Correlation betwwem rim and tire size
Discussion in 'Wheels & Tires' started by Snowcat4360, Dec 25, 2018.
  1. Dec 25, 2018 at 3:02 PM
    Snowcat4360
    Snowcat4360 [OP] New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Trying to understand the relationship between tire size and rim size. If you go up in rim size and reduce sidewall mass of the tire, does your rolling resistance decrease? I would think the larger wheel would weigh less than the increased weight of the tire you have with a smaller rim. Input would be much appreciated.
  2. Dec 25, 2018 at 3:10 PM
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    Really it would depend on the wheel. Some wheels are very heavy.
    The smaller the sidewall, the harsher the ride will be.
    zcarpenter92 likes this.
  3. Feb 9, 2019 at 3:40 PM
    Snowcat4360
    Derek
    I would think an aluminum wheel would weigh less that a 8 to 10 ply rubber sidewall on a tire...
  4. Feb 10, 2019 at 3:24 AM
    brimy311
    brimy311 New Member
    Kalamazoo
    I thinks a margainal difference. 1” of rubber vs 1” of aluminum. Probably the difference of a couple lbs.
  5. Feb 10, 2019 at 4:04 AM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    Spent a couple minutes on tirerack and looked up OE sized tires and rims (same model in both sizes). the 20" tire was 4lbs lighter but the rim was 4lbs heavier. You would have to pick a rim and tire you want and compare the two sizes to see if one is lighter
    040Tundra likes this.
