SDHQ Hood Hinge Light Mounts/ Vision X Light Cannon
Discussion in 'Product Reviews' started by PLC721, Sep 1, 2016.
  1. Sep 1, 2016 at 11:27 AM
    PLC721
    PLC721 [OP] New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    So a few days ago I purchased the SDHQ hood hinge brackets, let me tell you these things are beefy. They also include a rubber isolator to prevent any vibrations that may occur from offroading etc. Install took roughly 15 minutes. This is a great location for a spot beam light to get it up higher and firing down the road a good distance.
    Link to brackets:
    http://store.sdhqoffroad.com/sdhq2014tundraapillarlightmounts.aspx
    Link to switch
    http://store.sdhqoffroad.com/a-pillarswitch-blue.aspx
    Link to lights
    http://store.sdhqoffroad.com/lightcannon.aspx
    Everything bolts up perfectly the way the detailed instructions specify as well.
    Edit: Will post more pics of actual brackets later today
    Clears everything as it should
    I then finished the install off installing a Tundra Specific A-Pillar switch that ties into the factory interior lights
    Lower portion illuminated with interior lights
    Upper portion illuminated with lights on
  2. Sep 1, 2016 at 6:37 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
    I have a set of led lights that I didn't know what to do with until now
  3. Sep 1, 2016 at 7:35 PM
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Crisis Adverted :thumbsup:
    1G3-TRD[QUOTED] likes this.
  4. Sep 3, 2016 at 6:33 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    That was a close one
