOTED] likes this.
  16. Feb 12, 2019 at 7:36 PM
    Aurora CO
    Wasn't aware Toyota had the sixer but sure enough...up to 2013.
    15whtrd likes this.
  17. Feb 12, 2019 at 10:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m pretty sure regular cab only. Work truck spec, so most were white. :D
  18. Feb 12, 2019 at 10:36 PM
    Kn4x2
    2010 DC 2WD
    DC and silver, work truck
  19. Feb 12, 2019 at 10:58 PM
    kgb4187
    kgb4187 New Member
    Did you notice the oil smelling like gas? Or under the cap?
  20. Feb 12, 2019 at 11:00 PM
    Kn4x2
    2010 DC 2WD
    Didn’t notice anything like that
  21. Feb 12, 2019 at 11:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Interesting. I don’t think that was an option in Canada, but I’m really not sure now.
    The white part was a joke, not sure if you caught that. Some here like to say that white is the fastest color. But silver is way more gooder.
    Mountun Goat, Sunnier and Black Wolf like this.
  22. Feb 12, 2019 at 11:20 PM
    Kn4x2
    2010 DC 2WD
    I finally caught on, took me a bit. (Long day I guess)
  23. Feb 14, 2019 at 9:16 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    My 5.7 has milky looking oil in the full tube also.
    Never on the dip stick
    Cause was just condensation nothing to worry about it changed my pvc valve
    landphil and Kn4x2[OP] like this.
  24. Feb 20, 2019 at 3:56 PM
    Kn4x2
    2010 DC 2WD
    Great news.
    Dealership service department inspected my truck today and did not find anything that I need to worry about. Cooling system is fine.
    They found that the timing cover could be weeping a small amount of oil, so they cleaned the oil off and told me to inspect it once in while to see if it gets worse.
    Well, as usual I over analyzed things and gave myself an ulcer.
    The dealership did the inspection for free as well
  25. Feb 20, 2019 at 7:57 PM
    kgb4187
    kgb4187 New Member
    Fantastic news!
