Is there a better way to drain oil cartridge?
Discussion in '2.5 Gen Tundras (2014-2021)' started by vanthesupreme, Feb 4, 2019.
  1. Feb 4, 2019 at 4:02 PM
    vanthesupreme
    vanthesupreme [OP] I'm Batman
    OKlahoma
    2014 Tundra
    I recently changed the oil on my Tundra. I have an RCI skid plate and when I inserted the plastic piece to drain the oil in the cartridge housing it turned into a messy ordeal. Is there a better way to drain the oil cartridge housing without making a mess?
  2. Feb 4, 2019 at 4:07 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Fumoto valve on the pan and filter drain tool = 2 hoses into the pan and no mess
  3. Feb 4, 2019 at 4:07 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
  4. Feb 4, 2019 at 4:11 PM
    vanthesupreme
    OKlahoma
    2014 Tundra
    I have the fumoto valve on the pan but what are you
    What are you using for the drain tool?
  5. Feb 4, 2019 at 4:26 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    whole new housing?
    Prostar 190 and SouthBoundSteve like this.
  6. Feb 4, 2019 at 4:37 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Joe Dirt and Prostar 190 like this.
  7. Feb 4, 2019 at 5:39 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I attach a 1/2 inch sprinkler hose to the insert.
  8. Feb 4, 2019 at 5:43 PM
    vanthesupreme
    OKlahoma
    2014 Tundra
    Thanks everyone for the info!!
    SouthBoundSteve likes this.
  9. Feb 4, 2019 at 6:00 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    MotivX oil drain tool. It's inexpensive, simple to use, well built and it works.MX2340_Img4_c929436d-45d9-4929-aacb-9780772cfd5e.jpeg.jpg
    B737, Beep88, 4Runner and 5 others like this.
  10. Feb 4, 2019 at 6:02 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    None of that fancy stuff for me. Jammed the drain thingy that comes with the filter into a piece of 1/2" schedule 40 pvc that's cut about 2" above my drain pan. It might drip a couple of drops but no mess.
  11. Feb 4, 2019 at 6:03 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  12. Feb 4, 2019 at 6:10 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Oops, thanks, totally missed that. I think at that price I’ll keep using the tool I have, especially since another modern Toyota will hopefully join the herd soon. But damn, that looks nice. :thumbsup:
  13. Feb 4, 2019 at 6:14 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Camry. Hopefully a ‘19 SE 4cyl, but trying to save a bit more while the old ‘01 Corolla with almost 400,000 km is still going strong. Wife drives quite a bit, so fuel economy is a priority.
  14. Feb 4, 2019 at 6:35 PM
    X2^^^^
  15. Feb 4, 2019 at 6:35 PM
  16. Feb 4, 2019 at 7:12 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    I just ordered the motivx drain tool just now so I can have a good first experience changing the oil in my Tundra. Just received the Fumoto 103s drain valve as well.
    landphil and SouthBoundSteve like this.
  17. Feb 7, 2019 at 1:42 PM
    Trooper2
    JR
    Are you using the original plastic housing or the upgraded aluminum housing? I have the new aluminum for the next oil change and not sure I am seeing a plug to remove. Thinking I remember a plug like in the pics of product.
  18. Feb 7, 2019 at 2:59 PM
    TundraTSS19
    San Antonio, TX
    Ready to knock out a few oil changes
    Steve6, landphil, Trooper2 and 2 others like this.
  19. Feb 7, 2019 at 3:20 PM
    Trooper2
    JR
    Actually looking forward to changing the oil this weekend. :thumbsup:
    landphil likes this.
  20. Feb 8, 2019 at 5:36 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I am still using the plasic one, but the Toyota aluminum one is set up the same. The plug has a 3/8” square recess.
