Cali Raised - Vehicle Switching System (Install and More)
Discussion in 'Cali Raised LED' started by DividedSky, Jul 5, 2018.
  1. Jul 5, 2018 at 9:12 AM
    DividedSky
    DividedSky [OP] New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I wanted to start a thread to cover the Cali Raised Vehicle Switching System. The primary purpose is to document the install process in our TUNDRAS, but also to provide a resource to answer any questions about use etc.
    First off, here is a copy of the instructions that came with the unit:
    Here is what comes in the box:
    One possible install location (courtesy of GiantsFanDan)
    And a shot of where he installed the power unit under the hood:
    Running the wires inside the cab:
    And mounting the switch-plate:
    pvn.beluga likes this.
  2. Jul 5, 2018 at 9:21 AM
    DividedSky
    Jeff
    Ok... So here are some questions I have to help guide me on my install.
    So here is my first question. In the install notes, it states to connect the Ground, Ignition Input and Lights Input... And then later to connect the thick gauge Power wire directly to the battery. The Ground is obviously the Ground for the switch power. What about the Ignition and Lights inputs? I would assume the thick gauge is what provides power to the accessories, Ignition input is to power the Switch functionality and the Lights input is what provides the back lighting on the switch-face?
    If anyone else has installed a Cali Raised Switching System in their Tundra, please feel free to post pics of your install and explain how/why they installed the way they did, how it has been performing, and what you are powering with it!!
  3. Jul 11, 2018 at 8:34 AM
    DividedSky
    Jeff
    Here is the Wiring Diagram for the switch Unit:
  4. Jul 11, 2018 at 12:17 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @DividedSky do you know if the switch itself will fit in the card slot?
  5. Jul 11, 2018 at 12:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  6. Jul 11, 2018 at 12:23 PM
    DividedSky
    Jeff
    I did a test fit and determined that is "kinda" does... I'm not gonna put it there though (most likely) I'll take a pic to show better, but as I recall, it fits but the tabs dont. In other words, I think you would have to cut out the whole card slot and mount flush with the rest of that piece. Though you would probably have some gaps on the edges...
    Stay Tuned
  7. Jul 11, 2018 at 12:29 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
  8. Jul 11, 2018 at 12:36 PM
    DividedSky
    Jeff
    Ditto.... @GiantsFanDan ?
    Now that I've looked at the wire schematics in more detail, I have more questions. Would also love it if Jake ( @CaliRaised ) would chime in.
    I still want to know what each wire does...
    I assume that:
    #3 - White - Lights or Illumination = what controls the back lighting on the switch face
    #4 - Yellow - Ignition = makes it so that accessories can only be powered when the ignition power is on? (I believe that GFD wired this to battery so he could keep things powered when vehicle is OFF)
    #13 - Red - Power = This is what is supposed to allow power to accessories when ignition is off?
    GFDan didn't tell/show how he connected this one (#13 - Red). Also, I haven't seen any instructions on how to choose which accessories are powered by Ignition (vehicle on) and which are powered by Battery (Vehicle off). Maybe there is no choice... I dunno. I thought the CaliRaised site said we could choose, but I dont see that on the site any more. Maybe we can't? Not a big deal if we can't IMO. Just want to know what each wire does... If you can't choose, then maybe one of those two wires doesn't do anything... Again, I just don't know.
    Also, I FULLY ACCEPT that this is still sort of a Beta product and things might still be getting worked out. And that they are a bit lacking in instructions...
    Any help you can provide would be appreciated Jake. Still think this has the potential to be a GREAT product!!
    :thumbsup:
  9. Jul 11, 2018 at 12:43 PM
    DividedSky
    Jeff
    That "@" function is great.... Can you get the user# for Cali and tag him? I'm not exactly sure how it is done...
  10. Jul 11, 2018 at 12:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  11. Jul 11, 2018 at 4:28 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Red Wire (small): Use red fuse tap for 12v went to an empty fuse spot in the main fuse box (I want power anytime). If you don't do that, then you need to break out your volt meter to test what empty fuse spot doesn't have power when the truck is off.
    Black: Ground can go to any ground on the truck.
    Yellow: Ignition wire went to my 2018 LED headlight harness that has a fuse tap already. Did this because the DRL's only come on when the ignition is on. (this wire seems redundant to me)
    White: Light wire goes to your parking light wire. Use the small bulb wire for your side amber marker light from your headlight.
    I called and talked to Caliraisedled after installing. You have zero function as for programing. The middle hidden button on the switch pad does nothing.
  12. Jul 11, 2018 at 4:31 PM
    GiantsFanDan
    Each time you turn you headlights on to off, it will dim the switch pad green lights.
  13. Jul 11, 2018 at 4:40 PM
    GiantsFanDan
    Same here. Wish it used the white wire to detect parking lights are on, it must be dark so lets dim the switch pad.
  14. Jul 11, 2018 at 4:42 PM
    GiantsFanDan
    That's a great idea. Push the button on and off a few times to dim the lights.
  15. Jul 12, 2018 at 10:55 AM
    DividedSky
    Jeff
    Thanks for clarifying Dan!! I finally think I have enough info to tackle this project.
    Although I'm sure I'll have more questions as I go. ;)
  16. Jul 17, 2018 at 11:22 AM
    DividedSky
    Jeff
    Dan,
    I tested a bunch of the empty fuse slots w/ my volt meter and wasn't able to get a good reading. Which empty slot did you use for "anytime" power?
    (see fuse diagram below)
    831Tun likes this.
  17. Jul 17, 2018 at 5:29 PM
    GiantsFanDan
    I will take a look in a bit
  18. Sep 4, 2018 at 4:48 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    What are the dimensions on this?
  19. Sep 4, 2018 at 5:48 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    In the bottom right corner of the pic. there's are 4 empty spots, try the open slot that's to the right of the one that says IGN.
  20. Sep 5, 2018 at 8:48 AM
    DividedSky
    Jeff
    Perfect, thanks for the tip. I'll try it out.
  21. Sep 5, 2018 at 8:58 AM
    GiantsFanDan
    I forgot to get that photo for you @DividedSky
    Still need it?
  22. Sep 5, 2018 at 9:11 AM
    DividedSky
    Jeff
    Yes Please!!!
    I've been holding off on this project just bc I'm unsure how to complete it. Electrical is NOT my thing...
  23. Sep 5, 2018 at 4:45 PM
    GiantsFanDan
    Here you go. It's the last one on the right of the 4 blanks (orange fuse). The red one is my 2018 headlights LED DRL.
  24. Sep 18, 2018 at 10:48 AM
    DividedSky
    Jeff
    So that's the "Anytime" power?
    GiantsFanDan[QUOTED] likes this.
  25. Sep 18, 2018 at 10:50 AM
    GiantsFanDan
    Yes sir
  26. Oct 22, 2018 at 10:22 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So how hard is this to install? I’m debating on getting one as I want to add lights to my truck and don’t want a shit ton of wires going thru my firewall grommets. Any1 in so cal willing to install? How much?
